I’m just about ready to tackle the Modula MT’s. My first real speaker project. The part that has me most concerned is the crossover. I’m looking at the circuit diagram as well a people’s photos. There are a few things I don’t understand (OK, many things). Using those white plastic Radio Shack terminals looks to make the whole crossover a little neater,. Some questions I have:
-Where do you wire in the binding posts? Is one post the “In -“ and one the “In +” in the bottom photos? On the circuit diagram, the ends seem to be just a few lines. I’m not sure what that means. Although one of the ends is labeled with “Generator 1.”
-Does one binding post color (red or black) usually correspond to + or -?
-The + and - will be marked on the drivers, correct?
-I can use those white plastic terminals to go between:
> the binding post and crossover board 1
>crossover board 1 and 2
>each crossover board and each driver
right?
I’m not sure what I’m doing here. It will be my very first circuit experience. Thanks.
-Jon
The tweeter section:
The woofer section:
right?
-Jon
The woofer section:
