Comparing Dayton RS HF 12” with a Qts of 0.44 and SoundSplinter RL-p12 with a Qts of 0.219 for the Dual 4, how does the driver’s Q play into the sound? As with a sealed sub, bigger boxes with a lower Q (<= 0.577) I hard are more musicale (tight and less boomy). Can the same thing be said of the driver’s Q (the lower the less boomy)?
Does a low Q also mean the driver suspension is looser?
Has anyone heard these two 12” drivers in a sealed box with a Q around 0.577? How do they compare (witch one sounds more tight/accurate)?
Would two Dayton RS12" HF be better then one Titanic 15" in a sealed box Q of .577 (witch one sounds more tight/accurate)?
ThymeJ
ThymeJ
