I'd like to build a new speaker that uses these midranges. I did a search about the C44, and it seems Jon had plans of using the C44 with M8a woofer and Focal tweeter. I'm not sure if that speaker was built, since it was a really old post back in 2002. Jon, would you still recommend using the M8a woofer in a 3-way if using the C44 or would you consider the RS225s? I would imagine it comes down to crossover selection and slope. I'm thinking LR4 between the woofer and midrange at around 800-900hz, but I'm not sure which slope to use between the tweeter and midrange. Especially since I'm not quite sure on which tweeter will sound best with the C44. I'm leaning towards the H1283 at around 4K LR4. Another option might be the Vifa XT19, but I want a tweeter that has a lot of dynamics, even if I'll be crossing over around 4K. So, any feedback would be appreciated, especially now that I'll have the C44s in my posession in a week or so.
Jed
Jed
