Thanks but I already have 8 on hand. I bought extras so if I broke any or I could set up multiple domes to experiment with, etc.
New Wave Guide Study
Originally posted by JoshKBtw, anyone have any suggestions for which compression driver to use? I am clueless about these. The B&C ones look to have much flatter FR, but I have no idea if the horns they are measured on are compairable to the ones the BMS are measured on.
Pinging Mark Seaton, which 1" compression drivers do you like?- Bottom
Well I received my DDS Eng 1-90's. I got the bolt on type. It look like it may be able to be used with dome tweeters...but not sure. I only have the H1212 on hand and its metal grid is in the way. Its a bit shallower than I expected. I think my SteelSound 7" WG's (not 90Āŗ...probably ~70Āŗ...same as Dayton WG's I think) are deeper or as deep.
The DDS is a bit expensive IMO for a WG, but then it is nicer made then the SS or MCM wg. Its not a cheap plastic...its a thicker plastic composite mold of some type. Seems like it'll be less prone to resonance.- Bottom
Hi JoshK,
You might try the BMS.
Iāve got the DDS 90 wave guide hooked up to a BMS 4540ND driver and really like it.
Would also love to try the 4542ND.
The 4540 in the DDS wave guide measured about identical to this graph.
Something to keep in mind if youāre planning a digital crossover with a compression tweeter.
Initially I had the combo crossed directly with a DEQX. Sounded good, but not quite right.
The problem gain mismatch. I had it crossed over to a PHL 1340 bass mid driver and the DEQX was having to pull about 17 db or more from the tweeter. I think this was pushing things as far as the digital DEQX was concerned.
I put an L Pad in the circuit taking about 10db or so from the tweeter. After this, things shaped up nicely.
On crossover points.
As you can see from the above graph, the driver starts taking a dive right around 1500hz.
I found crossing it over at 1500hz did not present a problem for the driver. It never sounded like it was stressing or loosing dynamics at any volume level I listen at even at that low crossover point. This is in stark contrast to 1ā domes which to me really go to poop when one gets anywhere near their natural roll off.
Branwell- Bottom
I found crossing it over at 1500hz did not present a problem for the driver.- Bottom
Thanks Branwell for the tip. Yeah that is a good idea to bring the gain mismatch down with passive elements. I picked up a pair of JBL 2123H's so not altogether different than your combo. Below the JBL's I had planned to use some Lambda TD15x's but the dude who sold them to me innappropriately packed them and they were damaged.
I'd really like to repair the Lambda's but John J of AE hasn't responded, nor has the dude from Millersound. I don't know who else to ask about repairing the cones.- Bottom
Hi JoshK,
I recently dismantled the BMS / WaveGuide, 10ā Phl Mid section to rebuild them into better cabinets.
In the mean time, I rehooked up MTM top sections with Seas W18ex drivers and Millennium tweeters.
The first thing I noticed wasā¦where did all the power go?. The second was where did all the dynamics go?. The third was where did all the detail go? And lastly, where did the life go? My foots not tapping.
Changed out the top units for MT tops with SS8545s and North D28 tweeters. Same thing.
Changed them out for MTM tops with PHL 1340 Bass mids and Morel 110 tweeters. Better, but much the same.
Hereās the thing that gets me. In theory, all of the above systems should have outperformed the BMS / WaveGuide, 10ā Phl Mid section in detail, but in practice, they donāt.
Wondering why, I came to a conclusion...probably wrong, but I like it.
The BMS / WaveGuide, 10ā Phl Mid section is so totally effortless and easy going in my room that it gets played louder, and being louder, one hears further into the subtleties of the musicā¦Will have to take some SPL measurements, but I am fairly sure thatās it.
Would be interested to hear how your setup ends up sounding.
Branwell- Bottom
Originally posted by noah katzIn case he doesn't chime in, I believe Mark favors the BMS 4552ND.
The one I'm very interested in but haven't seen much info or reports on yet is the 1.4" exit, coaxial/2-way compression driver. This driver on the 1.4" 18Sound horn might be a very worthwhile pairing.Mark Seaton
"Make no little plans; they have no magic to stir men's blood..." - Daniel H. Burnham- Bottom
Hi Branwell,
I do believe that you are correct that the fact that the BMS waveguide and 10" PHL are operating well within their linear range is a significant factor, but I doubt this is the only notable difference. If you are using the DEQX then a good deal of the acoustic phase differences are minimized, but that still leaves the directivity of the waveguide and the larger 10" driver. Even if the on axis is matched to rediculous similarity, the off axis, total power radiated into the room, and the interaction with the room's acoustics will be quite different. There's also a question of how the DEQX is taking its measurements and how it determines the correction applied, as the horn has a different acoustic behavior than the dome tweeters and the room will creep into both measurements, and of course contribute less with the waveguide.Mark Seaton
Actually, of their 1" exit drivers, the 4550 is my preference if weight isn't a factor with portability.
Why do you prefer the non-neo version? BMS claims the 4550 can cross a bit lower but I notice it shows an upward spike in the 3rd harmonic below 1kHz that the 4552 doesn't show. If I couldn't see any numbers, and just looked at the curves, I'd be inclined to cross the 4552 lower.
Good catch Dennis,
The neo motor does have greater motor strength which is probably part of the difference. I have not compared the two side-by-side as the projects I've used the 4550 in were ones where the cost was already pushing it a bit and the weight wasn't an issue. It probably comes down to cost, weigth and value of a slight performance gain. If the added cost of the 4552ND was not a concern in a project, I might choose it over the 4550, but in the end you'd need to take some more measurements of the two to make any real determination. I would point out that the waveguide and the crossover design will probably be hugely more impactful on the resulting sound quality than the difference between the two drivers.Mark Seaton
Even though I'm not currently pursuing the static WG avenue , I found this very interesting http://audioheritage.org/vbulletin/s...ad.php?t=12126
He is doing a great deal correctly IMHO. Food for the mind.
Cheers,
AJ
Manufacturer- Bottom
Originally posted by branwellWondering why, I came to a conclusion...probably wrong, but I like it.
Would you agree that waveguides sound more like "the real thing?"
Originally posted by branwellWould be interested to hear how your setup ends up sounding.
Branwell- Bottom
I've posted extensive measurements of my speakers. They use the same compression driver. I agree, they measure well. I've also posted a crossover. I'm using a 99x66 degree oblate spheroidal waveguide.
Originally posted by branwellSomething to keep in mind if youāre planning a digital crossover with a compression tweeter.
The problem gain missmatch. I had it crossed over to a PHL 1340 bass mid driver and the DEQX was having to pull about 17 db or more from the tweeter. I think this was pushing things as far as the digital DEQX was concerned.
Branwell
In my current crossover, I'm using two caps and an inductor, which gives me three corners. Like a 3rd order crossover, but not a textbook one.
:: PB ::Last edited by theSven; 30 July 2023, 14:28 Sunday. Reason: Remove broken url and update image location- Bottom
Apologies if this is a thread hijack, but I'm really curious which DIY available coaxials (or coincidents) AJ would recommend.
Also, where can I get information on some of these waveguides (like the DDS)? Are there links to pictures, prices and technical information?
Thanks.- Bottom
Paul,
I recommend.....you tell me lots more about your systems specific needs
Frequency range, target SPL, box/boxless, shielded/non, musical tastes (eg. ruthless accuracy [rigid cone] vs creamy smoothness [soft cone], etc, etc, etc... and of course, the dreaded b word. Budget.
Keep in mind also that it may be tough to recommend something that I haven't heard, unless its the TAD CST (then the b word would be BIG$), so there are some units that would still be plenty good, my recommendation or not.
cheers,
AJManufacturer- Bottom
Shielding is a non-issue. I'd actually prefer non-shielded since it would probably have better air flow in the back. This is for a music system (not, HT). My musical tastes are broad, but mainly classical music.
Budget is fairly flexible, though I don't think I could pay more than, say $500 or $600 for a coax (woofer and tweeter) pair. Of course, quite a bit cheaper would be better!
Thanks.- Bottom
I have not heard a Silver Iris, but I see a lot of red lights in that approach.
Cheap, yes. Weak motor allows OB without eq etc. Effective but very non optimal. That is simply not the way to equalize reponse..and dipoles need eq.
XO is also way too high for such a large woofer. I would expect less than stellar mids from upper band nastiness.
If you are willing to eq, then a smaller but much higher quality driver is the way to go. 100hz OB requires a good amount of swept volume for even modest SPL. Forget an 8". Too much excursion required, a no no for a coincident driver.
A larger woofer cone and a robust tweeter that can cross low to avoid large cone upper band limitations is the recommendation.
My suggestion would be something like this http://www.assistanceaudio.com/15_Assaudcoaxial.html
Crossed 1-1.3k range.
I've heard Ciare and BMS, but not this unit, so no *recommendation* .
Good luck.
cheers,
Originally posted by AJINFLAI have not heard a Silver Iris, but I see a lot of red lights in that approach.
The Ciare / BMS coax does look nice.
Thanks.- Bottom
I have a question for you controlled directivity gurus. I can appreciate that matching the directivity of the tweeter to the midrange could be a very good thing, but is this an intrinsically better approach than going the other way? As in, a dome mid to match a dome tweeter. Or, does that simply push the problem down to between the woofer and the mid?- Bottom
Originally posted by Paul EbertI have a question for you controlled directivity gurus. I can appreciate that matching the directivity of the tweeter to the midrange could be a very good thing, but is this an intrinsically better approach than going the other way? As in, a dome mid to match a dome tweeter. Or, does that simply push the problem down to between the woofer and the mid?
:: PB ::- Bottom
Oh. Maybe, then, my question was a stupid one . In that case, I may as well make evident my ignorance: how does the directivity of a dome mid and dome tweeter differ?
Thanks.- Bottom
Directivity of frequencies is more appropriate than directivity of drivers. A tweeter carries a greater share of those higher frequencies that tend to be directive, or beam. A waveguide will have a greater influence in dispersing the frequencies carried by a tweeter. A waveguide can have some influence with a mid-dome, just not as much.
I've had to walk the same path as you. There is no ignorance in asking a good question.Ed- Bottom
Phio Audio waveguide
The Phio Audio is also interesting. The developer uses a XT200 as driver and crosses at 800hz. Too expensive (EURO 299) for a test, alas...
Link to Phio Audio- Bottom
Paul E you read my mind! I'm still not totally understanding the goal of controlling this directivity, Edl's answer notwithstanding ops:
Even power response throughout the FR being important to SQ (according to Dr. Toole's research anyway), I assume this is the main goal of the waveguide. But I always thought it was even power response WITH wider dispersion than conventional designs that was important. Not just even power response in and of itself.
So instead of a conventional speaker where beaming is happening by the W and T at the top of their FR, we are trying to beam (or at least tighten directivity) throughtout the FR of the speaker until about the the lower half of the W's passband? Sure power response will be more even through most of the speaker's FR, but dispersion would be less through that same area.
I would think REDUCING the beaming of the T and W in the higher frequencies of their passband would be the way to accomplish Dr. Toole's observations. Not increasing beaming of T at lower frequencies, as would be the case here.
I guess it comes down which is more important: the even power response with wider dispersion, or even power reponse with narrower dispersion. Or maybe just higher dispersion period versus even power response.
As far as dynamics, lower XO, lower distortion, and time alignment, just on those merits I like waveguides. But power response seems very important and that was the subject I'm most trying to understand. Hope that all made sense :ELast edited by augerpro; 28 November 2006, 05:45 Tuesday.- Bottom
Also what are some popular 6" or so wg's available in the US?- Bottom
Augero,
A dome tweeter has VERY wide dispersion in the lower frequency ranges- in fact, this is responsible for a phenomena called tweeter "flare" in the lower ranges of the crossover, where it's dispersion is much wider than that of the midwoofer in the crossover region in many designs.
Very wide dispersion also increases room interaction, as there are more side reflections from adjacent walls, ceilings.
In my own current project, I'm using a waveguide to lower the workload on the tweeter in the lower part of it's working range, and to control the directivity so that it more closely matches the dipole directivity- where in the lower midrange front to rear cancellation helps match up the directivity with the upper range portion of the middrange driver, and of course the bass range has more limited directivity (and less room interaction) with a figure eight dipole (not U baffle). Reducing the room interaction for off axis sounds means that the direct sound of the recording predominates more. And the room less. IMO, that's a major contribution to fidelity of reproduction, especially for recordings with a true acoustic on the recording (i.e., not multi-mic studio wonders. But even the latter will be clearer sounding).
~Jonthe AudioWorx
Just ask Mr. Ohm....- Bottom
Here is a question for Jon or anyone with knowledge. Back in the day a company called Community Light & Sound came out with "constant directivity" horns. They were available for compression drivers and even up to 15 " drivers. These were for pro use in sound systems. As time went on, companies like EV and JBL picked up on it and brought out their own version of constant directivity horns. Are these comparable to a waveguide and, if they are, why are all waveguides I have seen very smooth from throat to the outer edges whereas constant directivity horns were always somewhat had a wiggle in their mold to achieve constant FR in all in the vertical and horizontal plane according to their specs? If they are not the same, what is the difference between a waveguide and a constant directivity unit? Thanks!
Chuck- Bottom
Augero and Paul,
I believe in trying to wrap words around the issue I made a mistake.
"A waveguide will have a greater influence in dispersing the frequencies"
Should have read: "will have a greater influence in controlling the dispersion of lower frequencies".
Thanks to Jon for helping me realize my mistake.Ed- Bottom
Chuck,
I don't know if that's covered in Earl Geddes' book. I was going to buy it, but got lost just reading the table of contents....... 8O
Perhaps someone with the book could comment.
Chuck,
Yeah, the current waveguides are a variation on the constant directivity theme. The main difference is one of emphasis. The old ones were trying to get a lot of horn gain so they used a lot of compression in the throat leading to high distortion. Modern compression drivers have much more SPL capability so the emphasis is more on controlling directivity and keeping distortion low than maxing SPL.
About the wiggle in the mold, do you mean increasing the flare rate out near the mouth? That's an effort to reduce reflections/diffraction from the mouth, similar to how a big roundover works. It's a problem with the commercial Geddes-style waveguides I've seen. Geddes stuffs the horn with very low density foam like the stuff JBL used to use for grills. Peavey has an interesting variation where they use higher density foam at the outer edge. An advantage of foam/felt treatments is it keeps the total size of the horn smaller compared to a large roundover or flare.
Quadratic-Throat-Waveguide.pdf
Image not availableLast edited by theSven; 30 July 2023, 14:30 Sunday. Reason: Attache PDF and remove broken image link- Bottom
In the case of the flaring of the end or increased angle at the last 1/3rd of the horn mouth, this is done for two reasons. Reflections from diffraction off the sharp edge transition is one reason, but the other is that with an appropriate driver, a straight walled horn will hold its physical pattern fairly well down to some low frequency. Then at very low frequencies it will of course have no pattern control. Aside from diffraction off the edge of the horn, the flaring of the end of a straight walled horn is an effort to smooth the transition from the horn controlling directivity to not having any.
With a straight walled horn and sharp termination, just below the range over which the pattern approximates the horn wall angle, the directivity will colapse and narrow down and then quickly expand towards point source behavior. By flaring the large end of the horn, this transition can be made more gradual such that the transition is more of a gradual loss of directivity or widening of pattern.
Of course we also aren't accounting for all the peculiarities that happen if you try and deviate too far from a round/squarish pattern and the potential for pattern flip and loss of pattern in one axis before the other.Mark Seaton
For those who missed it, forum member Mefistofelez posted a link to a nice summary of modern horn/waveguide design written by Jack Bouska.
Factors Affecting Sonic Quality of Mid & HF Horns & Waveguides (Part #1 of 9) This thread is an offshoot of the Handmade Ersatz M9500 thread, found at: http://www.audioheritage.org/vbulletin/showthread.php?t=12390&page=3 The thread evolved into a comparison of various horn contours, which included a pair of questions (from Rob H. and Ian Mackenzie) addressed to me. Rather than dilute the original thread with a long reply, I have opted to initiate a new thread dedicated to a discussion
There's also a DIY section where Jack makes his own waveguides out of solid oak.
I posted some images of my recent waveguide construction on the "Horn system pictures" thread, , and in post #51 "Titanium Dome" followed my post with a request for the & measurements I made on my waveguides. Rather than clutter up the "Horn system pictures" thread, I have chosen to start a new thread under the DIY section, with more details of the design and images. The two new waveguides are mounted on a pair of 1"
All very interesting! Thank you all for bringing me back to the current century, but I will have to say that the foam/felt looks suspiciously familiar. Why, it was used on my UREI 813's some 20 years ago as Mark said. I have also used constant D (sounds like a rap name?) horns in churches and auditoriums where you wanted strict control over the patterns to set up intelligble audio. And we used to call some of the larger constant d horns "the lips of God" instead of Jaggers lips. We used several that were 3 to 4 feet wide and 2 to 3 feet tall. Thanks for the answers.
Chuck- Bottom
OK, so I think I understand the basis for desiring controlled dispersion.
My next question is: is it better to go dipole in the midrange (with a cone) or to use a waveguide with a midrange such as the RS52? Any clear pros or cons to either approach? Assuming dipole bass, of course.- Bottom
Originally posted by Paul EbertOK, so I think I understand the basis for desiring controlled dispersion.
For me, anything above about 200-250 is midrange, up to about 2-2.5 kHz. YMMV. We did a speaker for ThomasW that was dipole up to 300, then controlled directivity midrange above that. There are probably too many different factors to consider, but in general, I didn't like it as much as I did the Arvo midrange being dipole from 200 Hz to 1200 Hz, as well as lower.
OTOH, I've never heard a midrange dome waveguide setup; keep in mind you could probably only get that to work down to 600-800 Hz, and that would be a BIG waveguide- double or more the size of the tweeter waveguides we're playing around with for 2kHz and above. Then, you'll still need a tweeter waveguide, and a lower midrange (though you might be able to stretch the Aurasound NS12 up that high- it's going to be beaming somewhat by 600. My own measurements show the distortion on the NS12 to be falling steadily all the way up to 1 kHz. I don't know of another 12" driver you might pull off a crossover to a waveguide loaded dome mid. So, maybe you could pull off a three way in that fashion. Would be interesting to see what the tradeoffs are; it would be a pretty tall vertical source at 600 Hz, getting close to a line array, which would mean SPL response would be variable for the system overall depending on distance (line array around 600 Hz, close to point source else where).
Now, how about a stack of 4 NS12's on each side, a waveguide loaded BG RD50, then a stack of ribbon tweeters above 4 kHz?
Oh yeah, better be careful with that idea, that's Evil Twin's Saint-Saens...the AudioWorx
The problem with using a WG for a mid (like the RS52) is that you could only use it up to around 7k (or so) at which point you must cross to a tweeter that will be completely decorrelated, seperated by several wavelengths if mounted (for example) above the guide, due to the large guide needed to effectively horn load the bottom end - as Jon points out. Mounting a small tweeter inside the guide (reverse unity style) to reduce CTC would create too many other issues.
cheers,
Well, it seems I can rule out the WG mid. Probably a good thing: I don't have to add a whopping lathe to my wish list
Thanks!- Bottom
Originally posted by AJINFLAThe problem with using a WG for a mid (like the RS52) is that you could only use it up to around 7k (or so) at which point you must cross to a tweeter that will be completely decorrelated, seperated by several wavelengths if mounted (for example) above the guide, due to the large guide needed to effectively horn load the bottom end - as Jon points out.
This does require a pretty big waveguide, though - I tried an RS52 in a sawed-off PE 12" waveguide, and didn't get much below about 1k with it, so you have to figure 14 to 16" by the time you get some edge transition, at which point you're starting to worry about C-T-C to the midbass.
Of course, given that I threw in the towel on all this and just shelled out $$$ for the real Yorkville Unities, I guess I'm obligated to point out that there are some real practical challenges involved.- Bottom
