Since I got so much information by reading through this site when I was planning and working on my project I thought I would have a little "Show & Tell". I originally started thinking about replacing my sub with something larger about nine months ago. I really liked the sound of my sealed low Q sub (ACI Titan) but wanted something bigger for the 3600 cu. ft. multi-use room in the house we moved into. I also like the take the hands on approach so I thought this would be a good opportunity to get into DIY audio.
I did a bunch of reading here and at other forums and decided what I wanted to do was an infinite baffle subwoofer. My setup is in a corner with everything on a 45 degree angle into an L-shaped room. Certainly a less than ideal audio configuration, but given the room restrictions with a fireplace and bookshelf on one long wall and a large window and bookshelf on the other and three avenues of approach it was the best we could do. Unfortunately, I came to realize an IB was not going to work with my current situation - with two exterior walls a line array baffle was out of the question, a ceiling mounted baffle wouldn't work because of the roof line, and the floor mounted baffle failed to meet the WAF. I think it had to do with something about whether the next homeowner would want a 15"x15" hole in the 50 year old hardwood floors. Oh well, onto the next step.
After a bunch additional reading I decided that I would go with Dual 15" Subs to make sure I wouldn't have a case of upgraditis any time soon. I could fit into my designated space either a copy of Tube-Zilla or stack two sealed subs similar in size to the ones that ajpoe did in his in his project (https://www.htguide.com/forum/showthread.php?t=14644) I showed my wife the pictures of the two possibilities and got the go-ahead on the two sealed boxes. After that it was a matter of looking at my size limits (about 20"x20"x24"), the current available 15" drivers, and working up possibilities in Unibox.
I used the RL-P 15"D2s for drivers and a Nady XA-2100 as an amp. The amp is probably more that I would need but the price wasn't much more than the other Nadys. For the boxes I made it easy on myself for a first project and modified the old 88.5l sealed Shiva plans. I basically just added another layer of 3/4 MDF to the outside, added an additional layer to the inside of the front baffle, and changed the bracing to a window brace. The end result is 23.5" x 19.5" x 19.5" with 1.5" MDF alll around except for the 2.25" front baffle. The volume is about 80l net and they weigh a little over 125 lbs each. Here are a few pictures.
Images not available
I appreciate any comments, questions, or suggestions. Since finishing this I am looking forward to more DIY projects down the road.
