Infinity MRS (rectangular) driver
  • AJINFLA
    • 682
    Reviving the "square" driver technology from the 80's (I think I recall some Sony models) using some of their old technology ( remember the EMIT, EMIM) with a new twist. Interesting that at least they are trying something a little different. Perhaps the driver technology experts here can analyse this a bit further. With those huge coils I imagine thermal power handling it a non-issue. Suspension would definately be the limiting factor here.
    Of course, how good it performs (sounds) is really all that matters.
    White paper:
    Cheers,
    AJ
    Manufacturer
  • westrock
    • 10
    A rectangle just doesn't work for me on a standard piston driver. The surround has to do weird things at the corners (no corners on a circle). And how is the magnet and voice coil shaped? Are they rectangle too? Is the load spread evenly? These are the concerns I have. I don't have any problems with oval speakers, like a 6x9 or something, but the hard edges of a rectangle seem bad in my mind.
    • AJINFLA
      • 682
      No time to read the white paper there West?
      It shows the shape of the vc in a pic.
      Cheers,
      AJ
      Manufacturer
      • poneal
        Ouch :E
        :E Slam dunk. :E
        • GrahamT
          • Oct 2004
          • 378
          Cheers,
          AJ
          I get "page not found"
          • AJINFLA
            • 682
            Hmm, you're correct, although it worked before. Try a cut & paste with this and see what happens.
            Cheers,
            AJ
            Manufacturer
            • Dave_H
              • 3
              It is amazing how they "discover" new transducer technologies and techniques. I believe Sansui had a speaker that utilized the same configuration in the 80's. The drivers were available separately for a while and I built a pair of speakers using them. Like all "Holy Grail" drivers they were OK and maybe could have been very good if I had the time and inclination to fine tune them. A similar DIY driver was also published in Speaker Builder or Audio Amatuer years ago.
              Dave_H
