Things I like about LspCAD 6
    • 15284
    Or, what I'm going to do on my Thanksgiving vacation?
    Seriously, though LspCAD 6 hasn't received the warmest of welcomes, due to the pricing on the new version, and lack of availability of a lower cost "standard" version (at this time, only the "Pro" version is available), I have to say this is a complete re-write and a there's a lot to like here- some fairly obvious, some more subtle. That's my story, and I'm sticking to it...
    So for the benefit of those who haven't waded through the demo manual and run the demo in depth, I'll toss out some comments and highlights. As I encounter or discover or remember more things, I'll come back and update this first post. If you check out the demo yourself, or get LspCAD 6 and have your own opinions and experiences, please feel free to post on this thread.
    One point upfront- I own a couple of older copies of Soundeasy, but I'm not intending to get into a "he said, she said" kind of tit for tat between the two programs- I haven't been using SoundEasy for a few years, so I'm out of the loop for that. When I "switched" to LspCAD it was because I found it fit my working style better, and had certain capabilities, including ones more related to documenation of work, that I liked and valued. YMMV.
    So, if you're in a new purchase mode, consider both, and by all means get as many opinions as you can, but also get some hands on time with both before making up your mind. There's a lot to explore in the LspCAD 6 demo.
    Schematic Editor
    The data entry part of LspCAD is totally re-vamped, and now works like a true simulation schematic tool - it's not driven by the constraints of a ladder network simulator using text entry, but allows you to draw out your schematic manually. Big plus, coming from a CAD guy like me.
    Components have detailed menus brought up by right clicking, including building in parasitic resistance, specifying a minimum and maximum range of component value under the optimization process (way cool), range for olerance analysis, enabling/disabling optimization, and being able to specify which optimization target uses this component- also way cool.
    Detailed component configurations can be cloned, differing only in designator and nominal starting value. Way cool, since you can save these configured components to a scap sheet or a template file...
    (if you're thinking that there's a lot of features here which make this a powerful, configurable production environment that would appeal to a real engineer or someone who has to do this for a living, you're on the money).
    Note boxes can be added to the project schematic pages as needed, to hold comments and thoughts as you develop a project.
    Projects can have up to 10 pages of schematics, accessed by a drop down box.
    Box models are now created on the schematic pages, and a templates for common types are included. Box models can be mixed with measured data, passive crossovers, active crossovers and active EQ all in the same single project file- a unified modeling environment is used for all.
    Graphs
    Graphs are now collected together into a single window, using tabbed panes to select which is displayed. Includes a new polar plot and polar map function.
    Calculated data from graphs can now be exported, either in simple text format, or MatLab format.
    As with past versions of LspCAD, updating component values manually or by arrow keys in the Schematic produces immediate updates to the displayed graph.
    Optimizer
    Box transfer function as well as network transfer functions can be optimized using selected parameters.
    When you're optimizing a section of a filter or your crossover, the parts which are checked in their local right click menu for optimization appear in bold, as a reminder of which parts are being adjusted/affected.
    User Interface
    The main control window is used to open projects (multiple can be open at once, up to memory limitations), and lists all the components in the current Schema pages, including drivers, along with key parameters and data.
    Settings and controls for the Optimizer and Emulator are located here.
    More to come- this is a post in progress.
    • 1345
    Well, Jon is certainly impressed, and the feature descriptions make this seem like a real "pro" tool. Okay, we've read references to a high price. Just how much is this puppy?
    I just loaded LspCAD non-pro and hope to jump into it soon with some of the new Dayton drivers. You pros out there must be very tempted by the new pro version.
      • 10931
      Hank,
      Unfortunately George W's handling of the US economic situation has caused to $US to plunge against other currencies. That hasn't helped with the price of LspCAD.
      The Pro version started out expensive and is getting more so.
      I bought it as an upgrade from Standard years ago for $350. The nonupgrade price then was $500.
      Until Dec 31st 2004, those upgrading from version 5.25 Pro to V6 of Pro can do so for $200. Those wanting to upgrade from the Standard version to Pro can do so for $510.
      After Jan 1, 2005 the Pro to Pro upgrade goes up to $485 and the upgrade price from Standard to Pro will be $850
      To buy Pro from scratch will be $980.
      One really needs to have Jon's level of knowledge to take advantage of what the Pro version now offers.
        • 3791
        Can you say "pricing yourself out of the market?" Starting from scratch, you'd really have to love the LspCAD interface to pay twice the price of SoundEasy which has equal (some would say more) capabilities.
        • Davey
          • Jan 2003
          • 355
          Yeah, I think LspCAD has gone over the top. I bit the bullet and upgraded to version 6, but I purchased the Pro version quite awhile back too. I can't see why any potential DIY customer would go that route now with the other options available.
          Davey.
            • 15284
            Starting from scratch it would probably be a different story these days, though I like Ingemar and the communications and support I've gotten from him.
            Soundeasy has had for some time some interesting features like the room space modeling; at this time, I'm intrigued by the "unified" approach Ingemar has taken and the possibility of modeling with defined or imported transfer functions- I'm thinking that the tool may be flexible enough to model dipole systems accurately with some effort.
            • Davey
              • Jan 2003
              • 355
              How would you approach modeling a dipole system with LspCAD?
              Optimizing to a user-defined target transfer function was available in previous versions of LspCAD. The free-form design environment is the only significant upgrade I can see in the new version. With previous versions you could pretty much construct whatever topology would be required....within limits.
              I just don't see anything with the new version that warrants the price. Hopefully a "standard" version will be forthcoming at a much lower price.
              Best,
              Davey.
              • Mark Seaton
                • Aug 2001
                • 197
                Hi Jon,
                Thanks for the heads up on the new version, I hadn't seen it was now available. From your description, it sounds like there are some very useful improvements for those doing lots of optomization and experimentation. The schematic entry is very welcome, especially if it allows more non-standard filter networks to be more easily modeled. I do like the idea of tab-sorted graphs, as it can be tough to sort through and keep track of all the windows in the current version.
                I plan to download the demo today, but I was curious if you knew if V6 allows optomization of the phase response as well as magnitude? I know this was mentioned as a feature to be added in the past.
                Thanks for the heads up,
                Cheers,
                Mark Seaton
                • Davey
                  • Jan 2003
                  • 355
                  Mark,
                  I am not Jon, but, yes, it sure does. You can optimize the phase response over a defined frequency range with a defined delay or to an imported phase response target.
                  Davey.
                    • 15284
                    There's a lot of different ways to use the optimizer in the new version.
                    With the old version of LspCAD, only relatively standard ladder network configurations could be entered, or some limited series network configurations. The new version is essentially free form, as far as output configuration, especially since you can now sense differentially.
                    Some other features are more subtle- being able to define component characteristics including optimization range- one can setup "standardized" components on your scratch template for certain applications areas or types-, and copy and paste those into your circuits, or build blocks which you clone and re-use- these are productivity oriented features, but unless you only do one project a year, productivity is a good thing...
                    Transformer component is new; now, it would be possible to model the ultra high slope filters such as Joeseph audio uses, which uses transformer coupled components for cancellation.
                    Baffle component for diffraction analysis with data measured originally on an infinite baffle.... (granted, not as good as having data from the exact baffle, but allows educated "what if" modeling)
                    The transfer function module gives the opportunity to model G(s) and G(z) in a variety of ways- this also includes the possibility of direct "code" input, using Matlab syntax, to model an acoustical transfer function-
                    Additionally, a transfer function from a text file can be imported, so if you can model it in MathCAD or Mathematica, you can create a file to use with LspCAD for modelign the whole system. This is way cool, in my opinion.
                    Now, if I was into the digital crossovers, having the dbx Pro DriveRack 260 component, or the Behringer DCX2496, or the XTA component of the DP224 and DP226 digital crossovers would definitely float my boat- and is a substantial addition. OTOH, I'm not into them, but still, it's a significant feature upgrade.
                    I'm not suggesting that everyone should rush out and buy LspCAD6, but for me, upgrading was a no-brainer. Everyone has to make that decision on their own- and for a lot of folks, doing just one or two "standard" projects a year, I expect LspCAD 5.25 std will cover most of their needs-
                    ~Jon
                    • Mark K
                      • Feb 2002
                      • 388
                      Looks like lspCAD 6 standard is coming. And the price looks more reasonable. (~115 euro currently for an uprgrade from 5.25 standard-which is around $150)!
                      www.audioheuristics.org
                        • 15284
                        That's good news; I've got a copy of 5.25 std I'd also like to update.
                        ~Jon
                        • Davey
                          • Jan 2003
                          • 355
                          LspCAD 6 Standard now available.
                          Davey.
                            • 1345
                            Oh Thomas, the econnomy isn't the president's "fault" - it's more complex than that, but Let's not go there - this is a friendly place.
                            I am disappointed. I contacted Ingmar a few months ago and asked about the upcoming improved upgrade to the standard version. I said I'd bought ver 5.25 but hadn't opened and installed it and wouldn't if the next version would be out in a reasonable amount of time, so I offered to trade mine for a reasonable fee, considering I'd been out the money for 5.25 for months and hadn't used it. He said it would be a "long" time (like next year) before the new standard version would be available. Now that I've opened and loaded 5.25, I discover that the new version is out. Drat! Just my luck, like having my rental car broadsided by a deer last Friday night (and of course I had declined the rental company's insurance :cry:
                              • 10931
                              Oh Thomas, the economy isn't the president's "fault"
                              I know, according to Frontline, WalMart is to blame ...... :wink:
                              My personal auto insurance covers me when I rent a car.
                              There's nothing wrong with LspCAD Standard 5.25.
                              Jon used LspCAD Standard to design ALL the projects you've seen him develop in the last several years. That should give you an idea as to how powerful the standard version is. He just upgraded to Pro with the V6.0 offering.
                                • 1345
                                Good one, Thomas - the evil empire Walmart.
                                Yes, my personal auto insurance covers it, but I'll have to pony up the $500 deductible. Point is, if I'd taken the $12 Enterprise insurance fee, they would have been responsible for the entire repair cost. What's that old saying about being penny wise and pound foolish?
                                • AndrewM
                                  • Oct 2000
                                  • 446
                                  If I'd have paid the insurance every time I rented a car I'd have been able to pay the insurance deductable a few times over. You may want to check with your credit card company to see if you are automatically covered.
                                    • 3791
                                    The standard version of LspCAD 6 has the following features missing. I know what some of them mean but I don't understand the context of all the terms. Which of them are "must have" or "nice to have" features for someone doing a couple of systems a year?
                                    PS - I browsed the Soundeasy manual and their way of modelling opamps is really lame (IMHO). Single + or - wire in instead of two +/- wires in and you have to calculate the gain, impedances, etc. and type them into a dialog box. So you end up with a schematic that looks nothing like the real schematic. I believe LspCAD lets you just add your resistors, caps, etc., like the real thing.
                                    The standard version has the following features otherwise available
                                    in the professional version excluded or limited.
                                    Crossover emulator, only two channel output possible.
                                    Snapshot, only possible to take snapshots of the SPL graph
                                    Tolerance analysis
                                    Voicecoil heating
                                    Extra transfer function
                                    Polarplot
                                    Polarmap
                                    Power response
                                    Optimizer options missing in the standard version
                                    Optimize Impedance
                                    Optimize Transfer function
                                    Target XO points
                                    Target Zmin
                                    Target Box vol
                                    Target Phase
                                    Target EQ
                                    Target Imported
                                      • 10931
                                      We have a copy of LspCAD 'standard' on order, we'll do a compare and contast between it and the Pro version.
                                      For those that don't know, older V5.xx LspCAD files aren't compatible with the new V6. So plan on re-entering all your data if you upgrade, since you can't import older project files.
                                        • 15284
                                        Uh, not quite right-- as I mentioned, LspCAD 6 has an "extra's" menu, among which is running in LspCAD 5.25 mode, so you can use your old files.
                                          • 3791
                                          Guys, if you act quickly, you can get Pro for the price of Standard. Ingemar is offering a free copy of Pro to the first 20 people who make a USD $210 donation to the Red Cross or Unicef for tsumani aid. What a guy!
                                          • Paul H
                                            • 904
                                            That's very considerate and generous of him.
                                            I tried, but Ingemar just advised via email that the available 20 copies are all reserved.
                                            Paul
                                              • 15284
                                              It went pretty quickly. Not surprising. Still, no doubt Ingemar is a gentleman and a scholar...
                                              ~Jon
                                              • Paul H
                                                • 904
                                                My LspCAD 6 Standard copy is ordered and on the way. I checked out the other typical speaker design programs but was very impressed with LspCAD's ease of use, particularly the "autocad-like" feel on the crossover and box layouts.
                                                First I think I'll take some measurements of my M8n/xt25 centre, and try to adjust it. It's almost right, but not quite - it has a different baffle than the one on my mains.
                                                And then, I'm doing some dipoles, and then ...
                                                Paul
                                                  • 15284
                                                  Sounds like you're on a roll, Paul!
                                                  LspCAD 6 is addictive, I find- I keep wanting to work on new projects to see how it will handle them!
                                                  • Paul H
                                                    • 904
                                                    I got a parcel in the mail from Sweden today ..
                                                    Paul
                                                      • 15284
                                                      I spent all day measuring drivers to feed the hungry maw of LspCAD6 ...
                                                      Congrats on getting your package!
                                                      ~Jon
