I'm getting started on my first pair of speakers, I've decided to go with the Kit281s. The instructions specify MDF or greater. After reading thru a few posts and some reviews on other web sites, I have found references to birch being a good wood if not using MDF. The main question I have is are denser woods preferred? I've got access to 3/4" oak and I'm curious if most use MDF to keep costs way down or if there are more serious considerations in choosing the type of wood.
The next question deals with putting everything together. Are all of the cabinet pieces glued, nailed, screwed? What methods did you use to put the cabinet together. Thanks for the help,
sw
sw
