Mirrors to help place panels?
    • 3815
    I'm a regular hackaday reader and saw this and thought it was interesting. What do you guys think?
    If you know your way around a pool table you should be able to apply those skills to improving the sound of your home theater. [Eric Wolfram] put together a post that discusses the issues caused by…
    Here's the article if you can't get to hackaday:
    f you know your way around a pool table you should be able to apply those skills to improving the sound of your home theater. [Eric Wolfram] put together a post that discusses the issues caused by unwanted sound reflections and shows how to position acoustic tiles to solve the problem. This is a companion post to his guide on building your own acoustic tiles. Don’t worry if you haven’t gotten around to doing that yet. With just a wood frame, dense fiberglass, and some fabric they’re simple to build. They’re also easy to hang but until now you might have just guessed on where they should go.
    Once you have all of your speakers and seats in position grab a mirror and some post-it notes. Take a seat as the viewer and have a friend operate the mirror as seen above. With it flat against the wall, mark each spot with a sticky-note where you can see a reflection of one of the speakers. Finding the reflection points is just like lining up a bank shot in Billiards. With five speakers (5.1 Surround Sound) and six surfaces (walls, ceiling, and floor) you should be able to mark 30 reflections points. Now decide how wild you plan to go with the project. The best result will address all 30 reflection points, but you can get by with just the front marks if you’re a bit more conservative.
    -Chuck
    .......What do you guys think?
    Yep! :T
    It is a quick and easy way to find the first reflection point on your walls.
      • 3815
      Cool. I just wasn't sure how true it was considering some designs will "lobe" the sound in various directions so it might not be a straight shot as the mirror idea suggests.
      -Chuck
        Lobing is generally a function of the speaker design; reflection points are a function of the sound waves from the speaker interacting with the perimeter of the room relative to the listener’s position.
        Which begs the question: Does a speaker make a sound if no one is there to hear it? :W
        • madmac
          • Aug 2010
          • 3122
          Yes.....but it doesn't matter in that case !!!! :B
          Dan Madden :T
            agreed, the mirror method is a good one to use.
            • madmac
              • Aug 2010
              • 3122
              I like to collect art and find oil paintings on canvas an excellent acoustic tile/ panels !!.
              Plus....they look good too !!!
              Dan Madden :T
