Ok, so I pretty much got the absorber idea down-packed for multichannel (at least I think I do).
-Treat first reflections from L/C/R on walls, floor, and ceilings for both rows of seating. I'll be using 3" OC703 for walls, carpet on floor, 2" OC703 on ceiling.
-Treat front wall / screen wall and use acoustically transparent screen. Using 3" OC703 covering the whole area directly behind the screens and making cutouts to fit the future 3 x TMWW towers. (I already calculated how the wall distance would affect the FR of the towers assuming the 3" OC703 and it looks fine)
Now, diffusors are a whole different story. I really really really like the look of Primitive Root Diffusers so I would definitely take the time to DIY some panels. The thing is, I don't really have a clear idea of where to place them or how much to use. Now, when I talked to Chasw98, he basically told me absorbtion is more important in the front and diffusion is more important in the rear; he gave some analogy of 'playing music while sitting on the edge of a cliff' sound is what I am aiming for. So he said the diffusors should be located in the rear part of the room near the rear and side surrounds.
So this is what I'm asking:
1. Am I missing anything in the absorbtion area?
2.How to make a Primitive Root Diffusor (skyline type)?
3.Where exactly do I put the diffusors assuming a 7.1-type multichannel audio?
