Zero's for IR codes?
    • 16478
    Some people find they get null values instead of IR codes in their CCFs from time to time. This is almost always a case where the user is opening CCF's with different versions of pronto edit. Because pronto edit 2 uses the built in data base it assumes that will be present when you open the CCF. If that CCF was created in pronto edit 1.05 there is no database so it get's confused and you end up with the zero's. If you try to open a CCF from version 2 in 1.05 pronto edit will crash. So what you should do is install both 1.05 and version 2 on your PC. First try opening any CCF you get with 1.05 if it opens then great you know it was made in 1.05 and will work fine for your remote. If however it fails open it with version 2.0 and use the save as option to save it as an old CCF. This will remove the links to the database and allow pronto edit 1.05 to open it with the IR codes intact. Hope that helps some people.
    My review thread for the Rotel 1066
    by Andrew Pratt
    Alrighty then my long awaited Rotel RSP-1066 has arrvied and is now installed in my gear rack. I'll preface this review thread by saying that before the rotel 1066 I've owned a Rotel DD/DTS pre amp, HK receiver, Sony DB930, Denon 2800, Denon 3300 and lastly the Sony TA-E9000ES. In each case these were...
    30 May 2002, 09:20 Thursday
  • dschamis
    Pronto .ccf for the RDC-7
    by dschamis
    I am using a Pronto .ccf which I think is good, but not great, for the RDC-7.
    If people would email me their's, I'd be more than happy to take a crack at coming up with a consolidated "Best-of" .ccf and redistribute.
    dschamis@aya.yale.edu
    Also,...
    10 October 2001, 14:41 Wednesday
  • Jon SS
    Rotel RCC-940 Cd player remote codes
    by Jon SS
    I have a Rotel RCC-940 Cd player but have lost the remote. I am using a the MX-700 universal remote but am unable to use some commands namely, PLAY, STOP, PAUSE, FF, REW. The MX-700 can also use Pronto ccf files.
    Does anybody have an ccf files that may work. I think Philips remotes work...
    15 September 2003, 12:06 Monday
  • Eiffel
    Additional Rotel IR codes for RSX-1055?
    by Eiffel
    I recently purchased a Rotel RSX-1055, and have already interfaced it with my Home Theater PC via its serial interface (which works like a charm).
    When I look at the commands available on the standard Rotel remote (RR-1050) or in the CCF file that Rotel provides, I find that many useful...
    27 October 2003, 20:25 Monday
  • Wireless
    Discrete on/off for Pronto
    by Wireless
    Hello fellow AVP owners,
    I am working on setting up my home automation controller, but I can't find discrete on/off codes for my AVP. Does anyone have a Pronto ccf file with these defined?
    Thanks for the help!
    John
    My HT...
    05 August 2001, 17:46 Sunday
