XP Hints, Tips and Tricks
    • 16478
    I thought I'd start a master thread where we can post tips and tricks that we come across as we learn more about XP and its "features"
    Two that I have used in the last couple of days are
    To rebuild critical XP system files that may have become unstable try this.
    SFC /SCANNOW
    Place your XP disk into the CDROM then enter this at the run prompt exactly as its shown above with the space and it will do a system check for you.
    the other goodie I found was a way to edit user profiles and log in type using the
    Control userpasswords2 command at the run prompt...very slick.
    • 27460
    Well, one feature I found was when my cursor locks up, hit the power off button to fix the problem.
    Another nice feature? pressing like 4 keys just to log out, having to sit there for 20-30 seconds for the next prompt. How stupid is that? Then he doesn't shut down all the way sometimes after you go through all this.
    Sorry to be a downer, but so far, these things aren't making XP the CATs meow for me.
    Lex
      • 16478
      Doug check out the link in the MP3 thread there's a section in there about making switching users faster...and getting it to log on automatically for you which is what I do on both our machines.
      • Brewer
        • Feb 2002
        • 14
        XP is Crap sorry to say unless you have a 850 processer or faster dont try to use it .Only buy the up grade if the only operating system thats on your pc has been the full version of ME thats the only way it will work right ....windows 2000 is the best still and the most stable i can leave my pc on for days and days and i wont have to reboot when i come back or can install software with out rebooting .....Your Dammed if you Do and Dammedif you Don't
        Kevin A Brewer
        Kevin A Brewer
        • Bing Fung
          • 6523
          Kevin, on what are you basing your opinion on?
          I have ran both XP and W2k and I find XP is much more stable by far, as well the driver support has been a lot better in XP.
          I had a ton of games that would not run in W2k, this required me to run a dual boot system of ME and W2k. When I set up XP I also set up a dual boot system of ME again. What I have found is I don't really need this dual boot system anymore, for XP will run all the games that W2k would not.
          The logon welcome window is a nice addition and allows my family to log on with out logging me off, or quiting any applications I may have running.
          The handling of digital images from my CCF card is totally slick. It will rename all the generic DSCN files to what ever I want in a batch. Then the thumbnail viewing of them is a nice feature, as is the quick photo edit features. Another nice feature is the way I can resize the images to for it's intended use. Publish to the net? It prompts me to size them accordingly and then saves the picture file as another version. Same goes for e-mailing them, I just right click, send to, mail receipent and it asks if I would like to resize.... can't be any easier than that.
          The built in image viewer alone is worth having XP. Using my MS Explorer mouse I just click forward or back on the mouse to view the image I want. sure I still use PaintShop Pro 7 and Adobe Photoshop 6, however most times I use the built in viewer & editor.
          Driver roll back is a cool feature that I have used on many occasions. The help files are alot more usefull as well.
          USB support and recognition of hot plugged devices is much more consistant and reliable in XP. With W2k, many times it would do nothing when I plugged in a device. My CCF card reader was a total pain to use with W2k, now with XP it is like another removable drive.
          A lot of people comment on the look of XP, personally I like it a lot more than W2k. It's has an updated look that is broken from the Windows 3.1 era that I find appealing. And if you don't care for it, it has the classic skins as well.
          IE 6 forever crashed and dumped in W2k on my system. This was a real downer for I really liked the features of IE 6. However I had to use IE 5.x in W2K. IE 6 is an intregal part of XP and I wouldn't want to use anything else.
          Those are the features that I use the most and find is more than worth the jump to XP.
          Lex, com'on, it takes 3 clicks to shut down XP, and it boots way faster than W2K. I have yet to experiance the long shut down times like that of W2k. 3 clicks is all it takes, sure W2k does it in 2, however I found a lot of times W2k will just sit there thinking about shutting down as its "saving your settings" That is your main deciding factor? :roll: I like the power button tip :LOL:
          XP Tip courtesy Dick Matthews.
          Windows XP reserves 20% of total available bandwidth by default. This is designed for office environments which will reserve 20% for real work, while giving resourses to the other people downloading MPEG files for fun.
          To unreserve the 20% go to Start and select Run. Type gpedit.msc and press enter. Expand Computer configuration then go to Administrative templates. then Network and select the QoS Packet scheduler. Double click the Limit reservable bandwidth key, and check the enabled item on the settings tab. Change the bandwidth limit % to 0, then click apply and exit gpedit.msc, this will free up that 20%.
          Don't know if it has made a difference, but at least I know I have every available amount.
          Bing
          Bing
          • Trevor Schell
            • 10936
            ROTFLMAO :LOL: :LOL: :LOL: :LOL: :LOL:
            Trevor
            Trevor
            XBOX 360 CARD
            • Brewer
              • Feb 2002
              • 14
              Dick
              My opinion is base on pcs that are useing full 98 then they install the me upgrade then try to install XP and it dont work or there trying to put it on 750 processer or less then have problem with it locking up and the bs you have to go threw to install a cdburnner ....
              I run a dual boot system as well with ME and win2000 as well but i have a hard drive for each operating system...All i was saying is that XP was made for new pc and to upgrade a old pc causes a lot of conflict...Kevin
              Kevin A Brewer
              Kevin A Brewer
              • Bing Fung
                • 6523
                Fair enough Kevin, however to say XP is summarrily crap based on just those issues, does not make it factual.
                Whenever I install a new OS, I will start from a freshly formatted HD, ALWAYS. I know that it is not always feasible for everyone, however you are only asking for problems by not doing otherwise. In that respect you may be correct that XP is not the best choice to install over another OS, but that doesn't mean it's a crap OS with all finality.
                Cheers
                BTW, it's Bing, not Dick Unless of course you were insinuating something else... lol
                Bing
                Bing
                • SiliGoose
                  • 941
                  LOL!!
                  I have a request for an XP tweak:
                  How do I get rid of those annoying message bubbles that pop up all over the place? For example, after installing new software these bubbles pop up every time you press the Start button. They obscure the shut-down options.
                  If I could get rid of those I'd be a happy camper.
                  Brewer,
                  Try a clean install. That way, any issues that arise are either your fault or bad hardware.
                  -Sili
                  www.campmurphy.net
                  • Brewer
                    • Feb 2002
                    • 14
                    Bing
                    Sorry about the name nothing ment by it just took the wrong name off your post.i do agree with you crap may have been to strong of a word .. But the last 5 years microsoft have gave us 3 new os and 2 nt os when are they going to perfect one product and not try to make people move to a new one and make more money like the xp plus for the home edition i ,i got one for 98 the with ME they made plus part of the os .Then to make you buy it all over with XP .Id rather buy updates for whats working for me right now then buy another os ...Kevin
                    Kevin A Brewer
                    Kevin A Brewer
                    • Jariten
                      • Jun 2000
                      • 271
                      Uh :roll:
                      Installed on a Celeron533 with 128MegRam No problems
                      Installed on a Dual AMD 1800XP ..no problems...
                      Installed on a AMD K6 with 256Meg ram Laptop (SOny VAio)
                      No problems
                      Installed on 650Mhz Durons machines (4 of them) no problems...
                      Where is the problem?
                      WinXP is very stable win2k is nice too..
                      Humm hints and tips....
                      Anyone checked www.techimo.com
                      • Bing Fung
                        • 6523
                        Kevin, no problem at all. I thought it was funny :LOL:
                        I agree, that plus jazz should be part of the original OS, not some further money grab. I have plus for both XP and 98, it certainly is not worth the $55 asking price.
                        Bing
                        Bing
                        • Jeremy Santos
                          • 154
                          I think XP is the most stable OS I have used, but you do need a fairly powerful PC to run it with all of the features on. If you are having problems with drivers, or can't find any for XP, it is usually a safe bet that you can use W2K drivers.
                          I don't know if W2K had this feature, but for XP you don't even have to go through the "start" button to shut down your machine. With XP, you can now just hit your power button on your tower case and it will shut down for you. And I can definitely say that XP starts up and shuts down so much faster than W2K.
                          Jeremy Santos
                          My Software
                          Santos Theater
                          Play It Loud, Play It Clean!!!!!
                          Jeremy Santos
                          My Software
                          Santos Theater
                            • 16478
                            I have XP running on my Celeron 950 and Celeron 450 machines and both are running 100 percent stable. The 450 machine was an upgrade from 98SE while the 950 machine was an upgrade from win2K...both have been rock solid. Like Bing mentioned above there are so many useful features in XP that its really a big step forward from the users point of view and it finally gives us the driver support that 98 had only with NT's stability. Calling XP crap on machines that have had a questionable upgrade cycle isn't justified IMO.
                            • Brewer
                              • Feb 2002
                              • 14
                              Well what may work for you dose not work for everyone...I own my own PC doctor Co. I work with people who use there pc for home use.Ever Since XP has came out most of my calls lately have came from people who install XP Home Edition then there pc locks up or wont start up or shut down.All of the problems that iv list in the above post have been the main problem.You can never base what works for you will for everyone else there are to meny factors to figure in.Im most of the cases iv repalced the processer and mother board and ofcorse more ram and it works fine..and i only did that after i reformatted there hard drive and try reinstalling the os and it did not work for me......
                              Kevin A Brewer
                              Kevin A Brewer
                              • Jeremy Santos
                                • 154
                                So you have had most of your problems with the "Home Edition"? I am using the corporate version and I am now wondering if that could be the difference. I know Andrew is using the corporate version as well.
                                Jeremy Santos
                                My Software
                                Santos Theater
                                Jeremy Santos
                                My Software
                                Santos Theater
                                • Brewer
                                  • Feb 2002
                                  • 14
                                  yes only the Home edition....... thats what i do is go to the clients home ..most my bus is based around Dumb rich people who know nothing more about PC then AOL.but the got aol they know everything ...lol I should not make too much fun thats how i make my bread and butter...and the house calls to the nice looking ladies is not bad either, better when they forget your comeing ....lol
                                  Kevin A Brewer
                                  Kevin A Brewer
                                    • 27460
                                    LOL Kevin.
                                    Bing, don't be a dick. haha.
                                    Well, my XP is on my laptop, and for now, that's the only place I will have it. Sure, it's novel and new, but I am not convinced it's the ticket over W2K. However, I do have the Home version, not the corporate version...
                                    Lex
                                    • Bing Fung
                                      • 6523
                                      Dick-Will?? :LOL: :P :LOL:
                                      Bing
                                      Bing
                                      • Chip
                                        • Aug 2001
                                        • 232
                                        I have an XP question.... My buddy just installed it on his 450 PII Gateway box. How do you "Find Files" on XP? I know it's a dumb question, lol but, i haven't sat down with it at all yet.
                                        Chip
                                        Chip Engle
                                        "Concrete ain't a spectator sport"
                                        <a href="http://www.htguide.com/bilder/index.cfm?fuseaction=arkivbilder&userid=0&selected userid=336" target="_blank">My HT
                                        Chip Engle
                                        My HT
                                          • 16172
                                          Pretty much the same way as for 98, 2K, etc.
                                          By menus, START, FIND, FIND Files
                                          The Find Files folder will come up, which has a lot of options and sub tasks in the pane on the left.
                                          (now, I'm running WINSTEP on top of XP, so I don't have all the XP UI START menu features, but most of the menu menu is preserved; but then I do have four windows systems I have to do "work" work on, two running NT, two running XP, which in most matters behave identically on a UI basis) (that is convenience, since it adds a lot of functionality to NT's often austere behavior. See below ).
                                          Re stability, I have to concur with Bing. I'm running XP on four systems right now (two are still 98SE; an audio test computer, and the bedroom gaming rig); XP is VERY tunable regarding OS resources and with little effort can be made to run quite nicely on a 450 MHz Celeron; the key is having 256 MB of RAM or more. 98 hardly knows what to do with more RAM; not the case with XP.
                                          Driver support is MUCH better in XP; while WIN2k shipped without driver support for most current HP Inkjet printers (and HP didn't have the drivers, either!), XP had support built in for my HP855, HP1000, and HP990. In fact, all you have to do to install a printer is plug it in and boot up. For me, in 100% of cases so far, XP detected the printer and installed the drivers automatically.
                                          Disclosure:
                                          Conflict of interest statement: I was an XP beta tester, so I'm probably not exactly unbiased, having "grown up with it" through an evolutionary process. But, in my opinion, it is by far the MOST complete OS Micro$oft has ever shipped. And for me, it has been more reliable and stable than WIN2K, which, usually struck me as being an incomplete and unfinished melding of NT and 98. Which it was.
                                          Cheers.
                                          Last edited by theSven; 15 December 2024, 13:23 Sunday. Reason: Update image location
                                          • Bing Fung
                                            • 6523
                                            Jon, that's a nice looking desktop. Winstep allows you to set-up like that?
                                            Chip in the default XP, the search is in the left column of file explorer. It provides a little brown dog to help sniff out files. Apperently this dog cannot be removed unless you have something like the program Jon is using. I'm not sure if using classic desktop will disable him, however he doesn't really bother me as much as he may others
                                            Bing
                                            Bing
                                            • SiliGoose
                                              • 941
                                              Whoa! Is that the 'Dock' from OSX on your WinXP desktop?
                                              h:
                                              -Sili
                                              www.campmurphy.net
                                                • 16172
                                                Sure looks like it, doesn't it?
                                                I like this overall interface a lot; it's easy to access all kinds of functions. I have the start icon in the upper left; my "task bar" is the strip of translucent icons on the left, starting just under the start icon.
                                                This system is running XP. What weirds out our IS guys, is when they see my desktop or company laptop at work, running NT, and it looks just like this, too!
                                                There are a variety of "skins" available (for free) for Winstep; it comes with about a dozen and a half. I've used the NextStep clone also, but I think I like this one, "H20 Pro" the best. It's very customizable within a particular "skin", also. The clock is cool; you can sync it to an atomic clock standard (and set your PC time) with two clicks.
                                                Take a look at it here
                                                -Jon
                                                • Burke Strickland
                                                  • Sep 2001
                                                  • 3159
                                                  One XP tip -- if you have used Network Ice's "Black Ice Defender" (BID) as your personal firewall (with cable modem or DSL) DON'T use it with XP. Even though their site says the latest update is XP compatible, it is not -- unless you consider random, unannounced reboots every few minutes a sign of compatibility. :>)
                                                  A while after installing BID on my new computer which uses XP, I started experiencing the reboots, and it didn't seem tied to any particular application so at first i assumed maybe my hardware was starting to malfunction since I had left the PC running for several days. But looking around various software forums with Q/A about XP and BID, I discovered that other computer users had experienced the same problem when they installed BID, and that it stopped immediately when they uninstalled it.
                                                  So that is what I did, (uninstall BID) and sure enough, no more reboots (unless I inititate them). So will I wait for word from Network Ice on an update? No -- I need firewall protection, now so I'm looking at other options. But it sure is aggrevating for a vendor to assert that their product is compatible with an operating system only to discover that it truly isn't.
                                                  Burke
                                                  • Bing Fung
                                                    • 6523
                                                    Windows Tips Balloons
                                                    Here's how to get rid of them...
                                                    Click Start, Run then type regedit Browse to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVe rsionExplorerAdvanced and create a DWORD key named EnableBalloonTips. set the Value to 0. and reboot. That should take care of them.
                                                    Bing
                                                    Bing
                                                    • SiliGoose
                                                      • 941
                                                      Thanks Bing!
                                                      I saw that in MaximumPC last week...didn't think to post it here.
                                                      I'd rather not mess around with my registry. I've found that Microsoft's PowerToys for WinXP performs this task automatically. PowerToys is currently unavailable but a new version is coming soom.
                                                      -Sili
                                                      www.campmurphy.net
                                                      • Bing Fung
                                                        • 6523
                                                        That's good Tweak XP does it for you Sili. I have installed Teak xp, but did not notice the balloon delete feature Note that Tweak programs are just a registry hack in it's self that modifies the registry, only you don't know how or what it has modified.
                                                        Reg Edits are great, I like working in there, however one of these days I may get burned!! Always back up the registry before editing :P
                                                        Bing
                                                        Bing
                                                          • 16478
                                                          Thanks Bing for that hack i hate those silly things. Silly don't worry to much about hacking the registry just do a backup (export) it before you make any changes. If you want to get comfortable making keys etc but don't want to upset the stability of the machine use the HKEY>Current User area since it only affects settings for the person logged in and you can't screw up the OS in there
                                                          • Land Shark
                                                            • Mar 2002
                                                            Per Andrew's request...
                                                            www.winsupersite.com - Nice layout and easy to read directions on XP tips and tweaks
                                                            www.tipsdr.com - Kinda slow and not too pretty to look at, but some great tips
                                                            www.dougknox.com - Most tips and registry fixes are already in .VBS scripts for you to download
                                                            www.microsoft.com/windowsxp - I couldn't forget Microsoft's own contribution
                                                            Have fun.
                                                            Brian
                                                            • Land Shark
                                                              • Mar 2002
                                                              Burke,
                                                              I had the same type of problem with Black Ice in XP so until I get the update I'm using the free version of Zone Alarm.
                                                              Works like a charm and I even past the Sheilds Up test at www.grc.com. (Go to the Sheilds Up link and run both tests.)
                                                              Basically you want all your ports to show up with a "Stealth" reading.
                                                              I'm not sure about the home version but XP Pro comes with a built-in firewall that you will have to enable which you could also use.
                                                              Brian
                                                              • Jon
        • Mar 2002
        • 27
        I have a machine at work that's a Cyrix 6x86MX PR200+ (187mhz) with 128MB Ram, 6.4GB HDD, Windows XP. I wouldn't try to tell you it runs great or anything, but it does run acceptably. All I use it for is testing and logging onto servers, and to see how XP would run on it. But its actually not all that slow, really.... my 2 cents.
        • jpossum
        1066 tips and tricks
        by jpossum
        Has anyone on this forum ever listed some "tips and tricks" for using the 1066? I just got mine and have been playing around with it. I saw an older post that suggested pressing the Dolby Prologic 2 button when in Dolby Digital 5.1...voila!! Dolby Digial EX!!
        Any other nifty...
        10 March 2003, 22:59 Monday
        VBulletin Tips and tricks
        by Lex
        Post tips and tricks for the new forum software here. This stuff is a little complex, so if we talk about it, we may all become a little better with it.
        Maybe you just found out about a cool feature. Figured out how to do something that wasn't obvious, whatever, post it here.
        10 May 2004, 11:26 Monday
        Office tips that tricks...
        by Andrew Pratt
        Since we all likely use MS office daily how about posting some of those little tricks you've come across?
        To get us started here's two I use a lot...
        The first regards using Word to select collumns of text. To do this simply click where you'd like to begin selecting and...
        22 February 2003, 14:24 Saturday
        Record Cleaner Usage Tips?
        by David Meek
        I recently acquired a Nitty Gritty 1.5FI record cleaner.
        Do any of you use the Nitty Gritty's? If so, have you picked up any helpful hints about their use?
        One of the things I've come across in my readings is a suggestion to manually pre-clean an album BEFORE
        17 April 2003, 13:18 Thursday
        • KMD
        Any tips on polishing ?
        by KMD
        Not sure on what type of polish to use on my B&W speakers? Any hints.
        14 March 2004, 18:16 Sunday
