Oops?
  • SiliGoose
    • 941
    Oops?
    Hmm...I decided to play with my FSB overclock to see where my limits were.
    I had been running my 1.4 Tbird at 1.5 (10x150) just fine. I decided to lower the multiplier a bit and raise the FSB. When I got to 9.5x160 I got a BSOD before Win2K completed booting. No big deal...I'll just back off a bit and re-boot, right?
    No. I rebooted and got into the bios but it kept locking up before I could back off to stable settings. I decide to power down and step away for a while.
    I come back...power up and the monitor is no longer getting a signal. The system fans all spin and the drives spin but nothing on-screen.
    Could I have killed my Geforce 3 with this FSB OC?? That would explain why the system previously froze on the bios screen.
    I've got a GeForce 2 and an old TNT2 Ultra around here somewhere but my wife is gonna kill me if I fried my $350 GF3 (especially after killing my $170 Gigabyte GA-7VTX).
    Is it possible for a FSB OC to kill my video card?
    -Sili
    www.campmurphy.net
  • Trevor Schell
    • 10936
    You certainly live on the edge my young man.
    Better run before the wife gets you.
    Sorry I don't know what could be the problem but did want to pop in and poke some fun at you.
    I know I am bad.
    Good Luck,,hope you do get the problem fixed.
    When I hear of these type of things happening I tend to shy away trying anything in terms of playing around in the system.
    When it comes to fixing computer problems I would not be able to fight my way out of a paper bag.
    We need Super Bing to the rescue.
    Trevor
    My HomeTheater S.E.
    Sonically Enhanced
    C5
    Trevor
    XBOX 360 CARD
    • Bing Fung
      • 6523
      Sili,
      Try turning off the power at the back(main switch)and then switch it back on.
      Hold down the "Insert" key on your keyboard, and then press the power button.
      This will initiate Abit's Bios default, reset mode when you OC to a point of no boot.
      Give that a try first and we'll go from there.
      Also try resetting the CMOS.
      I have not heard of frying a card due to over clocking unless the AGP port is set to 1:1 with a high FSB. The newer boards have independant AGP's most times I think, and the KG7 most definitely does.
      Trev, super? Hardly LOL!
      Bing
      Bing
        • 16478
        well I once had a mobo short on me at the AGP slot when I was OCing so I guess anything is possible. That mobo was replaced under warrentee though So far with my Abit VH6II all I ever had to do if it wouldn't respond is flip the main power switch on the back of the tower and wait a few seconds...it always reset the bios back to default after that
          • 16176
          Most motherboards have a provision for a hardware reset of the BIOS, (via a jumper) which resets the BIOS parameters to default conservative values. I think that may be the only way for you to recover your system. Bing mentioned that among other suggestions, but that is probably really your only recourse.
          Good luck getting it going again.
          • SiliGoose
            • 941
            I'm back. Thanks guys. Like you all said, it was no big deal. A simple CMOS clear and I'm back at it. Whew!
            -Sili
            www.campmurphy.net
