Creative MP3+ problem
  • w8liftr
    • 85
    I get a power error when connecting the Creative MP3+ soundcard to any USB port on my Dell Inspiron 8600 laptop. Will a powered USB hub fix this problem? I figured I would get a faster response here than with Creative tech support. Thanks ahead of time. Tommy
    Probably not, according to Creative it should be able to work on any hub powered or not, so it should run perfectly fine off your laptop (if you are plugging it directly in).
    One thing to check is to make sure your bios is up to date (they are at A14 I see)...
    Other than that, it's got to be something else.
    • w8liftr
      • 85
      Thanks for the response. I flashed the new BIOS and got the same thing. I plugged the card in on my desktop with no problem. All other USB devices work when connected to my laptop, all do not need power. I may pick up a hub from Wally world since you can return anything there.
      • dyazdani
        • 7032
        Do you have any other devices plugged in?
        Danish
        • w8liftr
          • 85
          The powered hub fixed the problem. Thanks.
