Alright guys(and girls?), i am one of those people who like to play games, like to play them a lot, but i don't know all too much about computers, especially when it comes to indepth stuff and i'l probably end up buying a pre-build pc and we don't want that.
So, please help me out, by suggesting a computer (by parts) which would suit me good. I use it mostly for games and internet stuff, i multi task often but with a good proccessor/ram it won't be an issue for me. I want, hopefully, an affordable but still a gaming pc.
Now what i need, is 2 pc build ups, one should be somewhere around 1000$ and another at 2000$, if you can be bothered to come up with two.
Also, it would be nice if you would tell me why something is better then the other, because i won't be able to tell the difference and umm how new the parts are/how long should i wait for prices to go down before buying etc.
I am thinking about one of the Athalon 64 processors for a start, but do suggest different ones if better. Oh, and do tell, what stuff should i steer clear off (as in, it will get out of date soon).
Thanks.
Thanks.
Otherwise just get the fastest CPU you can afford. if it's a 3000+ great, if you can afford a faster one, even better :T I usually try to find the one that's the best price/performance. For example a 3000+ might me $150, a 3200+ $165 and a 3400+ $245. In that case the 3200+ is your biggest bang for the buck.
