HD signal is stretched on my TN50X81
  • Kootenay Dog
    I've been reading this forum for a while and have gained much more info from it - thanks to all. I got the courage and info from here to recently perform a "service menu" level calibration of my old (1999) Toshiba TN50X81 HD RPTV and now remember why i bought it; i hadn't realized how out of wack the picture had become over the years! What a difference - it's like a new TV!
    Anyway to my question: i just got a new cable box that provides me with a HD signal so that i can finally make use of that clear picture with TV instead of only DVDs. I have set all the options on the cable box to the correct settings (4:3 picture, 1080i output on the component video cables) but my TV is "stretching" the HD channel images vertically when it switches into HD mode - everyone is tall and skinny. (The CBS logo is oval instead of round, Drew Carry looks like he lost a lot of weight). This does not happen with my DVD player; all widescreen movies play properly. I cannot find any reference to a stretch mode to turn on or off in the manual for my TV.
    Any suggestions would be appreciated.
    KD
  • soundhound
    • Mar 2004
    • 816
    Depending on the calibration source you use there are some pretty intuitive settings regarding aspect ratio, size settings, etc...There are a couple of peeps in this forum who I am sure know the answer off the top of their heads, your'e set-up disc should should get you going in the right direction until they respond. Avia for certain has samples, with settings, and if you dont see the correct pattern, they will tell you how to correct it. Bob
      Twin Moderator Emeritus
      • 16706
      It might be the signal your HD STB is sending and not the TV have you checked it's different output options?
        KD, are you using the same inputs for all signals to the RPTV? Ie. is your receiver/pre-pro also your video switcher? Or, do you have the DVD and HD signals running into separate inputs? That info will help us on where to look next.
        • Kootenay Dog
          After a couple of hints and a few days searching, i found the solution. I should have saved the thread i found the info on so i could thank the right person; i am using seperate component video inputs for the HDTV box and the DVD input. I didn't realize that this TV "remembers" seperate calibration settings for 1080i vs everything else (480i/p). So a complete re-convergance of the RGB guns when receiving a 1080i signal - compressssing the raster to the correct wide-scren ratio - was required.
          1 - went into service mode
          2 - hit 7 to bring up the convergance grid (Not using 'mute')
          3 - press 7 to exit convergance mode without clearing the grid
          4 - adjust the 'HIT' parameter to compress the raster to 16:9
          (This MAJORLY messes up the convergance)
          5 - measure / use strings to grid out the proper spacing
          6 - spend the time to do a accurate major re-convergance of the RGB guns
          7 - forget to save the settings before exiting
          8 - swear a lot
          9 - repeat step 6
          10 - this time save the settings
          11 - have a well deserved beer while enjoying awesome HDTV.
          12 - since you are mostly set up, do a complete re-convergance of the 4:3 picture settings as well.
          As i found out, this TV saves seperate convergance settings for 1080i inputs and the rest.
          Thanks.
          KD
            • 16706
            :rofl: I like 7 and 8 :rofl: Glad you got it working :T
            • markandjenn
              I have this same TV and this issue has been bothering me since I received my HD cable box 6 months ago.
              I have a few questions:
              1 - How does one go into service mode?
              2 - I am running my DVD player and 2 TiVo through my receiver and into the HD ColorStream 1 input. I have my HD cable box going into my HD ColorStream 2 input. Will I be able to go through the steps outlined here on the HD 2 input without affecting the HD 1 input and the other Video inouts on the TV or will changing these settings affect all inputs?
                • 16706
                I wouldn't reccomend going in to the "service mode" unless you're a professional with the appopriate calibration equipment (spectrum analyzer) or at the very least REALLY know what you're doing. If you want the set calibrated beyond the user controls with DVE or AVIA I suggest getting a professional ISF tech to calibrate it for you. Worth the money IMO
                From the above post it sounds like your set will save different settings for the different signal types. To be sure, just make sure you right down all your current setting before changing them, in case you need to change them back
                • Jeff Kowerchuk
                  Toshiba 56H80: A Complete Review Including Calibration
                  by Jeff Kowerchuk
                  Well, I finally sealed up the calibration on my 56H80 and thought I would share my results. What follows is a review of the TV itself and the results of the calibration.
                  As many are aware, the 56H80 is the latest model of Toshiba's 56" 16x9 set. After suffering at the hands of downconversion...
                  30 April 2001, 21:02 Monday
                • newguy987
                  Crossover settings
                  by newguy987
                  This could be a noobie question, however I'm going to ask it anyways. There seems to be a little bit of confusion when it comes to Ideal crossover settings. I Understand that when you select "large" for speaker size, that the speaker receives the full signal(20htz-20khz), and that when you...
                  07 January 2009, 15:34 Wednesday
                • jonia
                  Multichannel sound calibration
                  by jonia
                  Hello!
                  I need help from someone who really know how to set up a multichannel system...
                  I have used a sound pressure meter to adjust the soundpressure from all my speakers based on the noise generation in both my dvd player (when using 7.1 channel) and the noise generation...
                  29 April 2005, 00:57 Friday
                • we87
                  Mitsubishi 62" DLP WD-62525 Calibration - HELP
                  by we87
                  Im not 100% sure if this is the correct place to post this kind of question, so if its not please forgive me as I am a little new to these forums
                  I just purchased a Mitsubishi 62" DLP WD-62525 Television yesterday. My problem is the TV is a little "off" and the geometry...
                  17 January 2005, 14:53 Monday
                • Chris CRt
                  DPLIIx Settings and Room Sizes - Just Checking!
                  by Chris CRt
                  Hello!
                  I was just curious to see what you all are doing in the setup menu for Dolby Pro Logic IIx and what size your room might be. I've been playing with the settings for a little bit now and am starting to find how each works (good and bad) with the signal.
                  I can definitely...
                  21 March 2005, 22:28 Monday
