Need help on projector Switching off after 2 minutes
  • stereoharold
    Hi!
    I was wondering.. I have this old Zenith projector (model pv855p) that i got at home, and everything used to work fine with it. Recently, whenever i turned it on, it would shut off after 2 minutes of operation(as soon as it heats up a bit).
    I know electronics a bit, but not enought to figure it out. The image is fine, then poof - everything turns off. I checked the wires, and looked inside for burnt parts, but everything seems fine.
    I'm pretty sure it's just this one little capacitor that fails after a little heat..- it's so frustrating to have it there and not being able to use it !!!
    If anybody knows what i should do with it, please help me!
    Thanks a lot - Harold
  • George Bellefontaine
    • Jan 2001
    • 7636
    Harold, what kind of projector is it ? Crt, Lcd, Dlp ? If it's one of the latter two, then the PJ uses a lamp and there is probably an air filter involved. When the air filter gets dirty the PJ will overheat, and may even damage the lcd or dmd panels. Newer PJs have warning messages or blinking colored lights to tell you what the problem is. Shutting down automatically is usually the Pj's way of protecting itself. Try cleaning the air filter, or maybe even replacing it if it is badly clogged with dirt and dust. Any projector with air filters need to be vacuumed at least once a month.
    Hope this helps.
    My Homepage!
    • stereoharold
      Cleaning up the filters
      Thanks for the reply.. However, the projector i have does not seem to have any fan, or air filter.. (at least not that i know of..) I attached some pictures.. maybe that can help..
      It seems it shuts down because voltage seems to low.. that's my theory anyways.. but if anybody has any idea..
      Thanks again
        • 16202
        I used to have one of these. Actually, it was the Heathkit version, so actually, I should say I built one of these! In the same year that one was manufactured in Mexico.
        Built two if you count the work I had to do to get ThomasW's running...
        There is a cap which tends to go out in the power supply; I had that problem about a year into owning it. I believe it was one of the main electrolytic caps. Unfortunately, getting Zenith repair or calibration info isn't very easy; in the old days Zenith had an extensive dealer and repair network, and they were pretty good about getting stuff fixed. You might try the Zenith web site to find a local dealer, and see if you can get service or a manual.
        Mine is happily running at a friend of ThomasW's somewhere outside Denver...
        ~Jon
        • PMazz
          Notch filter for RD50 help
          by PMazz
          Calling all crossover gurus.....
          Try as I might, I can't seem to improve the notch filter on the RD50. B&G suggests a parallel notch filter with the following values: L=.05mH, C=20uF and R=8ohms.
          Problem is I still have a sizeable hump in the FR around 5K. I have tried...
          21 July 2003, 16:05 Monday
          Widescreen Review Magazine article on Sony HS-10
          For those who were asking, here's a "hard" copy of the review. This PJ is one that I've been looking at for a while, and finding good stuff.
          Sony VPL-HS10 Video Projector
          Champagne Video On A Lemonade Budget
          By Greg Rogers
          29 January 2003, 05:14 Wednesday
        • b_force
          Active controlled BR-system
          by b_force
          Introduction
          Sometimes you want to use your favourite driver or have to use a specific driver in a design, but unfortunately the BR pipe is way to long.
          You can use a smaller pipe diameter, however that limits the max SPL (because of the air velocity) and would be a sin for a driver with...
          16 June 2010, 11:07 Wednesday
        • efarstad
          HT & Air Flow Problem *Fix*
          by efarstad
          You all may remember how my HT room has a register but not a fresh air intake...and how I discussed how to keep the room at a decent temperature especially given the extra heat our new projector throws off. Well, I could just crack the door, the window, etc...but I still wanted to do something...so...
          11 September 2003, 11:16 Thursday
        • efarstad
          Air Vent/Return
          by efarstad
          Hey Gang...many of you have witnessed my theater construction and I greatly appreciate all your support, feedback, and comments....so in that light I ask for your help once more.
          I have a heat register that brings fresh air into the theater via a duct in the ceiling, but do not have a...
          29 July 2003, 12:34 Tuesday
