i have a 42? that i want to wall mount. viewing distance is ~10'. which would you recommend? (frugaphile) . thx.
which lcd wall bracket ?
by ht_addictIf you had to choose between a Paradigm Servo-15 and a 37-42" LCD which one would you get first? The upgrade bug has hit and I've goto decided between replacing my 47" RPTV with a LCD or my PW-2100 with a Servo-15. Can't get both at the same time though it would be nice.-
by MitchellThis is probably a worn out topic but I can really use some advice.
We live in an apt in NY and want to put in a small HT system is a room that is 14x8. We would have a couch on one end and want to mount a flat panel TV on th opposite wall. LCD or Plasma is the only question.
The LCD we...-
Channel: Select Manufacturer Clubs
by SayersWebThe L300 is a brand new 16:9 LCD budget front projector. Price comes in under $2,000 and often includes a free Panny DVD player.
What makes this projector special?
To overcome the "Screen Door" effect (where pixels are spaced far apart and have black lines in... -
Introducing the extraordinary new 17-inch DeLL W1700 17" LCD TV, a multi-functional, wide screen high definition-capable television (HDTV) that enhances Dell's already impressive array of digital entertainment products. The W1700 17" LCD TV has all of the features... -
by CliveG'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...-
- Loading...
- No more items.
