Differences Between 1066 And 1055 (as pre/pro)?
  • Dave Simpson
    • Jan 2003
    Hey gang, I'm a new guy here; perhaps you might answer a few questions I've got before I drop my dough on some new gear. Specifically, are there any real differences between the 1055 (used as pre-pro only) and the 1066? I really would prefer to not buy another reciever, but Rotel doesn't make it easy, now do they? I don't look forward to spending money on amps I'll never use (already own Parasound 1205A and 1000A) and I really like the idea of true separtates. On the other hand, the 1055 is signifigantly cheaper here in Toronto, and has a tuner, to boot! My impression is that the preamp section of the 1055 is identical to the 1066. Correct, or not? So what of it, fellas? Opinions? Advice? I'm all ears!
    Cheers!
    DS.
  • sndtowne
    • Jan 2003
    • 105
    Dave,
    You are correct. The preamp features on the RSX-1055 are identical to the RSP-1066. The removal of the tuner and power amp section gives the RSP-1066 a 0.05% lower distortion rating (0.04 vs. 0.09) and a 2 to 3 dB better signal to noise ratio. Are these big differences - no, but it depends of how much of a purist you are.
    The truth is - you can't go wrong with either of these units.
    (For the purists out there, I know 3 dB is a big change percentage wise, but if the noise is already inaudible it cannot be made "MORE" inaudible. But for some, there is a Phycological benefit of knowing the noise floor is lower even if the difference is inaudible.)
    Bruce
    Bruce
      • 16478
      I agree 100 percent with bruce here. I owned the 1066 and switched to the 1055 and didn't notice a difference. The nice thing about the 1055 is that you can use its internal amps to power the rear surrounds in EX/ES mode which would allow you to use a 5 channel amp with the 1055 to get into 6.1 or 7.1. If you already have 7 channels if your mains are bi ampable use four channels for your mains and use the 1055's amps for the rears...bi amping can make a pretty big difference on some speakers and you won't likely ever notice the lower power being used for the rear effects speakers.
      • SayersWeb
        • Dec 2002
        • 82
        Arghh! $#(^*@#$%
        Sayer - Musical Creations and Home Page
        • efarstad
          • Jun 2001
          • 2230
          I visited my local Rotel dealer today and we chatted for a bit about the 1066, 1055 and the new 1098.
          He said for HT the 1055 and 1066 would be pretty much about the same. BUT for 2-channel the 1066 is a step above with better circuitry, etc. He said Rotel used slightly different and better components inside the 1066 for the music purist that are not in the 1055. Other differences were due to the 1055 creating more heat then the 1066, which equates to differnt internal components as well.
          So depending on what your usage is, whether HT or music, this may come into play.
          Though it also depends on how could your cables are and how sensitive your speakers are and ESPECIALLY your ears to change!!!
          Hope that throws something into the mix...
          E
          The Norwegian A/V Nut!
          E-Cinema
          E-Cinema
          • sndtowne
            • Jan 2003
            • 105
            Erik - I believe your dealer is sincere when he says this, but it is not accurate.
            Bruce
            • mml7
              • Jun 2002
              • 31
              Dave,
              Being the purist that I am, I'm strongly against a particular component having extra circuitry that I neither need nor want. While you won't be using the amplifiers in the 1055, the fact is that they're there, and unless they are totally isolated electrically have some affect on the overall sound. The same applies for the tuner; If I really want a tuner, I'll buy one - it'll preserve the sonic qualities of the preamp, but will also offer better sound/performance than the built in one.
              Again, I'm more of a purist, and wouldn't consider purchasing a receiver for anything except a second system. In anycase, really try to audition them both side-by-side and let your own ears be the judge.
              mike
              • sndtowne
                • Jan 2003
                • 105
                Dave,
                I agree with Mike. Andrew has said he has owned an RSP-1066 and now uses an RSX-1055 and cannot tell any difference. I too am unable to tell any difference. But... you might be able to. It would be a good idea to ask your dealer to connect both (not at the same time of course) to a power amp for you to audition. That way, you can have assurance as to which route is best for you.
                (Also, from your post, it sounds like you might like to have a tuner so that too might be a consideration.)
                Bruce
                Bruce
                • spacey
                  Rotel 1065 v. 1055 v. 1066
                  by spacey
                  All,
                  I am seriously considering the purchase of a Rotel 1065 receiver, and have been reviewing the posts on this forum. I note that there is a lot of info on the 1066+Amp, and 1055, but relatively little on the 1065. I will be using it with B&W N804, N805, and HTM2.
                  07 February 2003, 17:32 Friday
                • Gary Stevens
                  Q: S/N on 1055 vs 1066 ?
                  by Gary Stevens
                  Greetings!
                  I've been pondering the tradeoff between a 1066 and a 1055 and I am wondering if anyone has any info or experiences with the relative signal to noise ratios.
                  I believe that Andrew noted in another thread (on another forum?) that Rotel stated the S/N ratio of...
                  26 September 2002, 11:34 Thursday
                  RSP-1066 / RSX-1055 etc. Frequently Asked Questions (FAQ)
                  by Andrew Pratt
                  Rotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
                  1. How do I know what firmware is installed on my processor?
                  Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...
                  15 April 2003, 14:08 Tuesday
                • BleakShore
                  Stick to RSX1065 or go to 1055/1075 separates?
                  by BleakShore
                  I guess I'd like to hear/learn advices/experiences from those who have gone this route.
                  That is, stick with the RSX1066, or exchange it for the RSX1055/RMB1075 combo? I bought it from Myer-Emco so I can do the exchange with no penalty.
                  The reason I'm contemplating this...
                  17 October 2003, 13:27 Friday
                • Spectre
                  RSP-1066 and noise from LS
                  by Spectre
                  Hi all,
                  I am a new owner of the Rotel RSP-1066 and the RMB-1075 combi.
                  All in all I am very pleased with this combi as it is a significant improvement over my old Yamaha AZ-2 amplifier.
                  However, I noticed a little annoiance that is not noticeable under normal...
                  02 September 2004, 03:51 Thursday
