An RDV-1050E progresssive problem
  • Mouton
    • 8
    I have had my RDV-1050E for many years now and as my old TV only allowed me to use RGB-SCART I have done so.
    I recently purchased an HDTV and connected the Rotel via component cables. It works with interlaced but not with progressive. I followed the manual's settings for selecting progressive output. The progressive LED indicator light comes on and the TV shows the signal is indeed 575P or 480P depending on whether I set PAL or NTSC. Picture, however is black, but intermittently the film appears for an fraction of a second.
    I know the TV and cabels are OK as I tested both 480P and 575P using the same cabels and TV input with an older DVD-player. The Rotel is working as it should when I select interlaced. I am leaning towards the fact that my unit may be defective, but ask anyway as I might have overlooked something.
    It may be a bit late now as it is an old model, but is there a firmware upgrade that may help me or is service the only option? It may also be a defect right from the start as it is the first time I tested the component connectors.
    Another question:
    What is the difference between "Film" and "Video" in the Choice settings?
    Thanks for your time!
  • Karma
    Progressive Vs. Interlaced Scanning
    by Karma
    HI All,
    We all grew up with interlaced video. Even now, most TV's use interlaced horizontal scanning systems. It is the system I am familiar with. A few years ago I started hearing about progressive scanning monitors mostly related to computers. I understood that the advantage to progressive...
    05 June 2006, 12:23 Monday
  • rlabarge
    Line Doublers & 480P(30) Content
    by rlabarge
    I have been trying to push the DVD-Video format to its limit as far as video quality is concerned. Many people know that DVD-Video supports progressive scan video from film - called 480P(24). However DVD also supports progressive scan video at a higher frame rate - called 480P(30).
    I...
    19 April 2002, 09:52 Friday
    Philips 32PT830H
    by aud19
    So our office got together and got this Philips 32PT830H for a coworker for a house warming / help out (husband lost job and their TV blew up) gift.
    It came to just under $700 Canadian, after taxes through our supplier :E A price I can still hardly believe!...
    08 July 2005, 19:06 Friday
  • Henk
    RSP 1098 and progressive scan dvd/dvd audio players
    by Henk
    The RSP 1098 TFT screen displays no video unless a usable signal is passed through the composite video connection. However, as pointed out in the RSP 1098 manual not all dvd players, set in progressive mode, output a usable composite video signal. This is true also for dvd players that play dvd audio....
    21 November 2003, 05:55 Friday
  • McLovin
    1068: Problem switching between progressive inputs
    by McLovin
    G'day,
    I am having an issue with my RSP-1068 and progressive scan inputs.
    I have three video input devices hooked up to the 1068: a set-top box, a DVD player, and an Xbox (on V1, V2, and V3 inputs respectively). The 1068 is then connected to my TV (a Sony LCD). All inputs...
    16 June 2008, 08:45 Monday
