Rotel RB-1070 problem?
  • specialized
    • Apr 2008
    • 332
    Hi there.. I got last RB-1070 they had on stock. Im using for rears (for my 805S)
    After listening session when i turn off after 2-3 seconds there is sound on the speakers like emptying of capacitors of RB-1070 (Something like fiuuuuuuuuuuu). If i just turn on and turn off there is no such sound.. Only if i played a little bit.. While it's playing sound is ok..
    Is this a sign that some of capacitors are gone? Should i return the unit?
    Or is not a problem to worry about? I tried connecting to different speakers and the same thing happened. Also i tried to different power cords and definitly it's RB-1070 not something else..
    Greetings
    Darko
    p.s. I have something like that (but more short and more silent ), from one of the RB-1080, and after a while the sound gone.. I keeped the RB-1070 turned on for few days, but the same. .Nothing changed
  • miner
    • 900
    First of all, the amp does not power down completely until a few seconds after turning off - so sounds normal to me what you are experiencing. Yu need to be sure your volume on the preamp is turned all te way down when you power off. Is the amp connected to the preamp via a 12V trigger?
    • specialized
      • Apr 2008
      • 332
      No. Its not.. And also Im turning off preamp first.. When i turn off amp last same thing happened
      Darko
      p.s. Seem like capacitors are emptying.. Becouse When i dont listne music just turn on and then turn off after few minutes, nothing happenes.. This sound i'm getting only if i have listen few minutes
      • Glen B
        • 1106
        I believe the RB-1070 and RB-1080, like some other Rotel models, have no output relays, so the speakers are always connected to the amp output stage. If you cut power to the amp while music is playing, the sound should continue for a few seconds and become increasingly distorted as it dies down.
        I think what you are hearing is indeed the sound of the power supply caps discharging, a normal occurence and nothing to worry about. When you listen to the amp for several minutes versus just letting it idle momentarily, IMO its going to be hotter and behave a little differently when you power down.
        • specialized
          • Apr 2008
          • 332
          It's strange that when i turn off after beeing used for sound after i listened and stopped the sound, the sound that im getting is like wistle and starting 5-10 seconds after i turned off .. If i wait and dont turn off imediatly after i stopped the sound and leave the amp turned on for maybe 30 minutes, when i turn off after nothing happened.. I have three more Rotel RB-1080 and nothing happened like this.. Also i had older Rotel then RB-1070 (his precessor), also nothing happened..
          Darko
          p.s. I tried connecting to different power plug and also i changed the surge protectors i had. Now im using Belking vs MGE before
          • Glen B
            • 1106
            Darko,
            I've discussed your issue with several techs and all concur there is no fix to the amp that will eliminate the noise. What you're likely hearing is some oscillation as power to the rails drop off. If you find the noise intolerable, the best solution would be to install an output relay, if there is room in the amp.
            A suitably rated DPST (double pole single throw) relay, with power for its coil taken either from the transformer secondary, ahead of the diode bridge, or AC mains, right after the power switch, would be easy to implement. As soon as the amp is turned off, the relay will drop out, disconnecting the speakers. The relay contacts would be wired in series with the "+" side of each channel's output. Any competent technician should be able to install an output relay for you, as long as there is space in the chassis.
            Glen
            • specialized
              • Apr 2008
              • 332
              Darko,
              Glen
              It's not that noise is intolerable.. I can live with that as soon as there is no more damage to the amp or speakers or preamp..
              Do u suggest that except the noise i listen there is no other negative things that would produce in the future some more serious problems?
              Darko
              • Glen B
                • 1106
                The problem is in the circuit design. There is no damage risk, its just a nuisance issue. That is part of the reason why manufacturers include output relays (to mute turn on/turn off noises). It would have cost Rotel less than $10 worth of parts to include an output relay.
                • specialized
                  • Apr 2008
                  • 332
                  U want to tell me that all Rotel RB-1070 have this? It's strange that i have three more RB-1080 and non of them have this.. Also i had a chance to try the model before RB-1070, also no something like this..
                  Darko
                  • Glen B
                    • 1106
                    I did not say that ALL Rotel have this problem. Amplifier operation/behavior depends on the design. The tolerance of parts (resistors, caps, transistors) vary and values drift over time, values change with temperature, and the circuit designer has to take all of these factors into consideration. When you power down your amp, as the caps discharge and the rails lose power, parts of the circuit are probably maintaining bias while some parts are not. This is likely causing a slight oscillation, which you are hearing. This is a shortcoming in the circuit design that probably manifests itself only rarely because of a combination of factors.
                    If the amp had an output relay that disconnected the speakers upon turnoff, you would not be aware of any noise, and we would not be having this discussion. You can't use other models as a reference since they are of slightly different circuit design and have output relays. Maybe some other amps do have this oscillation but you just don't know it because the speakers disconnect when the units are powered down.
                    • specialized
                      • Apr 2008
                      • 332
                      Thanks Glen for u'r help.
                      Greetings
                      Darko
                        Cheap way to power an amp on/off
                        by Andrew Pratt
                        I have two power amps one has a built in power off and on toggle that my pre amp controls but my Class A Musical Fidelity amp does not. Given the Class A design this amp is sucking a lot of current from the wall and I wished I had a way to turn it on and off without resorting to an X10 switch or some...
                        17 February 2002, 19:15 Sunday
                      • Eric_C
                        Turn off Overscan: Samsung 87W TV's
                        by Eric_C
                        I have a 61" Samsung 87W series 1080p DLP and the overscan drives me nuts.
                        I found where I can turn it off temporarily until I turn it off and back on but I want to turn it off permanently.
                        One of the internet tuners offered to do this as part of a package for $500...
                        17 December 2006, 15:54 Sunday
                      • dedepas8
                        Q: Do you turn your uint off?
                        by dedepas8
                        Question: Do you switch your Rotel unit off completely or leave it on standby after use?
                        The reason I ask is that there are relies clicking when you turn on/off the units like 1098,1095,1080. And with rely they have limited lifetime and will worn out eventually. Should I leave the unit...
                        07 September 2004, 21:23 Tuesday
                      • MikeZ06
                        Turning off 1050 remote?
                        by MikeZ06
                        Hey guys,
                        Just got some Rotel gear...awesome stuff. Programmed the remote for the 1066 without any problems.
                        Went to shut everything off...no problems.
                        Noticed the LCD on the 1050 remote was on....couldn't turn it off.
                        Power off doesn't turn the...
                        09 September 2003, 08:47 Tuesday
                      • Stockinv
                        Leave On or Turn Off
                        by Stockinv
                        A just installed a new HT with B&W speakers and McIntosh 500w amps.
                        I'm listening to music in the morning and perhaps in the early afternoon and then at night. I'm constantly turning the system on and off. Is this harmful?
                        Should I just leave it on all day and turn it off at night?...
                        30 July 2005, 14:01 Saturday
