My equipment consisted fo the follow before I added an amp.
RSX 1057, TV, Xbox 360 & DVD player. SPeakers were B&W 603 and a LCR600.
WHen I had this setup everything worked out fine, no buzzing. However once I added a Krell amp, I started to notice a buzzing noise from both the tweeter and midrage. What I discovered is that with each video output that is being used by the rotel receiver, the buzz get's louder and louder. EG. I removed the component out and hdmi out on the rsx1057. WHen I attached the component out and attached the other in (component in) on the TV, the buzz got louder. The same applied for HDMI. THe buzz was the same volume with the tv on and off. However If I completetly disconnected the TV from the wall outlet, the buzz was gone. Can someone help me out on what's causing the problem
