Is it possible to have different crossover seettings on the LFE/SUB? For 2 CH i have set the fronts to small and their HP-filter set to 60 hz and the sub (redirected bass) set to 60 hz. I'm very happy with these settings, but the problem is, when i'm listening to a 5.1 mix, the LFE channel get "chucked" at 60 hz, and in a DD 5.1 mix the LFE channel contains material from 20hz - 120 hz, so i won't hear the stuff over 60 hz.
It's not my biggest problem, but i do think a reicever for almost 3000 euro should be able to handle this correct, and maybe it can?
So i would like to have crossover for HT use at 80 hz and for 2 CH use at 60 hz is that possible? I have all the speaker set to small in both modes.
My sub is a REL Strata 5 and fronts are Dynaudio Focus
