I'm a newbie when it comes to Digital Coaxial Connections. I posed the following question to Rotel and got the following response. Was wondering your thoughts on the subject.
Thanks!
"I have a Rotel 1068 Pre/Pro and a 1055 Cd Player and was wondering how should I connect the two together. Should I use the Analog connection of the 1055 or the Digital connection? Is there a difference or pro/con for each?"
Response: "THE DAC’S IN THE 1068 ARE BETTER THAN THE DAC’S IN THE 1055. THE AUDIO SECTION OF THE 1068 IS BETTER TOO. I WOULD RECOMMEND USING THE DIGITAL CONNECTIONS BETWEEN THE 1068 AND 1055. USING THE DIGITAL CONNECTION ELIMINATES THE NEED FOR ANY ANALOG HOOK UPS."
Thanks!
