Power rating discrepancy in a Rotel RB-1092
  • musman
    • 57
    If you read the review of the RB-1092 on Rotels web site it states that the manufactures output power rating is 600wpc & that they got 635w out of it. Rotels specification is 500wpc. What's the deal?
    http://www.rotel.com/reviews/pdfs/po...News_Apr06.pdf
  • Blindamood
    • Sep 2003
    • 900
    I think the discrepency is pretty typical. I've read reviews of the RMB-1075 (rated by Rotel at 120W per channel) that have measured its true power at closer to 150-160W per. I believe it is more honest for a manufacturer to 'under-rate' its products, rather than the opposite.
    Maybe a good analogy would be the estimated mileage sticker on a new car...your mileage may vary in the real world (due to variance in build components, driving style, maintenance, etc.).
    Brad
    • musman
      • 57
      I see what you are saying but in the review they state that the 600 watt rating is the manufactures specification. If you look on Rotels site they are rated at 500 watts. Just makes me wonder what it really puts out.
      • Kevin D
        • 4601
        The 500 watt Rotel rating is with both channels driven. I imagine the 600 watt spec is with a single channel driven, something Rotel doesn't really need to 'market' on their lit.
        Kevin D.
        • DL86
          • 271
          Just referring to the rb-1090. It was measured that it gives out 410 watts per channel both channels driven and the maximum power consumption is 800 watts stated by rotel on the back of the amplifier, you are saying this is only for one channel driven? which makes it effectively 1600 watts power consumption when both channels are driven to their maximum?
          • Kevin D
            • 4601
            The discussion is just related to output watts. The review stated Rotel rated them for 600 watts (output), while all the lit states 500 watts.
            The power consumption rating is what you should see for most every listening scenario, but it isn't max consumption.
            Kevin D.
            • DL86
              • 271
              So that explains the reason why my fuse blew when I connected the 1090 and 1080 onto the same powerpoint. The moment I hit the switch on the 1090 the peak current required to switch the amplifier on exceeded the max current of the fuse thus blew it the 1080 was switched on too. Is this true that a high current is required to turn the amplifier on?
              Cheers, David
              • Kevin D
                • 4601
                Most likely yes. Without using high volume test tones, the peak current will usually be highest at turn-on.
                Kevin D.
                • sarsi
                  Help on RB1092
                  by sarsi
                  I would appreciate anyone that can share experience on RB1092. I recently added RB1092 to RSP1098, which now drive my front speakers and now the RMB1095 drive the rear and center speakers.
                  Both the amp are turn on and off via the +12v trigger from the RSP1098 but I noticed each time...
                  16 December 2006, 12:56 Saturday
                • Bluespower
                  Discrepancy in the published power consumption for the RMB-1095
                  by Bluespower
                  I was mapping out my power conditioner and noticed a discrepancy in the published power consumption ratings for the RMB-1095. The owners manual rates the amp at 800 watts. The spec sheet on Rotels web site lists the power at 1,200 watts. Any clue which is correct?
                  13 April 2006, 16:54 Thursday
                • ecthelion
                  looking for more opinions about rb1092
                  by ecthelion
                  im on the market for an amp for quiet a while reading a lot of opinions about diffrent amps help me narrowed my choice to few of them ..krell400xi,rb1092...those are my leaders...i drive klipsch rf 7 with maranzt8500(still)for almost 1.5 years time to move on i know about rb1090 and klipsch but fact...
                  01 November 2006, 12:49 Wednesday
                • style
                  RB1092 Rotel ICEpower
                  by style
                  Hallo,
                  I have a system Rsp1068+Rmb1075 in black.Speakers in black too.
                  (I have a paar of imaging (sorry for the quality)
                  I muss decide for a new Rotel Rb1092 (to drive in Bi wire the mains speakers)
                  Rb1092: in Black or bicolor???
                  I muss say to my Dealer...
                  06 March 2007, 06:06 Tuesday
                • style
                  B&W with Rotel Rb1092
                  by style
                  Hallo,
                  I have a Rotel system (rb1091 for center, rb1092 for mains 803s and another
                  rb1092 for rear 703.)
                  For rear in place 703 I think the 805 will be the better solution but the XT4
                  can be too a solution?
                  Plase reply.
                  Omar
                  20 June 2007, 04:47 Wednesday
