RSP-970 memory problem
  • NielsLu
    I have the following problem:
    When I'm setting-up my pre-processor the memory isn't working: when I have set the speaker settings (volume and delay) the sound is great, but when i'm changing source or turn off my pre-pro, every single setting is gone
    Could this be an empty battery or do you think this is something else?
    Greetings
    Niels Lukens
  • Kevin D
    • 4601
    It might be that a backup battery has failed, kind of like a CMOS battery on a computer. The newer units are hard written to an EEPROM and don't have a battery, but it's possible on an older unit like this.
    Wouldn't hurt to crack open the case and see if you see anything on the board that looks like a watch battery (possibly as big as a quarter). If not, a call to Rotel tech support should give you an answer.
    Kevin D.
    • KEN KAZ
      1068 loosing memory
      by KEN KAZ
      Helllo there
      I have had a 1068 for about 5 months.
      Once i zaped it with static; drug my feet on the carpet and touched the volume knob. It lost its memory. all settings gone. takes forever to get it back to how it was.
      the other day we had a huge hail storm....
      17 May 2005, 23:32 Tuesday
    • fgkblacklabel
      Buy eeprom and change myself RSX-1065
      by fgkblacklabel
      As mentioned in another thread I have a RSX-1065 with old FW 1.3. I would like to upgrade the eeprom so I can upgrade fw to 2.xx. Though I don“t want to pay like 300 usd to have this done by a dealer. It seems like a pretty easy task to change eeprom myself. Unless there is another...
      30 August 2011, 13:07 Tuesday
    • JoshK
      DIY Battery Power
      by JoshK
      OK, I'll bite.
      Interested to know Jon's take on battery power in the DIY realm. My own application involves power UcD400 modules off of two APS battery packs ($25/ea on surplus market) which have 4 12V7ah batteries in each and a battery charger. Together...
      23 August 2005, 11:06 Tuesday
    • kpodolski
      Battery powered phono pre-amp???
      by kpodolski
      I have a Cambridge 640P and had some questions regarding powering it via a battery instead of the wall wart. The pre-amp requires 12v .05a. Before wasting time and money building a battery pack I used my 12v motorcycle battery. When I power the unit up with the battery the power indicator lamp lights...
      31 January 2009, 23:15 Saturday
    • sg13
      Surge and Battery Backup
      by sg13
      As I just posted in the Audio forum, I'm new here. Been doing a lot of reading, but haven't come across my exact question.
      I've got the following equipment in my humble HT:
      Toshiba 36" CRT TV
      DirecTivo
      DirecTV Receiver
      Kenwood VR-507 Receiver (500W +...
      06 June 2004, 18:53 Sunday
