For a while now I have been using my Rotel 1055 receiver as a HT pre/processor for my L/C/R channels, feeding seperate Aragon/Marantz power amps.
I have decided to "seperate" my system. Will be using the Aragon to drive some maggies for music, and use the Rotel receiver to drive an all Pardigm HT system. Now have Studio 20v3s, will get the matching center/sides later.
So I have a 45' cable run between the Rotel and the L/C/R speakers, which will be partially in-wall/ceiling. Do ya think I will be ok with 12 gauge or should I go higher with a 14/4-wire (11 gauge) or 12/4-wire (9 gauge)? Thinking of something like Kimbers KWIK12s or similar CL rated cables.
Thanks, John
Thanks, John
