B&K 507 Crossover issues/subwoofer/low freq issues
  • eieio
    • Jun 2003
    i have a new 507 B&K receiver and have the following question regarding the low frequency crossover:
    in a 5.1 system, if you set all speakers to small, and set the crossover to 45 Hz, then in theory, everything below 45 goes to the sub, and everything above 45 goes to the various speakers. there are many people out there who believes that the ".1" channel (the LFE channel)'s information does not get "mixed in" and does not go to the main fronts.
    example: for the crossover to be at 45 Hz, then everything in the LFE channel from any DVDs from 45 Hz up to 80 Hz will be lost, according to many people. But i've even called B&K about this, and they seem to say, with a tone of confidence, that they are pretty sure that that is NOT happening with their receiver/processor. they say that the LFE above 45 Hz in the above scenario will actually get "mixed in" with all the rest of the info, and everything above 45 hz from the LFE will find its way into the front mains, since the front mains is responsible for everything above 45 hz.
    anyone knows more about this please?
    thanks!
  • PMazz
    • May 2001
    • 861
    Well, that's certainly not how it's supposed to happen. The whole idea of the small speaker setting is to relieve the speakers from the ultra low freqs. The LFE channel is supposed to be just that, another channel of information. Bass management is another story. Of course, the xover is not a brick wall filter. It's a 24 dB HP and a 6 or 12 dB LP, depending on the setting. Rule of thumb, BTW, is to use a xover point at least an octave above the LF reach of your speakers for good integration.
    BTW, the LFE channel has an upper range of 120 Hz, and that is a brick wall filter. Although there's rarely much info recorded to the LFE channel up that high.
    Pete
    Birth of a Media Center
    • BleakShore
      LFE over x-over freq discarded for 1066, 1065, & 1055?
      by BleakShore
      I'm told that the BM in the 1066, 1065, & 1055 discards the LFE above the crossover frequency. That is, if you set your speakers small, and chose to set the sub crossover freq at, say, 60 Hz, anything above 60 Hz in the LFE channel is simply discarded.
      Now, this doen't sound like...
      23 October 2003, 08:59 Thursday
    • Stiletto Pat
      AVR-507 Heat Issues
      by Stiletto Pat
      I'm new to this forum, and also a relatively new AVR-507 owner. Actually, I've just assembled a completely new system. So far, I love the sound, although the logic takes a bit of getting used to. Anyway, I've noted that the unit generates a fair amount of heat, especially when I'm enjoying music...
      17 May 2004, 21:27 Monday
    • therock
      LFE Or No LFE? I Need To Learn.
      by therock
      I have a listening problem with Bass levels fluctuating too much between listening applications and need some help info.
      See my audio equipment details in my signature.
      First the sub is a fantastic unit. Clean accurate tight bass.
      The problem is the bass right on one broadcast or...
      01 July 2006, 11:04 Saturday
    • br33zy
      Setup issues...
      by br33zy
      I am running into a little problem with my setup. I am new to a lot of this and I have been reading and searching for my answer but I can not find one. I hope one of you guys can help me out here.....
      I currently have a HK AVR235, Polk monitor center, front left and right, two cheapo...
      14 April 2005, 08:18 Thursday
    • Wadsbrau
      7100, LFE, and Subwoofer level, relationship?
      by Wadsbrau
      I am trying to wrap my head around LFE, and subwoofer levels and how they interact with the 7100. I completely understand what LFE is. However, I am not sure how the 7100 settings for Subwoofer level (in speaker setup menu) and the LFE level interact with the 7100. Subwoofer level generally sets...
      22 August 2006, 16:31 Tuesday
