B&W ASW2000 sub setup problems-HELP
  • Bobcatt
    • 4
    I have a wooden built-in entertainment center in my living room. The sub sits in the bottom middle cubby hole on a shelf about 4 inches off the floor. It has about 4 inches of space on each side, back and top and is sitting on it's feet without the spikes. The sub needs to remain in the cubby hole.
    On the music side it works and performs well, however on the movie side it sounds to me like it reverberates within the cabinet. I'm not sure if this caused the problem, but now its in the shop for a blown woofer. :cry:
    My questions are....
    1. Did the sub blow because of over heating and I need to vent better? I felt the air inside the cubby hole and it didn't feel unusually hot.
    2. Do I need some type of dampening material behind or under the sub to control the revirberation?
    3. Should I use the metal spikes or the rubber isolators on the feet of the sub?
    I appreciate any guidance that you can give me.
    Bobcatt
  • grit
    • 580
    Placing the sub inside furniture kinda goes against everything I've ever read. I also saw that you said there were no other options.
    I'd recommend using rubber isolators on the feet (perhaps spikes sitting on metal discs?). As for the cabinet itself, I'd say make sure the back of the cubby hole is removed.
    I seriously doubt your placement caused the problem, unless it's a ported sub AND the port was blocked. Perhaps someone with more knowledge could offer some insight?
    • RobP
      • 4747
      That sub in that hole may be acting as a semi-bandpass enclosure and causing more problems than you need. If you have to keep it in there, open the back of the cubby hole for ventilation and stuff the cavity with acoustic wool or fiberfill, you could use fiberglass but you dont want that stuff flying around a room.
      Robert P. 8)
      AKA "Soundgravy"
      • richh
        Center channel idea
        by richh
        I've got the dreaded "center channel needs to fit into a cubby hole in an entertainment center that we just bought" dilema. The space for the center channel is about 15" wide by 9" tall by 17" deep. The entertainment center is built like a bookcase so the cubby hole is more...
        12 December 2010, 18:33 Sunday
      • JimTW
        A somewhat technical question to setup of center channel (HTM2D)
        by JimTW
        We're building a custom wood center console for the Plasma TV and other
        A/V components. The center channel speaker, the HTM2D, will go into a
        cubby hole right underneath the Plasma TV. So, this means, the top,
        bottom, left and right, and back of the HTM2D will be wood and closed...
        24 April 2006, 12:50 Monday
      • kramskoi
        my Tumult...depressed at 22 Hz
        by kramskoi
        I would welcome any observations and tips on the following dilemma at 22 Hz:
        I've tried moving the sub up, down, backwards, forwards and every which way and the null remains. I've done manual sine wave sweeps with the same result. This sweep
        12 March 2006, 21:18 Sunday
      • AndrewM
        Need help with projector ideas.
        by AndrewM
        Well, I've made the first steps towards getting SAF on moving away from a RPTV and going to a bigger screen FPTV. Mostly by bring an old junky work projector home to try out, and we were both impressed by the picture this 5yr old 800x600 low contrast, low lumen projector put out onto a non-white wall...
        22 November 2002, 11:09 Friday
      • ttraynor
        DIY in a concrete cubby: thomasw and any others...
        by ttraynor
        i have a natural concrete enclosure under my waist high fireplace. Dimensions are 22"D x 25"H x 33"W with a 30" wide opening up front. What would be a good driver/amp combo for this space?
        Room is 6000+ cu.ft. allowing for openings to other room/hallways. I listen...
        15 December 2005, 03:23 Thursday
