I've posted this question I recieved in a PM from "Bullit731" (and my answer) because it is an intersting topic and I know there are quite a few different opinions and options on this one...
Geoff,
I have a couple of quick connection questions. I have been reading subwoofer threads associated with my Sig 805s. If I understood the posts correctly I could run a digital coax from my 1072 to my 1056 being used as my preamp and RCA cables from the 1056 to my 1080 as the power for my 805s. Then I could run the RCA analog outs from the 1072 directly to the RCA analog ins of a powered sub.
This is said to generate the cleanest signal from the 1072 in each case. My question is if this is correct, how do you limit the 805s to the midrange frequencies and above. I know you can control the frequencies of the sub by adjusting it crossover. I any case can you let me know how you would recommend setting these componets up.
Thanks, Ed
Geoff,
Thanks, Ed
