About 2 weeks ago, I bought a roof mount off-air ant and mounted it right next to my satalite. I ran 2 cables, one from the sat and one from the ant, to a diplexer I mounted on the roof. Then I ran a single cable from the outdoor diplexer to an indoor diplexer. Hooked the Sat cable from the diplexer to the sat receiver; ant cable from the diplexer to an amplifier, then to my VCR for a tuner.
Well, everything was working great until just the other day. I lost reception of locals and the satalite starting getting very choppy in the video and audio. I suspected the long cable run, so I replace it. Now the satalite works fine, but I still do not get locals.
Is it possible that a bad cable could have damaged one of the diplexers? and if so, would I see the problem in just the analogue signal?
Maybe there is a way to test a diplexer -- with a multimeter or something? I'm no EE, but I know a few of you guys are and was hoping someone could lend some advice before I go home and pull the whole setup down.
The Antenae is not that old, and both diplexers came included in the package, so I know I could just bring the whole seup back. But if I could determine which component is causing my problem, it will save me a ton of time uninstalling and reinstalling the whole setup.
Thomas.
Thomas.
