Reference level???
  • Tha Freak
    • Jul 2003
    • 385
    Reference level???
    I hear it quite often…the famous “reference level” for a HT. But what is the reference level? It seems to be quite important, but also quite loud!!!
    I red somewhere that a owner of a RSX-1055 (like me) has to turn the volume knob up to “60” to reach the famous “reference level”! that is quite loud!!!
    When I made the test for my new RSX-1055, I listened to FOTR Platinum with the DTS-ES track and the volume was at “38” the walls where shaking and the door frame was rattling!! (I turned it down to 35)…
    There is no way I could have cranked it up to a reference level of 60!!!
    Can I get some feedback on that subject?
    For information, here’s my set-up:
    Rotel RSX-1055 receiver
    Toshiba DVD player
    Energy C-6 as mains
    Energy AC-300 as center
    Energy C-2 as surrounds
    I have no sub
    "Are you gonna bark all day little doggy?...or are you gonna bite?
    -Mr. Blond in Reservoir Dogs
  • Burke Strickland
    • Sep 2001
    • 3159
    Originally posted by AudioVideo101.com
    Dolby Reference Level
    Volume level of an audio system with the volume [control knob] at the 0 decibel setting resulting in 85 decibel volume with a test tone and 105 decibel peaks. Dolby reference level is the volume level used in movie theaters for movie presentations (although this level is sometimes turned down).
    The reference level is set using a test tone generated by a surround sound preamplifier and a sound pressure level meter (SPL meter) to measure the sound output or volume. While providing a realistic and enlivening auditory experience, the reference level is very loud and is often turned down somewhat by listeners. However, surround sound audio systems should be set to the Dolby reference level and all channels properly equalized (each channel putting out the same sound pressure levels with a reference signal) even if the system will not be listened to at the true reference level.
    These are also the levels prescribed as the THX "reference levels" for THX-certified theaters and home systems.
    Originally posted by AudioVideo.com
    THX Reference Level
    Volume level designated to be used as the standard in THX certified theaters and home THX installations setting volume at 85 decibels when fed a continuous test tone and achieving 105 decibel peaks when the volume control is at the reference 0 decibel setting. The 0 decibel setting is the reference on the volume control with negative numbers being the number of decibels below reference and positive number being the number of decibels above reference. The reference level is set using a test tone generated by a surround sound preamplifier and a sound pressure level meter (SPL meter) to measure the sound output or volume.
    While providing a realistic and enlivening auditory experience, the reference level is very loud and is often turned down somewhat by listeners. However, surround sound audio systems should be set to the THX reference level and all channels properly equalized (each channel putting out the same sound pressure levels with a reference signal) even if the system will not be listened to at the true reference level. It is an interesting exercise to demonstrate a home theater system for friends when it is set at the true THX reference level though.
    [Emphasis added. The "O db" level refered to above would be marked differently on receivers or pre/pros which start their markings at O and show only positive numbers.]
    In practice, if you set all the channels to the same level as measured by the SPL meter when playing a standard test tone, you are setting a "reference level" for your system. It doesn't have to be as loud as the Dolby standard as long as it is consistent across all the channels.
    Burke
    Spelling and grammar checked in MS Word. If you detect an error, please notify Bill Gates.
      • 16478
      Reference levels simply mean that you are playing back the movie at the same volume at which it was mixed at and usually what the director intended you to listen to it at. Of course this is all just a guideline and you're free to listen to it at what ever volume you find comfortable...which for most people is quite a bit below "reference". Your volume reading though means nothing when comparing it to someone elses unless you've calibrated your system against a known volume level. This is usually best done with either Avia or Video Essentials which are both Calibration DVD's that calibrate both the audio and video side of your systems to a started level. If you don't already own one of these fine discs I highly recomend you pick one up as well as an analog SPL meter from Radio Shack. These tools will help bring your gear upto the level its capable of and allow you to get every last ounce out of the equipment. With respect to the reference volumes what you would do is play back the test tones on the DVD that are at a known volume. You then turn up your volume on the the Rotel until your SPL meter reads either 75 or 85 dB (depends on which disk you use). You then simply adjust all the other channels until their volume matches the fronts. You should now be able to turn up your receiver to this volume number (mines at 70 db on the display) and know that you're at the same level as the recording studio and other users. Its also handy when you say you prefer the sound at -10dB from reference since we'll all know exactly what you are hearing at that level even though you have different equipment and a different room then we have.
      • Tha Freak
        • Jul 2003
        • 385
        I see...a little bit complicated...but I could manage!
        I have the S&V tune up disk...is it OK?
        If I have this right, I (try to find) buy a analog SPL meter, I pop the disk in my player, play the tone for left channel and ajust the volume until the SPL reads 85db, then I switch the test tone to the next speaker, and with the ±db I ajust it so it also reads 85db, and so on for the rest of the speaker.
        So, the reference level is more for the initial set up.
        do I get this right?
          • 16478
          Yes that's fine. The S&V disc is just a subset of the Avia DVD but for 95 plus percent of the population the S&V disc has all you'll ever need. And actually its got the 6.1 test tones that are missing on the Avia disc so you're ahead of the game in that regard.
          Being in Canada you might have a hard time finding an analog SPL meter since Radio Shack only sells the Digital ones up here now :roll: but its not that big a deal. The reason we always suggest the analog one is that its easier to use in that its easier to watch the needle swing around 85 dB where as its harder to watch the digital display jump around from 83 to 87 and so forth...it can be done though.
            Tha Freak: You got it right. It's really not very hard at all, and not very expensive. I think the SPL meter is like $20 at Radio Shack. I also prefer the analog version for the same reason Andrew said. I personally crouch behind my seat at the main listening position, holding the SPL meter right where my head would be to eliminate my body directly interfering with sound waves, but even that's not really required.
            Most people find the reference db level somewhat louder than normal, and turn it down. It's all personal preference, but you'll lose just a bit of detail every time you turn it down. Me, I'm big on hearing the true, original sound of media that the designers intended.
            Luke: "Hey, I'm not such a bad pilot myself, you know"
              Huh? What? I can't hear you. . . I've been listening to movies at reference volume for too long! :B
              One other comment on reference levels: if I'm not mistaken, aren't you supposed to set your subwoofer output +10 dB (to 85 or 95 dB depending on which disk you use) to compensate for the differences in home vs. commercial theater acoustics? I've heard some HT's that are set like that and the bass is too pronounced (room gain?), but in my room that's what produces the most normal and balanced tones across the spectrum. As always, YMMV.
              One caveat here: I'm running a Velodyne FSR-15 sub which is one of the servo-controlled designs. Some people think the bass on these is too constrained, so that might have something to do with my +10 dB preference. I don't think these subs are "too anything", but I do have mine set +10. . . .
              David - HTGuide flunky
              Our "Theater"
              Our DVDs on DVD Tracker
              • Burke Strickland
                • Sep 2001
                • 3159
                I'm big on still having my hearing intact at the end of my listening session. ;>) Reference level is for reference only. A really good home playback system can resolve sufficient detail at lower volume levels to be satisfying as a listening experience and be true to the artists' intent (unless their intent was to make the members of their audience deaf).
                IMO, "reference" level is too loud to be comfortable or safe for sustained listening, While some would argue that Dolby and THX would never prescribe a level that isn't "safe" or they wouldn't get away with it legally, by analogy, there is also a lot of processed food on the shelves of the grocery stores that have excessively high salt content and they "get away with it".
                Although it isn't healthy to eat a lot of salt, (it can lead to high blood pressure and damage internal organs), it is still legal for the manufacturers to sell their products that are loaded with it for "taste". We as consumers have to read the labels and protect ourselves by avoiding "too much" salt. Likewise, we need to take "reference" levels with a grain of salt, :>) and set our actual listening levels at a sane volume that won't blow out our eardrums.
                Burke
                • George Bellefontaine
                  • Jan 2001
                  • 7636
                  Earlier I used to try listening as close to reference as possible, but it became annoying after awhile to myself, my wife and guests who often felt reference levels in theaters were much too loud. I have my Denon volume control knob set at -15 for most dvds. The DTS track of LOTR though is very loud and I had to cut that back to -20. As for the sub, like Tex, mine is +10.
                  My Homepage!
                  My Homepage!
                  • ht_addict
                    • Dec 2002
                    • 509
                    I personally pick 0db on my Marantz pre/pro as the 75db level. Calibrated each channel individually to this level. Now when I watch DVD's I usually turn it up to -15db to -10db. This is plenty loud especially during intense scenes.
                    ht_addict
                      True, true.
                      Me personally, after calibration at reference level volume, I back off the master volume 5-10 db for viewing. But as others pointed out, each disc/TV show varies from a little to a lot in volume, and it requires further adjustment. Some discs are made "hotter" in overall volume, or even just certain frequencies (usually bass) to appeal to the ear.
                      Funny that LOTR was mentioned--this is always the first movie that pops in my mind. It is VERY, VERY bass heavy. Usually I have my sub turned up a few db over reference due to both personal preference and to compensate for bass-deficient material. But LOTR is one media piece that needs no additional boosting whatsoever.
                      I just don't like to adjust calibration for individual movies or music.
                      • jlee
                        Setting volume levels on RSP-1098 - rears seem soft?
                        by jlee
                        Hello. I just got my RSP-1098. Firmware is version 3.1 (I guess the 2 week wait was worth it... seems as if I ended up with the most recent version). I just got my Classe CAM-200 for the center channel yesterday.
                        Setup:
                        Left, Center, Right - CAM-200
                        Rear - RB-1080
                        25 September 2004, 05:13 Saturday
                      • Trevor Schell
                        Reference SPL's 'VS' All Channels Driven...
                        by Trevor Schell
                        Hi!,,
                        When we calibrate our systems to reference level, we are running pink noise to each channel seperately to do the calibrations..No problem here.
                        Now when an amplifier is playing back material with all 5 or 7 channels driven, the wattage output per channel normally...
                        05 April 2001, 13:02 Thursday
                      • Frank Helmling
                        prefered listening volume level on your ROTEL
                        by Frank Helmling
                        Which is your average listening volume adjustment on your ROTEL?
                        And where is your movie reference volumelevel?
                        I have measured in my room at my RSX 1550, a level of "80" as being the cinema reference level - which produces on my listening position a maximum peak of 96dB...
                        13 October 2010, 05:30 Wednesday
                        reference levels
                        by George Bellefontaine
                        I was reading a review on the Denon 3801 Receiver in the latest issue of Widescreen Review. The reviewer constantly referred to reference level and just what is reference level. I set all channels to 75db. If this is reference where do I set the volume ? 00 ?
                        29 March 2001, 16:19 Thursday
                        Exploring Common DIY Terminology - SPL (Sound Pressure Level)
                        by technodanvan
                        SPL stands for sound pressure level, and it is a measure of the sound intensity or loudness at a specific location relative to a reference level. It is commonly used to quantify and describe the loudness of sound in various audio applications, including loudspeaker design, room acoustics, and sound engineering. Sound pressure level is expressed in decibels (dB) and is calculated using the following formula:
                        SPL (in dB) = 20 * log10(P / Pref)
                        22 July 2023, 07:04 Saturday
