Will the black bars that I notice on some anamorphic widescreen DVD's "burn" into my screen? It's kinda dissapointing getting a widescreen tv and then having "widescreen" movies still have the bars. I could use one of the stretch modes but it does distort slightly. If it is not a "high risk" type thing, I'd rather just watch them with the small bars.
Being new to RPTV's, I'm not exactly sure how this "burn" in thing actually occurs. Would it normally only occur if the brightness was cranked way up and you had the same stationary item on screen for like 10 hours? I usually watch lots of different programming so the bars would only be on during that particular movie and the remainder of my viewing is for tv. I do use one of the stretch modes for normal tv and the picture is still pretty good . . . the distortion is minimal so I can live with it.
Should this be something to be worried about?
Thanx!
Thanx!
