Hey Guy's,
My system has been torn apart since early Feb. All this down time has me thinking upgrade.
When the system was last used I had a HK PA5800 amp.
Within the last couple of weeks I replaced it with a Marantz MM9000, and a pair of Ma500 monobloc's ( the MA 500's are for the soon to be added rear surrounds).
Here's my current audio system.
Ref30
mm9000
ma500's x2
Def tech BP30 mains
Def tech clr2000 center
Def tech Promonitor surrounds.
I will picking up some Def tech BPX's for surround, and moving the monitors to rear for future replacement
Ok so here's what I am thinking.
I really have a feeling I am not gonna be real happy with the mm9000. I kinda bought it on a impulse.
To replace it I am considering the following
Sherbourn 5/1500a ( I've heard nothing but great things about it)
B&K Ref 7250 (should go well with the ref30)
Those are my two top contenders in the "affordable price range"
If I Really stretch my budget I can step up a notch in quality.
Top contenders there would be.
Bryston 9bst
Proceed amp5
My question is would the much larger price tag on the last two be worth the difference from the sub $2000 ones.
If I look at my system it seems that power amps are my weakest link. So I am starting there.
Ref30
mm9000
ma500's x2
Def tech BP30 mains
Bryston 9bst
Proceed amp5
