I had recently purchased an Alpine Car Audio system a couple of weeks back. However it did not meet my expectations so my 1997 Intrepid went back for another operation to istall some better quality components and parts. The guys did a great job as I ended up with a system that sounds pretty darn good. I just have to make sure I keep my seatbelt on so as not to bounce all over the inside of the car.
Here's some pictures to show the final results.
Here is the open trunk showing the sub box.
A closer up veiw,,2 12" subs.
The amps are Alpine V12's.
Two V12's put out 300 watts each into the dual coil subs
A single V12 produces 4x90watts into the rear deck 6x9's and the 5 1/4's in the front doors.
This is the digital capacitor made by Boss that assists in powering the amps.
This is the head unit. The face plate unfastens and fits into a little case to avoid theft.
The head units puts out 60wattsx4. The Blue lights are mezmorizing.:E
The Engine had to be modified to accomidate the system.
A close-up of the Blue Nitro kit.
Thanks.
Trevor
My HomeTheater S.E.
Sonically Enhanced
C5
Thanks.
Trevor
My HomeTheater S.E.
Sonically Enhanced
