5.1 or 6.1 enough?
  • migliore
    • Nov 2000
    • 50
    5.1 or 6.1 enough?
    I didn't want to start a discussion based on spatial obsolecnce of 7.1,8.1,10.2, but talk about actually using 5.1 or 6.1 channels to their potential.
    I was trying to think of a clear film example where the sound engineer imaged the effect between my front and rear speaker. Between my FR and RR for example, to create the sense that that effect is actually coming from beside me.
    I can't think of one, or a good one. Suggestions?
    The more I think about it, you really max your necessity of speakers at the 6.1 level. 4.1 would be enough if you didn't have more than one listener. You could corner load (within reason, or make a hexagonal setup) the speakers, and image almost any point along the perimeter of the room. Inward and outward too. Add front and rear center speakers so that other listeners have a more even soundfield, and you really shouldn't gain anything from additional speakers, other than sound pressure level.
    If you actually were to add more speakers, I would guess 2 more would be required, and they'd go along the side walls between front and rear speakers. This would bring you to 8.1, and you now have speakers everywhere. But, I'd think you need to have a good 15-20 feet between your front and rear speakers for this to be of use.
    Just my thoughts - sorry if this sounds like I'm beating a dead horse. I just don't want our audio society to embrace these new 'technologies' if we really didn't know how to use the previous ones.
    Rob
    Reviews and System
    Reviews and System
  • Lexman
    • Jun 2000
    • 1776
    Rob, it's been so long since I listened to true 5.1 on material that really rocks, that it's hard for me to give you good 5.1 examples. Sometimes, I use THX 5.1 for overly bright movies. But that's usually more center activity that drives me to do that. I enjoy the 7 channel plus sub configuration in a room that is about 18 X 19. Actually a little larger area than that would be ideal. Like say 20 X 25. I think that would be a great size for a theater designed for 1 row of seating, maybe two.
    Recently I moved my couch back a little bit, which effectively moved my sides ahead of me just slightly. So far, I am pretty happy with the arrangement. I really wish I could push my rears back 3 feet. But that's not possible as they are in the corners of the room, aimed towards the center of the sofa.
    Lex
    <A HREF="http://www.catcables.com" <IMG SRC="http://www.htguide.com/lexman/other/sm_logo.gif"
    • MRWILLL
      • 107
      I feel the same as Lex. My room is 11 1/2 by 27 (wish it were about 6 feet wider), and when I demo 5.1 as opposed to 7.1, there's a big gap in my system. There's nothing better than a contineous great soundtrack with the rears/sides kicking a**.
      STOP!!...LOOK!!...LISTEN!!
      DVD...Hear it from the people who
      mixed and mastered it "LEXICON".
      • Markj
        • 322
        I have a 16 x 22 family room that is also the theater. I find that 5.1 is enough. I have not hand the pleasure of having a 7.1 in my house and have only demo-ed 7.1 systems. I don’t feel that I am missing anything but may be ignorance is bliss. I also suspect that because I have planner speakers this helps a lot to file in any voids.
        • kingpin
          Confused about best placement for the rear speakers
          by kingpin
          So I have read and read and read. There seems to be no agreement as to the proper placement of the rear speakers(bookshelves in my case).
          Here is a picture so you can see what I am up to. There is actually about 8' available behind the couch.
          I can use any option right now...
          25 January 2008, 21:35 Friday
        • number17
          Room acoustic dilemma - rear speakers placement
          by number17
          I finally got my speakers and while I'm still shopping for a used amp (anybody who spots a marantz 5400, denon 2803 / 1804 or Yamaha RX-V1400 at ~ Cdn$500-700 I appreciate if you can let me know!) I have a dilemma with the placement of speakers in my room.
          Since I don't have a picture...
          17 August 2004, 13:53 Tuesday
        • George Bellefontaine
          Adding extra rear speakers
          by George Bellefontaine
          I have a Yamaha A3090 integrated amp and presently have two rear speakers on the side walls.They are connected to a subwoofer which is connected to the amp's rear speaker terminals. Question is, if I want to add two more rear speakers to the back walls, do I have to add another power amp to drive all...
          26 January 2001, 08:33 Friday
        • scanido
          Which Rear Speakers with 804S?
          by scanido
          Hello folks,
          Well it's almost that time of season again, time to get that yearly bonus and I was looking to get a set of rear speakers to 'complement' my set of 804S speakers.
          I went to the dealer and just took a quick look at a few models:
          DS8, DS7 and...
          27 November 2006, 12:15 Monday
        • pjisgreat
          need help in selecting rear speakers.
          by pjisgreat
          Hi guys,
          This is my first post on this forum. I currently have the following equipment.
          B&W 602 S2 for fronts
          B&W LCR 600 S3 for center channel
          Marantz CD 6000 OSE
          Yamaha RXV 596
          Denon 585 tape deck
          Samsung cheapo dvd...
          30 September 2008, 12:46 Tuesday
