I need a longer sub cable and instead of buying a "sub cable" i used a component cable...is that ok?
Can I hook up my sub with a 75ohm Component video cable?
So, is this component video cable a 3 pronge cable (3 separate strands), and yet you are using 1 strand only, and leaving 2 to what, dangle unhooked? If that's the case, I am going to say, no, not a great idea.
Secondly, a video cable while fine for a sub cable "technically speaking", still is not optimized for carrying analog audio.
I'm in the business, and those are my professional questions/comments.Doug
"I'm out there Jerry, and I'm loving every minute of it!" - Kramer- Bottom
Originally posted by LexSo, is this component video cable a 3 pronge cable (3 separate strands), and yet you are using 1 strand only, and leaving 2 to what, dangle unhooked? If that's the case, I am going to say, no, not a great idea.
I had an extra component set that I wasnt using. I dont have 2 cables unhooked, becuase I just took off on cable from the stand.
To your second point the video signal that component cables carry is analog, so im not sure I get your point. Both the sub and video are analog.- Bottom
Yep it should work fine. Secondly it's sub cable not an audio cable. There is far less information being carried to the sub in its limited bandwidth to worry about.
Bottom line, your solution WORKS.- Bottom
Actually guys, as the cable pro here, I am going to say this one more time, a sub cable is an audio cable. It's just carrying a different frequency. When I say analog, I mean analog audio, not video, and not designed to carry digital audio, as 75 ohm cable is. Cables to carry video and audio are designed with two distinctly different purposes in mind. Foil shielding while excellent for video noise suppression, can make an audio cable sound worse, and is overkill anyway for most analog audio applications.
Technically, yes, a 75 ohm cable will carry anything a 50 ohm audio cable will. But that does not make it ideal for the job. That also does not mean you could tell a difference in your setup. But I won't stand down on saying all cables are the same, whether video, primary audio, sub, analog, digital, etc... They, and the specifications thereof, simply are not the same.Doug
Please post any DIY requests in the DIY area. But welcome to the forum otherwise.
You an use 75 ohm coax with screw on F-type, and RCA to F-type adapters. See Rat shack.
thanks.Doug
