I've got some new speakers and I want to get a new A/V receiver to fit them. I don't have a clue about any of this stuff and I've hunted for info and all I managed to do was get even more confused. Any help would be greatly appreciated.
I've just acquired some Pro Dynamics speakers.
2 are tower speakers (ES3000)
200W, 8 ohm, 85 db sensitivity w/post connectors
I also have Pro Dynamics sub, with center channel speaker and four other speakers.
I don't know how many watts this sub is (Model is SPL 2800), it has it's own power source and on back of sub is following:
IN LEVEL - Left and right IN spring clip connections
Left and right OUT spring clip connections
INPUT - Left and right - what is that and where does that connect to?
PHASE - can be switch from 0 to 180 - no idea
CROSSOVER FREQ(Hz) - dial goes from 50 to 200 - no idea
Can someone give me some info on the best specs for the proper A/V receiver for these speakers, and tell me what I'm supposed to do with what's on the back of the sub? I also need some advice about the right cable I need. Not sure about that because the tower speaker connections are different from the sub connections.
Thank you for your help.
SJ Wooten
SJ Wooten
