a piece of cake....er.....ahhh....Pi
    somewhat fitting, but totally coincidentally....
    my Raspberry Pi 3 & HiFi Berry Dac Pro arrived today, 3.14.
    my goal for this project is to build a portable music server system that i will use mostly at work.
    basic capabilities include:
    power for both headphones & efficient DIY speakers.
    run music server aps for redbook & higher res
    use a portable HD.
    access to wifi & Ethernet for control & music streaming.
    to start with, i purchased a low noise linear power supply here
    so today i started assembly of the PS.
    Last edited by theSven; 24 June 2023, 17:40 Saturday. Reason: Update image location
    • 4157
    That's an ambitious list of wants. I'll be following this project, mostly because A) It looks like a very useful idea, and B) If anyone besides Jon can pull this off my money is on you.
      i do appreciate your confidence & hope it is not totally unfounded 8O
      it is a low-cost solution to a problem i do not have.
      main purpose is just to build something & possibly learn a new thing or two.
      but others may be interested since it does provide a quite affordable & flexible little digital platform that is easily ('easy' being a relative statement here as i have no experience with Linux or programming) customized & tailored to one's specific desires.
      one of the areas i have spent a fair amount of time researching is how significant low noise is for digital music systems.
      the first challenge was to find a power supply that could exceed what is commonly used in commercial equipment.
      as per our Maestro, Jon Marsh, the UltraCap LPS-1 is one of the best currently available.
      i may get one later, after i upgrade the DAC board to the Soekeris 1012-12 board.
      the PS board i have chosen to start with is fairly cheap & uses chokes for common mode noise reduction.
      it is actually two PS's on one board, so i can use separate PS's for the Pi & the DAC board.
      i will be making some noise measurements once i get it completed.
      my goal is to get better performance than the ifi Audio iPower.
      total costs so far:
      DIYNHK Power Supply 67.95
      Vilros Raspberry Pi 3 Media Center Kit 59.99
      HiFiBerry DAC+ – Pro 47.97
      Total 175.91
      Last edited by theSven; 24 June 2023, 17:41 Saturday. Reason: Update image location
      • Finleyville
        • 350
        opcorn:
          • 4157
          It's based on your engineering background, your fine taste in audio equipment, and your remarkable taste in motorcycles. That last being one of my reference points for quickly identifying the "good guys" for many years.
            Originally posted by Alaric
            ..... based on [a] remarkable taste in motorcycles. That ..... being one of my reference points for quickly identifying the "good guys" for many years.
            a litmus test which i too, always apply & have found to be quite reliable over many years of use
              some geek porn:
              so i booted up the Pi3 with Volumio & everything seemed ok.
              still some work to do on software loading / settings.....so no music yet.
              Last edited by theSven; 24 June 2023, 17:44 Saturday. Reason: Update image location
                • 4157
                Nekkid PCB!
                  here is my little desktop project so far.....
                  still need to finish up my low noise linear power supply, so just using a standard wall wart for now
                  1/2 gig drive feeding the HiFi Berry Pro DAC
                  Using Volumio as an OS platform for now.
                  I can access WiFi streaming via the raspberry Pi3 so long as i am hooked into our company network.
                  Last edited by theSven; 24 June 2023, 17:46 Saturday. Reason: Update image location
                    further update:
                    short term solution for powering speakers......
                    just ordered this from MassDrop for $99 including shipping
                    yes.
                    i know.
                    odds are high that this thing will be DOA.......
                    if it does work, i will be putting in the new sockets & tubes i just ordered for it.
                    hardly at the level of how our Maestro does things.....
                    .....but hey, this is all a learning exercise, so......
                    ......when i break shit, i will not be crying.....well, not for too long, anyways.....
                    Last edited by theSven; 24 June 2023, 17:46 Saturday. Reason: Remove broken image link
                      • 4157
                      They actually don't sound horrible, at least not the one I heard playing through Mirage speakers.
                        encouraging news, Lee.
                          You know when you get this all done, we have to have a listening party with it!!!!
                            I finished soldering up the power supply on thursday.
                            i will hook it up to one of our lab power supplys on monday to see if it runs without me having to put any magic smoke back into it.
                              ordered two of these transformers for the PS.
                              will be on vacation for a few days, then returning to some critical deadlines at work.
                              maybe get some testing done in two weeks.....
                              Last edited by theSven; 24 June 2023, 17:47 Saturday. Reason: Update image location
                                Ah, one of my favorite concepts in audio....
                                At least it is not a high cost solution, the path I usually take... :B
                                  Click image for larger version  Name:	20170413_072453_zpsabv2o7i1.webp Views:	0 Size:	43.2 KB ID:	942452
                                  Substantial progress... may the Force be with you for successful completion when you return from this, what did you call it, "Vacation" - what is the meaning of this word?
                                    Bill, did you try out that tube amp yet?!?!?!?
                                      got side-tracked.......
                                      my new car is my new obsession......been planning, performing & spending on performance upgrades......
                                      too many hobbies, so little time!
                                      Last edited by theSven; 24 June 2023, 17:49 Saturday. Reason: Update image location
                                        Another pretty bauble...
                                        Well, it is quite understandable how this will prove a powerful distraction for you... but to master the true power of the Force, you will need to harness the power of single minded focus...
                                        You may note that I have not been discussing land speeders or new atmospheric fighters for some time... there is a reason for that.
                                        OTOH, you may well enjoy life a little more this way... Being a Sith Lord is not always all it's made out to be...
                                        • Wayne1
                                          DIY Modular DAC
                                          by Wayne1
                                          Please note that this is a work in progress.
                                          A couple of years ago, I started accumulating parts for a DAC build that would allow me to play back my collection of SACD rips.
                                          I had been using a Logitech Touch with EDO app into a CEntrance DACmini.
                                          A couple...
                                          13 August 2017, 12:51 Sunday
                                        • Supernova
                                          Whole house replacement project with raspberry pi's.
                                          by Supernova
                                          I thought I'd share my journey and seek advice and recommendations on replacing my whole house entertainment system. I researched various projects including Roon (I really wanted to use this but there were limitations), Volumino and many others. In the end I settled on piCorePlayer....
                                          08 March 2020, 11:09 Sunday
                                          New Z-series DAC finally released!
                                          This is sweet--the zDAC is finally released. I'm going to pick up a couple of these for sure, and I'm REALLY hopeful about the performance possibilities.
                                          News release today. Visit the full press release webpage at http://www.gspr.com/parasound/zdac.html for high resolution pictures...
                                          06 November 2012, 09:17 Tuesday
                                          AURALiC Vega DAC
                                          This is one of those tests and write ups I've ben wanting to get around to for some time, but there always seems to be something more immediately urgent to distract me from the effort. Well, there still are those things, but I figured it's time to get this done because I'm...
                                          10 December 2016, 10:20 Saturday
                                        • wettou
                                          Why Top Quality DAC matter in the SSP-800
                                          by wettou
                                          Why Use a Better DAC?
                                          An argument for why using an external audio converter IC over one integrated on an SoC can help ensure high-quality audio performance.
                                          By Dafydd Roche, Texas Instruments
                                          My system-on-chip already has an onboard codec. So why should I bother...
                                          04 December 2008, 12:37 Thursday
