Hello everyone. This has puzzled me for quite some time now. Any comments regarding this will be highly appreciated and will help me not waste money, thanks.
I want to have good HT and be able to listen to decent stereo sound. I noticed from auditioning receivers and (surround pre-amp / amps) that the best stereo sound that can be achieved (from HT equipment) was by using "direct sound" mode (signal bypasses all processing and is fed directly to the amp).
However, in this mode, the full frequency range is sent to the Left and Right speakers. Therefore, floorstands would be ideal. However, my Left and Right speakers are the N805 which are bookshelves and are limited in the lower freqs.
I started thinking of a solution, and this is what I came up with. Please tell me if this will give good results.
I know that my subs (two B&W ASW675) when used in a system with a seperate pre-amp and surround amp can be used to function as part of Left and Right speaker (will work in stereo). This is possible by connecting the right channel from the pre-amp to one sub, and connecting the Left channel to the other sub. Then set the cross-over freq in the sub accourding to N805 capabilities. The remaining signal is then sent to the amp and then to the left and right speakers (N805).
My first question, is do you think that using the above set-up will give good stereo sound, comparible to floor-stand speaker. Or will the bass be in-accurate?
Should I persue this set-up by buying a seperates surround pre-amp processor and surround amp (the above set-up cannot be made without seperates) (thinking of getting the new Arcam). Or should I just give-up on getting perfect music (with my current speakers) and get a regular surround receiver and save the big spending that I'm going make if I go the seperates way?
Bear in mind that my next purchase is going to be a surround processor/amp or a surround receiver because my current one sucks. Furthermore, I do not wish to change any of my speakers or subs.
I can't help the feeling that goes through my head "I wish I bought floor stands", but I wasn't very audio educated 2 year ago
Thanks for your time guys, (sorry about the long post)
