Subwoofer vibration problem
  • whmacs
    • Oct 2003
    • 184
    Hi All,
    When I installed the home theatre in the family room my wife was pretty flexible except for two things. 1) No wires visible 2) no speakers or subwoofer on the floor. To met this requirements I used Jamo THX D6 speakers that are wall mounted and the Jamo 15" SW-3015 servo subwoofer that sits in the cabinet on the right hand side. This cabinet is 3.8m x.8m x .8m and quite solid (see attached link). The problem I have is that the sub will sometimes cause the cabinet to vibrate when a long low notes are played in the 28-38hz range. I realise that the best solution is to move the sub out of the cabinet, but this would violate rule (2) and is not an option. Is there anything I could sit the sub on in the cabinet or insulate the enclosure that would minimise these vibrations?
    Cabinet (sub on right)
    Stephen
    My Home Theatre
  • Snap
    • 1295
    Hey Stephen,
    My guess is that the its the doors that might be making most of the noise! Wait a minute..... First..... Sweet sysem man. It looks very nice.
    I would try this. Glue some carpet or some thing that is soft to the inside of the doors. That will take away the wood on wood rattle. (If that is what it is). Then if the Sub is directly on the bottom wood of the cabinate, try placing a cut of carpet under the sub so that the sub is sitting on the carpet and not wood on wood again.
    Not sure if that will help, but it is something that you might want to try.
    snap
    • gd
      • Jan 2003
      • 583
      The eternal battle... wimmin vs speakers.
      Your screen / cabinet setup is absolutely handsome -- and that sub is never gonna work properly while tucked away in a cabinet... box subs are designed to interact with the entire room, and the cabinet treatment will necessarily inhibit that.
      The only solution I can think of is a costly one -- an in-wall sub... by now there should be others, but the only specialty manufacturer I can think of is James Loudspeakers... never heard them, but they are well-reviewed, highly regarded... looks like they also make on-wall subs... http://www.jamesloudspeaker.com/inwall.cfm
      greg (gd to you)
      Frank Zappa
      • Patt
        • 922
        Hi Stephen,
        What Snap said about carpet for insulating is a great idea.
        My sub shook things severely until I did the following.....sub on spikes...then a round concrete pad painted flat black from a home store....then a dozen squash balls painted flat black and hotmelt glued to the underside of the concrete pad.
        It stopped all shaking caused by the movement from the sub. As long as there is room for the sub to be raised about 5"-6".
        ......Pat
        • Snap
          • 1295
          If you are going to go with an in-wall sub go with Earthquakes new in wall sub that thing is a killer.
          Patt what a great Idea. Dang....what a great idea. Thanks man that is cool. I am printing that one out for the ole, file cabinate. :T
          • ajpoe
            • 439
            may be you could get some ideas from this site:
            cult of the infinitely baffled
            I don't know if it would be possible to seal that cabinet and port it, or just go with something like they have done on that page.
            AJPoe - - Growing old is inevitable, growing up is optional!
            • Patt
              • 922
              Gee, the guy not only installs subwoofers but builds them as well.......
              Thought I spotted a single black Tyler Acoustics monitor speaker on page 3.
              ......Pat
              • whmacs
                • Oct 2003
                • 184
                Hi Guys,
                Thanks for all the reply's I really appreciate it. I would dearly love to move the sub out of the cupboard, but that would have a very low WAF factor. The first thing I checked was the cupboard doors which turned out not to be the problem. The rattling still occured with the doors open. I'm using DVE's 15hz to 150Hz LFE sweep and the rattling starts at 28Hz and finishes at 38hz so its not the biggest problem, but I would like to try and improve the situation. I've now got some foam rubber and I've grab a paving slab in the morning. I also picked up a couple of carpet tiles so I'll give them a try as will and report back.
                Patt, with the squash balls did you cut them in half before sticking onto the the paving slab?
                thanks again for all the help guys.
                cheers,
                Stephen
                My Home Theatre
                • eddiem67
                  • 139
                  You might have a spike at that frequency, is your sub EQ'd, you can try to flatten the response, although this will not fix your problem, but it might reduce the vibrations due to resonant frequency at 28-38Hz. The earthquake in wall subs are very nice, that is one recommendation, or you can get a baffle sub, ie Image dynamics.
                  My Car Audio
                  • whmacs
                    • Oct 2003
                    • 184
                    Hi All,
                    First off I would like to thank everyone for all the great ideas and suggestions, this is a great forum to be a member.
                    Well after everyone's suggestions the problem turned out to be fairly easy to fix. Last night I confirmed that there were no loose items rattling and it was in fact the cabinet resonating. Following peoples suggestions I ended up lining the inside of the subwoofer enslosure with carpet tiles which cost about $5 per 0.5metre square tile (the enclosure is roughly 0.5 x 0.5 x 05). Problem solved! I can detect no reasonance now in the 28 - 38hz range at normal listening levels (around 62 on my Rotel RSP-1098 procesor) and I can't detect any loss of subwoofer impact due to the carpet tiles! To induce any hint of vibration I have to crank the RSP-1098 up to 75 or so. At this level there is only a hint of vibration in the 28 - 38Hz range and no vibrations in any of the other ranges. 75 is way too loud and I have the automatic volume lockout set to 77 to stop the kids blowing things up or the sub causing down lights to fall out of the ceiling (which has happened in the past!)
                    So once again thanks for all the input and suggestion which helped solve the issue.
                    cheers,
                    Stephen
                    My Home Theatre
                    • Snap
                      • 1295
                      :T Glad that worked for you man. I wish I had your system very nice set up!
                      • whmacs
                        • Oct 2003
                        • 184
                        Thanks Snap I appreciate the kind words. When we built the extension onto the house I had the luxury or designing the room with a HT in mind, this made things a lot easier than trying to retrofit into an existing room.
                        Once again, thanks for all the help.
                        cheers,
                        Stephen
                        My Home Theatre
                        • xyrium
                          Need a sealed cab sub. Morel UW1058?
                          by xyrium
                          Hey guys,
                          I want to build a sealed cabinet sub, and therefore considering the Morel UW1058 and the Scanspeak 23W. Has anyone used these before, or can anyone recommend another driver for sound quality?
                          I'm fairly partial to US and Euro made drivers however...sorry.
                          17 March 2010, 21:39 Wednesday
                        • tizeye
                          Speaker Spikes and Wood Floors
                          by tizeye
                          Currently building Zaph's SR71 and matching stands. First primer coat on drying on sands as I type. Having difficulty deciding how to spike the stands.
                          With my sub, PE's 10" Titanic, I quickly learned pointy spikes + wood floors = disaster and the separate floor plates are a joke...
                          23 October 2009, 06:40 Friday
                        • pcrocett
                          Sub placement
                          by pcrocett
                          Is the conventional wisdom that sub woofer placement should be on the floor? I have a nice out-of-the-way spot atop our armoire. Putting it here would put the feet of the sub on wood, rather than carpet. It would also keep it out of the way of my 2 year old, and vacuuming ease and asthetic are also...
                          12 February 2005, 18:39 Saturday
                        • directitstore
                          Faulty Jamo 6510sub
                          by directitstore
                          Bought this $900+ dollar sub as part of the Jamo PDD.5 system from Harvey Norman, Auburn, Aust only a month or so ago.
                          Anyway, while watching the T.V (on a low power level) this loud buzzing noise was apparent, with no bass sound output just this LOUD buzzing noise.
                          After...
                          12 August 2005, 01:09 Friday
                        • scarpi
                          Paradigm Servo 15 sub question
                          by scarpi
                          I have a Paradigm Servo 15 ver.1 sub. It came with large plastic feet attached to the bottom. Paradigm also supplied floor spikes but when you remove the plastic feet, there is no way to screw the metal spikes into the bottom of the sub because the holes are too large. Has anyone installed these spikes...
                          08 February 2010, 16:26 Monday
