RGB and HDTV
  • akfire
    • 4
    RGB and HDTV
    I currently have a RUNCO 3 Gun projector which has RGB cables. Is it possible to have HDTV without changing the these cables to component or DVI cables?
  • Uncle Clive
    Former Moderator
    • Jan 2002
    • 919
    Hi Andrew, I am not sure I'm following correctly however, most systems that are High Definition Ready uses the component input (the RGB input and cables) to transport that signal. Of course, there is DVI and HDMI available now but if your Runco is High Definition Ready, then the RGB\COMPONENT video input would be the one to use.
    CLIVE
    • akfire
      • 4
      Clive, Thanks for your reply. I'm a beginner so please bear with me. My projector does not have actual component inputs. It's older with the 5 input RGB/white, yellow ports. I think the system has HDTV (Runco 980 IDP) capability, but I'm not sure.
      Any info I can get is greatly appreciated.
      Andy
      • Uncle Clive
        Former Moderator
        • Jan 2002
        • 919
        No apologies required here, this is what "The Starting Block" is about. I have invited a couple of moderators from the front projection forum to assist us here. Please wait for their responses.
        CLIVE
        • Dean McManis
          • May 2003
          • 762
          Welcome Akfire,
          RGB (or RGBHV) is the way that computers output their high resolution analog picture information. The main connections for PCs and high resolution CRT projectors were separate RGBHV cables or the familiar VGA connector.
          Component connections were a way to get the RGB and sync signals with only 3 RCA plug connectors.
          DVI (Digital Video Interface) is a newer, digital video, PC connection, but it was adopted for HDTV use more for copy protection (DCHP/HDMI) than for picture quality enhancement. DVI output from a PC will not include the DHCP encryption, so it may not work with DTV peripherals.
          To start producing equipment that could recieve HDTV broadcasts, limit video piracy, and slow the PC industry from taking over, the electronics manufacturers first used component connections, later DHCP, and now DVI/HDMI connections between video peripherals.
          My RCA DTC100 HDTV decoder has VGA/RGB output, and there are a few DVD players that have RGB/VGA out connections.
          But most new equipment has only progressive component, DVI, or HDMI connections for connecting to HDTV displays in high resolution.
          And composite (low resolution/interlaced), and S-Video or analog component (better, low resolution interlaced) plug connections for backward compatibility to older NTSC media and devices.
          The slightly shorter answer is that most CRT/RGB projectors were built years before any HDTV connection standards were set, and they were usually used with PCs for displaying presentations. Some models have S-video inputs for watching VHS, DSS, and DVD video sources, and some with RGBHV inputs can be set to accept progressive component inputs (Y-PbPr) with the proper conversion cable and internal settings.
          It's possible, but not guaranteed to have a RGB-only display work with every video device that's available now to buy. So you need to find out the exact capabilities of your projector, and look to try and find video peripherals that match those connection capabilities.
          The reason that I've got a long, complex answer is that there have been years of conflicts in trying to set universal HDTV standards, and some are not yet fully defined even today (like HD-DVD).
          Feel free to ask more questions if something above doesn't make sense, and I'll try to make it clearer.
          -Dean.
            • 16045
            I'm in a similar situation, with two NEC CRT projectors with VGA and RGBHV inputs (your Runco is based on an NEC chasis.)
            Component video is a format which uses a luminance channel (black and white) (Y) and two color difference signals which are matrixed with the luminance to be decoded into RGB inside the set.
            There are transcoders from companies like Key Digital and Extron which will convert from Component to RGBHV. I have a Key Digital for when I need that functionality. You have to be a little careful, and distinguish between DVD component and HDTV component, becuase they use slightly different color space coefficients and if you use one where you need the other, you'll get a viewable image, but the color balance will be off. This was also a problem with some DVD players that offered upscaling on component outputs- they were outputting HD resolutions with a SD (DVD) color matrix.
            I use a DVI-D to RGBHV converter also; this is not the small dongle like used with DVI-A from a PC video card, but a true digital to analog converter system with it's own power supply. That works fine, but it's not cheap- they're in the range of $300 to $400 dollars.
            Like Dean's RCE, I have an HDTV tuner and a PC HDTV card that can output either RGB or Component. The tuner was a Samsung- maybe the current Samsungs will do that, too. Check them out to see- then you won't need a transcoder. My Key Digital transcoder was a couple of hundred dollars, if I recall correctly, about half the price of an HDTV tuner these days.
            Good luck getting your system setup for HD- you'll enjoy it a lot once you do!
            ~Jon
            • b&Wman
              Need advice on new HDTV $3000-$3500
              by b&Wman
              I'm in the market for a new widescreen TV.
              Here are the criteria I'm looking for:
              Excellent picture quality
              Must have a native display at 720p
              Must have HDMI input
              Must have computer (RGB VGA or DVI) input
              Must be at least 37" widescreen, must...
              04 December 2004, 00:24 Saturday
            • draganm
              Marquee CRT projector and DVI input card
              by draganm
              A few people have inquired on this board in the past about being able to input a DVI signal into their CRT projector. For about a year now, a guy named Moome in Hong Kong has been manufacturing cards that plug directly into the electrohome Marquee, Sony, Barco, and NEC CRT projectors. The card accpets...
              01 July 2006, 12:20 Saturday
            • kennethma
              Last hurrah for a Runco CRT projector
              by kennethma
              I have a Runco IDP980 (8" CRT) projector which has served me well since 1996. Wish I could say the same for my Faroudja LD 100 line doubler, which was great for anamorphic DVDs but now has completely died on me. Living in Brazil now, which means buying fancy new DLP projector is not an option...
              21 June 2005, 00:09 Tuesday
            • eddieberman
              HD DVI to Runco 980 BNC?
              by eddieberman
              I've had a Runco 980 for many years, which I've been using with a Runco line doubler. We just started renting a Comcast HD box for our smaller HDTV. My question is this - If we wanted to watch HD through the Runco, is it as simple as buying a connecting cable with a DVI end on one side (for the Comcast...
              30 December 2005, 20:08 Friday
            • levi2000
              To RGB or not to RGB
              by levi2000
              I'm a newbie here so go easy on me. Here is my setup:
              Wall Mounted HDTV, Direct TV HD Cable, DVD Player (with HDMI out) and Yamaha tuner. The tuner is about 5-6 years old and does not have HDMI capability.
              Now to my question... Should I run the DVD and Direct TV outs...
              20 January 2011, 14:33 Thursday
