Is there a difference?
  • Clive
    Former Moderator
    • Jan 2002
    • 919
    Are there any speakers out there that is definately not recomended for Home theater use just two channel?
    CLIVE
    CLIVE
  • Burke Strickland
    • Sep 2001
    • 3159
    Generally, (as you are probably already aware), if speakers sound good on music-only, they will also sound good on movie soundtracks. The reverse is NOT always true.
    Some folks are dead set opposed to electrostatics (or other flat panel designs such as planar magnetic) being used for HT because they typically don't provide the "slam" that some cone-type speakers render on soundtracks. But even those can be very satisfying due to their detail and clarity -- movies aren't all about explosions and earthquakes :>) -- and when mated with a powerful sub, the "slam" can be there, too.
    Also, some speaker designs (and again the flat panels come to mind) require a lot of floor space -- positioned out far a way from the walls -- to sound their best, and that means in a smaller room, only two of them will "fit". But actually, almost all speakers (except those specifically designed to be placed on or in the wall) benefit from being placed away from the walls, so that argument is kind of a red herring. If you like the sound, use the speaker.
    Burke
    PS -- if you are looking for recommendations on speakers that do an exceptional job on music, we'll be happy to make some suggestions.
      • 16478
      I guess you might be able to argue that some of the more exotic speakers don't have a matching center channel so in that regard they wouldn't make the best choice for HT applications but I don't think thats what you're really going after in this thread. I agree with burke though that any speaker that does justice to music should work well for HT also.
      • Kevin P
        • 10812
        Basically like Andrew said. I've heard (and even owned) speakers that sounded pretty darned good during movies but were intolerable for music. If you find speakers that you're happy with for music, they'll shine for movies too, especially if you can get matching center and surrounds, and mate it with a good subwoofer.
        I hit pay dirt with my Platinum Audio speakers. The speakers sound wonderful for music, and since the towers and the smaller speakers use the exact same driver configuration I get seamless timbre matching all around.
        KJP
        My HT Site
          I would just point out the difference in speaker types of monopole, bipole, dipole, tripole, etc. Depending on which speaker position you're trying to set up, whether front, center, surround, etc, I would definitely recommend one type of speaker over another. So in that sense, I would NOT recommend most dipole types for two channel. But I would not recommend many direct radiating monopoles for home theater surround.
          My $.02
          Luke: "Hey, I'm not such a bad pilot myself, you know"
          • tonygeno
            • Feb 2003
            • 17
            My own feelings are that if a speaker is of low sensitivity and can't play loud because of power handling issues it probably is not a good home theater speaker (although it may work wonders for music). Examples might be the original Quad ESL, Celestion SL600 (82db sensitive), to name a couple.
            • Uncle Clive
              Former Moderator
              • Jan 2002
              • 919
              So then for all you Audiophiles out there, would you recomend two separate systems/ speakers systems for music and theater. Do you use your "A" >"B" speaker switching?
              How should we really have this setup?
              CLIVE
              CLIVE
              • tonygeno
                • Feb 2003
                • 17
                I would recommend finding a speaker that works well for music and home theater. Why complicate life unnecessarily with two sets of speakers in a room?
                • Burke Strickland
                  • Sep 2001
                  • 3159
                  No. (See below.)
                  I agree.
                  I bought my Magnepan MG 3.6 speakers for "music-only" with the intention of having two completely separate systems in the same room. In fact, I set them up originally with a stereo preamp and power amp totally divorced from my HT system. But while we were setting up the Maggies, the dealer rep suggested I try them with a movie sometime "just to check it out".
                  Eventually I did, and from then on, the Maggies became "dual use". Except for comparison demos. I never used the Def Tech BP-2000s which had been my main L/R speakers for HT in that role again, and they are now my side surrounds in a 7.1 configuration. The Maggies do a superlative job of transporting the listener to the performing space where music is created, and they work their magic convincingly on movie soundtracks as well. (For LFE "slam", they are augmented in the lowest octaves by the Velodyne FSR-18 sub which I had purchased earlier.)
                  I merged the rest of the signal chain, too. One pre-pro to rule them all. :>) It just isn't convenient having two systems in the same room. With the right (high quality) components and careful setup, stereo music sounds sensational, and movie sound can be served properly too.
                  Burke
                    Clive- Aha, you bring up the exact point that has been made on many other discussion forums. Yes, there definitely are music purists out there that advocate two different setups for music and movies. Mostly, though, it's just in regards to the surround speakers which are typically built as some sort of bipole/dipole for movies, not for music. Since main and center speakers are almost always direct radiating monopoles, they CAN be used for both music and movies.
                    Denon made their top model 5803 (and I think the 3803) to satisfy even these picky people, having TWO sets of side surround speaker outputs, in addition to the rear surrounds in a 7.1 setup! Only one set of side surrounds operate at a time, so the idea is that you connect the side surround A jacks to your dipole movie surround speakers, and the side surround B jacks to your music surround speakers. Then you switch between the two sets depending on whether your DVD or CD is music or a movie.
                    This means that you could have as many as **10** speakers in your room, counting the sub, center, two mains, two rear surrounds, and **4** side surrounds. Wow. Confused?
                    Me personally, I find that to be overkill for my needs. I mostly watch movies, so I just set up all my surrounds as bipoles for dispersed sound, not direct. When I listen to CD music, I only use my mains anyways, and usually don't try to convert it to surround sound and muddy up the sound image. If I happen to be watching/listening to a 5.1 DVD or CD, I don't find myself caring much about the sound coming out of the surrounds not being "pure" as a direct sound, so I live with it.
                    • Uncle Clive
                      Former Moderator
                      • Jan 2002
                      • 919
                      Sure is good to know that I wouldn't have to consider buying more speakers, you're correct, it would be an over-kill.
                      Chris as silly as this may seem but I'll tel ya! I do know that many, many others here participate on other forums and I guess it maybe a good thing but I don't have the time. Before joining here I checked out two others. There were just too much bashing going on which made me afraid to even ask a simple question. I have never gone back since. Not because Lex pays me a lot of money to stay 8O really, I just don't have time. :LOL: Sharing that knowledge is priceless............Thanx.
                      CLIVE
                      CLIVE
                      • Opus007
                        Rock N Roll Speakers?
                        by Opus007
                        Just wondering which B&W speakers you own or have owned that you consider the best for rock.I own the 683's and a lot has been been posted about them not being very good speakers to which I totally disagree.They are very revealing and do exceptionally well for jazz and classical music.And also do...
                        20 January 2009, 23:49 Tuesday
                      • marshahu_cr
                        Best Speakers for Denon 1705
                        by marshahu_cr
                        Long time no see. Good to be back here again.
                        I am basically aiming for a budget 6.1 Home Theater solution with a DVD Audio and SACD player. I am intending to use this setup to output positional audio from EAX 4 compatible PC Games so 6.1 is essential - the more the better! So far I have...
                        05 April 2005, 14:09 Tuesday
                      • wettou
                        Using white noise to aim and adjust speakers
                        by wettou
                        Using white noise to aim and adjust speakers AIMING and "LEARNING" SPEAKERS Here is a method for "aiming" ...
                        25 July 2010, 16:28 Sunday
                      • amix
                        The Surround Wonder (Speakers)
                        by amix
                        Wooooooow !
                        That's it ! As some of you may know I was going out to find a nice 5.1 set. What I found on my search was not what I expected. I did not know surround can be so realistic.
                        A little dealer, far out in the nowhere, a little village aside from a major town, showed...
                        31 July 2004, 13:27 Saturday
                      • number17
                        Room acoustic dilemma - rear speakers placement
                        by number17
                        I finally got my speakers and while I'm still shopping for a used amp (anybody who spots a marantz 5400, denon 2803 / 1804 or Yamaha RX-V1400 at ~ Cdn$500-700 I appreciate if you can let me know!) I have a dilemma with the placement of speakers in my room.
                        Since I don't have a picture...
                        17 August 2004, 13:53 Tuesday
