How much power?
  • eljr
    • Aug 2007
    • 88
    How much power?
    I have a pair of speakers that I would like power recomendations for.
    Here are the specs.
    Frequency range+/- 3 dB [Hz]: 42.0 - 34,000.0
    Sensitivity (2,83 V/1 m) [dB]: 88.0
    Nominal impedance [ohms]: 6
    Maximum SPL [dB]: 109.0
    Recommended amp. power [Watts]: 40.0 - 200.0
    What you got back home, lil' sister, to play yer fuzzy warbles on? Pitiful, portable picnic players?
    Come with uncle & hear all proper! Hear angels trumpets & devils trombones. You are invited!
  • Glen B
    • 1106
    Power requirement is determined by speaker sensitivity, room size, distance from the listening position to the speakers, and how loud you like to listen. Try using this Peak SPL Calculator:
      HTG rule #1: there is no such thing as ‘Too Much Power’
      HTG rule #2: See Rule #1
      Seriously, the 'First Watt' always applies. A good amp is a good amp; and typically, you get what you pay for.
      Under-powering will only cause under-whelming performance and will be more likely to cause damage to the speaker than a high-power amp due to the distortion a low power amp will produce when asked to produce volume levels beyond its ability.
      As always, AIMHO & YMMV
        • 1913
        Given the sensitivity and impedance of your speaker, I say a Solid State 150 Watts RMS will do it. And get one with a hefty power supply, and listen to it first. No hurt in going with 200+ Watts either. Like Bill said - clipping can damage speakers. If the room is small you may not need that much.
        Sometimes a lower power amp will sound best just because it's operating in it's lowest distortion range, which is often about midrange output power. Sometimes high sensitivity speakers, even ones that can handle a lot of power sound worse with big power amps, because you're only listening in the 5 - 10 watt output range where there is more distortion. I have this situation with my speakers (8 ohm, 93dB sensitivity) but our 75watt amp sounds much better that our 150watt amp. Both are basically the same amp (and same company) except for differences in the size of power supply and number of output transistors.
        This isn't true of all amps. But given your speakers sensitivity you probably don't have to be concerned about this. It's always best to audition a couple different amplifiers with your speakers, if possible.
        John unk:
        • eljr
          • Aug 2007
          • 88
          Would you consider these specs a good match?
          2 x 150W Minimum Continuous Power into 4/8 ohms
          220W, 340W, 460W IHF Dynamic Power into 8, 4 and 2 ohms, respectively
          PowerDrive™
          High Current Holmgren™ Toroidal Power Transformer
            • 1913
            Yeah, that would be enough power. Power ratings can be deceiving though and don't say much about amplifier quality. So listen to it if possible, or check for equipment reviews on the internet.
            John unk:
              If buying online get from a company that has 30 day money back guarantee and stand behind their product. If you have to ship it back your out shipping but at least your not stuck with something you don't really like.
              • audiolab1
                • Jan 2009
                • 11
                Exactly.
                Power figures on their own mean NOTHING with regards to fidelity.
                Just look at all the chip amps and AV receivers claiming 100s of watts per channel with puny power supplies and filter caps. Current delivery capability can actually be more important depending on the severity of the load.
                • jteoh1
                  B&W N802s and McIntosh Amps
                  by jteoh1
                  I'm looking some opinion on a good amp to drive N802s.
                  I'm upgrading my Denon 5803 receiver 2 front channels to a separate amp. So far, I have brought home the following amps for evaluation:
                  • Bryston 4B SST - Good details, mid is too forward sounding, lacks bass at low volume....
                  09 March 2005, 01:15 Wednesday
                • Vinny
                  Do I really need that much power?
                  by Vinny
                  Hi guys!
                  This is my first post here in HTguide. I've been reading the forum for a while and thinking about step into seperate by adding amp before next generation comes up(so I can afford upgrading one by one).
                  I'm considering about getting Halo A23 or NewClassic 2250(or Halo A21 even)...
                  05 March 2006, 08:38 Sunday
                  Cheap way to power an amp on/off
                  by Andrew Pratt
                  I have two power amps one has a built in power off and on toggle that my pre amp controls but my Class A Musical Fidelity amp does not. Given the Class A design this amp is sucking a lot of current from the wall and I wished I had a way to turn it on and off without resorting to an X10 switch or some...
                  17 February 2002, 19:15 Sunday
                • cfarha
                  N804 Power Requirements & Recommendations
                  by cfarha
                  Newbie here needing a little advise.
                  I'm about to purchase a pair of 1 year old B&W N804's. Other speakers in my HT set up are/will be B&W HTM2 Center (planned), Martin Logan Depth Sub, new surrounds TBD.
                  Currently I have been using an NAD T762 receiver rated...
                  26 March 2005, 16:51 Saturday
                • nick77
                  Pro amp reccomendation please
                  by nick77
                  Can you please help me understand the choice of using a pro amp with sub. I am looking to power RLP15 and was just going to get a high power plate amp but I see the amp of chioce is maybe a Behringer 1500 or 2500. I am looking at a sealed appliciation and dont want to be left weak at the bottom end...
                  17 April 2006, 20:17 Monday
