CA 840C CDp vs. Vinyl (long)
    CeeDee, Vinyl & the Point of Diminishing Return
    Last week my V good friend (PewterTA) brought over his new (less than the factory recommended 30 hours run-in time) Cambridge Audio 840C CDp for a V informal and unscientific demo.
    This was a unique opportunity for me to evaluate this acclaimed (and on the upper end of affordable to the average, on a budget, enthusiast) new player which is said to match competencies with units in the uppermost strata of decks, within my own system at home.
    After plugging in the 840c’s OEM power cord into a HTS 3500 MkII surge protector, I took a moment to sit down and take a look at it. This particular unit was in the standard (and currently ever so popular) silver finish. The traditionalist that I am, it did clash a bit with my all black equipment (us old-timer curmudgeons all know that black really does sound better) and is available in noir finish for those who share my personal preference. However, it still somehow seemed right at home. The unit is standard width and quite tall, fairly robust at ~ 20 pounds, with a V understated and practical faceplate. No fluff, gizmo tech dressing or unnecessary glitz. But not overly ‘Industrial’, either. I personally like the appearance of this type of equipment in general. It makes me feel as though the money I spent went into making the product do specifically what it is intended to do, without wasting production budget on things that don’t add or contribute to the root performance of the product. Some may call it ‘Plain Jane’. I call it getting what you paid for (see my signature line). The remote is substantial, feels good in your hand with a clean and intuitive arrangement that makes it easy to use the first time you pick it up.
    As a point of reference, here is what was down stream of the deck. We connected to the deck’s analog output via a pair of 1 meter WBT terminated SilverCat (100% Ag) IC’s made by CatCable, that run to my Carver C-19 pre-amp, it being stuffed with two pair of matched Electro Hamonix 6922 tubes from Upscale Audio (one set for the signal level pre, and another for the built-in phono pre). We used the C-19 by-pass circuit during the entire session which eliminates any coloration that may be induced by tone pots and other such superfluous imbedded circuits. The goal obviously being to hear how the deck, not the pre-amp, sounded. Another set of SilverCats are run to a recently factory-refurbished Rotel RB990-BX, 200 watt power amp. The boosted signal was then routed via an 8’ pair of Mapleshade Clearview Golden Helix speaker cables to my self made 67 liter ported cabinets of 3/4, 15 ply Baltic Birch construction with 1-1/2” solid Poplar front baffles, utilizing two V capable 7” aluminum cone & phase plug woofers and a 1-1/8” aluminum dome tweeter specifically matched to the passive crossover network designed by Jon Marsh (original Avalon designer), and uses only V high quality components including the solid copper air-core inductors and high tolerance audio grade resistors and caps.
    With the power on, the tray was commanded to open. In a smooth and purposeful manner, that’s just what it did. So far, so good. The tray itself not appearing to be anything special as in the likes of a solid, machined from a single aluminum billet type such as…. say…. one of Nagra’s decks, but hey, this puppy don’t cost ten grand either! Suffice it to say it serves its purpose and with all but the type of abuse it might receive at a Saturday night frat-house party, should stand the test of time just fine. We dropped in a disc of Duke Ellington big band compositions, ‘Digital Duke’, released on the GRP label. This album has tons of highly dynamic brass, percussion and string content, is fairly well recorded and is one that I am V familiar with. To my utter surprise, I was immediately served a dose of low frequency information that initiated a recheck of the hook-up and equipment settings. After verifying that everything was in fact, set as intended, i.e., as neutral as possible, we got back to listening. This deck sounded like no CDp I have ever heard. The amount of bass information being delivered was near the level I get from my vinyl playback system. In fact, the more we listened, the more I noticed the increased amount of information and detail across the entire spectrum. V impressive. Disc after disc produced the same result. At this point, I am not going to regurgitate the same diatribe nearly every person who has heard this deck recounts as to how well-engineered discs sound great (well-engineered) and poorly engineered discs sound worse than ever (poorly engineered). I will say this; I am in total agreement with them all. What ever is (or is not) on the disc, this deck retrieves it.
    Now what? Well what else……time to spin some vinyl, of course! And it just so happens I have an LP that goes by the title of ‘Digital Duke’ on the GRP label. Isn’t that an interesting and convenient coincidence? I fired up my Music Hall MMF-7, dropped the Grado stylus in the groove, sending the 5mV signal through a set of CatCable KingCat 100% Ag, shielded 1 meter I/C’s, to the tube equipped phono stage input of the Carver C-19 and performed a rough volume-matching using a Radio Shack SPL meter (again, this was by no means intended to be a truly scientific comparison, just two good friends who share an appreciation for music and its accurate reproduction, having some fun and listening to some new gear). The results were impressive relative to the 840. Differences were subtle, but still discernable. Note that some of the differences on the ‘Digital Duke’ album may still have been due to variations in the engineering of the CeeDee vs. the LP, as I have no proof that the CeeDee version was not slightly ‘tweaked’ during its production. Regardless, my observations were consistent with the variations I found between the two formats (any vinyl played on my table vs. any CeeDee played on the 840).
    Sustain on vinyl was more prevalent and precise, especially in the upper frequency ranges of cymbals and strings. Reproduction in the lower ranges was incredible on the 840, but still lacked realistic warmth and tactile ‘feel’ of the stick or hammer hitting the skin of the drums conveyed by vinyl. Highs on cymbals, high-hat, and brass lacked the typical shrill, hard edge we commonly hear on digital playback (some call this characteristic crisp, clear and tight highs when listing to digital, but I hear enough live music at the plentiful number of jazz clubs our little city has, to know how real, natural, unamplified instruments truly sound). Sound stage was about equal. Mids were V good and cohesive (V much an analog characteristic) on the 840, as where most voices. This is probably where the deck comes the closet to matching analog. When it came to 3D depth of soundstage, vinyl was still the clear and obvious winner.
    All well and good, but sometimes you can’t see the forest for the trees. After all this nit-picking and critical focus, looking for variations in specific details of numerous musical aspects like attack, speed, dynamic transients, air, textures, etc., etc…..on and on…...Just what the hell does all this mean with regards to accurately reproducing music? In other words, is this deck getting the music right, does it get your foot tapping when you don’t even realize your tapping your foot? What happens when you just sit down and listen to well recorded and engineered music. Does this thing have PRAT (Pace, Rhythm And Timing)?
    Well yes and no. Yes, this deck makes music from a digital source better than any player or DAC I have ever heard. It is as smooth and clean throughout the entire spectrum as I have heard from CeeDee. Is it as natural, involving, realistic and capable of conveying emotion as vinyl? No, not quite, but it is a close as I have ever heard.
    Do I want one? Hell yes! Is it worth the price? That depends; there is certainly nothing out there that I have heard that compares to it anywhere near its price. Would it replace my turntable? Nope.
    I realize some may think I am biased toward vinyl, and maybe they are right, and maybe they aren’t. Why I may or may not be biased is based only on what I hear. You may or may not hear the same way I do. Regardless, as with most things taken to the end-all, nth degree of perfection, as you reach the theoretical (and unobtainable) end of such a quest, the differences get smaller and the effort begins to approach infinity.
    So finally, we reach the point where I attempt to make a point. That being, if I already had a sizable library of Compact Discs, wanted to make a worthwhile upgrade to a system that was already at a level of reproducing music with revealing detail and accuracy, and was trying to decide if it was worth making the transition to vinyl, I would seriously consider getting the 840 instead. Heresy you say! No. practicality, I say. If I had a serous investment in digitally formatted music, converting to vinyl would mean replacing much of what I already owned. I don’t know about you, but I’m not in a position to replace 1000 CeeDees with LP’s, supposing that I could even find half of them, just to get an incremental, albeit to my ears significant, increase in fidelity. And what if the type of music I listen to is seldom released on LP to begin with. Do you see what I mean now? It is all related to the individuals own answer when calculating the equation of ‘diminishing return’. In this case, with the 840, you would end up with a great collection of music and a great player to listen to it (or at least the decently engineered discs in that collection).
    If, on the other hand, I did not have tons of equity wrapped up in digital to begin with, then I would take the same amount of money and get a vinyl rig. That amount by the way, would get a V nice rig, including a good cartridge and the sundries like a stylus force gage and record cleaning materials. The vinyl would sound better, and I could begin building a collection of my favorite music to play on it. And if you are fortunate enough to have reasonable access to flea markets, yard sales and even better, used record stores, the costs of music can be greatly reduced. Cheaper software costs, better sound quality. Once again, I see it as a function of ‘diminishing returns’.
    In terms of how this deck performs, I have to say I was skeptical prior to hearing it. Now that I have, I must truthfully admit that it could make a person decide to stay with digital. The difference is that close. I have a decent size CD collection myself and just purchased my first turntable within the last 6 months when I had no LP’s of my own. I now have nearly 200 LP’s, and rarely listen to my CD’s, mostly just when I need the convenience factor they offer. I have no regrets, for me the superior sound quality of vinyl makes that decision the right one for me. But, if I had this 840C CDp that Cambridge Audio just came out with, in all honesty I would be playing those CeeDees more often. Actually, a lot more often.
    Last edited by wkhanna; 08 September 2008, 21:49 Monday. Reason: edit speaker description
  • GregLett
    • 755
    Did someone say they want and 840C
    Greg
      Yes, I'll take two, please!
        • 1913
        Bill,
        Thanks for sharing that. Wow, what a long post ... how you'd manage to type that much? Honestly I couldn't read all of it just now, my eyes are too tired tonight. :B I'll check it out more thoroughly soon.
        I'm not in the market for a new CD player, although I would buy the 840C, probably, if I was.
        I've been enjoying my LPs so much lately. Compared to my current CD playback, LPs are much more musical and easier on the ears. I'm content now and just enjoying the music.
        John unk:
          • 1913
          Bill,
          A most excellent review. :T I'm glad I read it.
          John unk:
          • zmanbands
            • 151
            Excellent post Bill. You did a service to us all. Can't wait for you to re-listen to my system since I have made many many tweeks to it. If you try this again after the 840 is fully broken in, put the silver cat on the TT. or better the king cat on the 840. Thanks.
              • 4153
              I knew it!
              Excellent post! You said what I heard when I listened to the 840C ! You also hear what I keep saying about vinyl to my non-believing friends. :T
              My CD player and TT are old and obsolete now , but my experience parallels what you describe. Thanks for the backup!
              • Russ L
                • 544
                Thanks for the review Bill. :thanku: Its funny because my son and I are conducting a similar comparison between my new Clearaudio TT and my 840C tomorrow (which I haven't played very much for the last 10 days since the new TT arrived). Altho I haven't done a formal head to head comparison I have to agree with your comments on the balance of musicality between the sources. To add a few comments... the 840C excels over the TT in resolution and articulation of individual notes. But I think this is largely due to the digital disconnect between all the elements of the musical picture. It may be an illusory effect but to give an example the highs being caressed out of Hilary Hahn's violin in Mozart's sonatas on CD with the 840C are hard to beat using any other source. The attack, articulation and energy behind the high notes are superb. The large power supply in the 840C really makes a huge difference!
                Russ
                  Great Review on my 840c Bill, hands down... well said!
                  Though we all know my 840c is better than your Music Hall! ha ha ha.
                  My biggest compliment on the CD player, that night, was once or twice when Bill got up to change the music selection, he didn't realize we were not listening to his TT...or vice versa. We both agreed that we were just really enjoying listening to either one! To me that says wonders about the unit since we hadn't done much CD listening the last few times I went over.
                  I really can't say enough about the player...for digital sources, it's the best (and most likely final for this type of a source) purchase I could have made!
                  I also have to send out UNREAL props to "The Audio Shed." If you are looking for this player, definitely buy it there!!! He bent over backwards to work a deal out for my friend to get this player as well and basically beat out all the offers up on Audiogon with a brand new player. THAT's putting the customer first!
                  • twitch54
                    • 340
                    Bill and Dan,
                    nice right up ! and I must say I too concur with alot of your "audible observations" during your listining session, for I have done similiar comparisons with others in my setup.
                    Thanks for taking the time to write this out and share with us !
                    Dave
                    • GregLett
                      • 755
                      Thanks!! I really appreciate it.
                      Greg
                        • 4153
                        Hey , now..
                        I like my Music Hall TT!
                        • Russ L
                          • 544
                          We just finished our head to head comparison between the 840C and the Clearaudio Emotion TT with Benz ACE cart. Used a Creek Classic 5350SE Integrated amp with Tara Labs Vector 2 interconnects and Tara Labs Air 3 speaker cables. Units were powered through a Rotel RLC-1040 Line Conditioner using Tara Labs Prism power cables. The Cambridge Audio 840C CD player and Creek Classic Amp are supported by sorbothane Audioquest Q-Feet. Really lowers the noise floor, separates the instruments, improves the soundstage and articulation on the 840C. Unbelievably makes the player even better. The listening room is acoustically treated with Auralex acoustic foam including bass traps. The rear wall has a DIY sound diffuser. Speakers were B&W 704s placed well out from the wall. Unfortunately no SPL meter was used.
                          Ran Led Zep's "When the Levee Breaks" simultaneously in both units. We used the best remaster of the Runes CD, 1996 version I believe and the recent 180g 1/2 speed remastered vinyl version of the song on "Mothership". To be honest it was extremely hard to hear a difference switching back and forth. I felt the cymbals were a bit more natural and the voice a touch more smooth on the TT. My son heard no difference. But he wants a TT to compliment his music server.
                          The 840C is one fine unit. Analog Heaven is here-version No.2! :amen:
                          Russ
                          • avrtRick
                            cambridge 840c Vs marantz SA-11S2 with cd playback
                            by avrtRick
                            Does anyone have intimate evaluations on these units,A/B comparisons.
                            To be more spacific, does the 840 sound better with cd playback than the SA-11S2(I thought of buying both, but if the SA-11S2 is equal or better with cd's then I can put that $2000 on something else,maybe a DAC) :B
                            25 November 2007, 23:11 Sunday
                          • TheTownHalo
                            RCD-1072 > Vinyl ?
                            by TheTownHalo
                            I'm a long-time vinyl proponent. For the first time in my life, I may be starting to prefer CD's. Why? The Rotel RCD-1072. The more it breaks in, the better it sounds, and the more I find myself wanting to listen to CD's instead of vinyl. I never knew digital could sound this good. Now, I do have a...
                            08 October 2005, 13:42 Saturday
                          • oldbob
                            Vinyl is complicated
                            by oldbob
                            Is it worth all the trouble? That really depends. Let's start with the sound. If you have a very revealing system and you like to listen to music for fairly long increments of time. It is absolutely worth it. For some of us digital music can have the same fatiguing effect as bright speakers. But, let's...
                            03 September 2016, 18:51 Saturday
                            Vinyl and Cd...not vs.
                            by Alaric
                            I prefer the "feel" of most recordings on vinyl , even though my vinyl rig is a few steps down the scale from my digital stuff. It sounds (to me) like digital reproduction is a great reproduction of the performance. Vinyl sounds more like the performance. Or do I prefer older music on vinyl...
                            20 May 2007, 13:57 Sunday
                          • Burke Strickland
                            Taking vinyl LP playback via my Parasound JC3 yet another step up
                            by Burke Strickland
                            A while back, I added a Parasound JC3 phono preamp to my system. At the time, I was pleased with how well it worked with the JC2 BP line level preamp and JC1 mono block power amps to deliver truly enjoyable sound from vinyl LPs via my Magnepan 20.7 speakers.
                            Since then, I've heard demos...
                            22 December 2019, 00:50 Sunday
