This is something that comes up from time to time, and I've seen people with various opinions. Thought this was interesting, which comes striaght from a newsletter from SVS:
I thought this was interesting, and probably the best input I've read so far as to how phase should be used during the calibration. But why would there be an additional 6dB with a second sub? Logarithmically, I guess I'm not seeing why that works out to "double".
Dual subs for large spaces, or larger bass appetites, has been “the way” for years. Got duals? Get your SPL meter and get busy!
Keep the subs co-located, or within 4 to 5 feet (say the 1/3 and 2/3 wall points on the front stage).
Set the Phase Control to “0” on both subs to start. Also, set the AV receiver’s subwoofer channel level to “+1db” for now.
Play the AVR or Avia test tones, and with one sub at a time playing, adjust gain on each until achieving normal calibration level.
Finally, fire-up both subs together. The combined result should be 6dB higher than one individual sub. If yes? Lower the subwoofer channel level to “ - 5dB” and you’re done!
If the subs are more than 4 or 5 feet apart, or you aren’t getting the full 6 dB increase in measured output, then adjust the phase on one sub until you approach that 6dB of gain.
