Receiver Relief - What actually happens when ...?
  • timetohunt
    • Feb 2007
    • 38
    I will be adding an amp to my system to better accomodate my front speakers. There was a comment made on a previous thread basically stating that 'if you add the amp to power your fronts, it will relieve the receiver of some amp duties thereby making the receiver more capable in amping other channels'.
    I was wondering what really happens then. Does it make more power available to CTR and back channels ? Or does it reduce heat thereby adding stability to its amping capabilities. Or was the above statement not really true at all, and no additional power (or anything positive) is reclaimed by the receiver. Just wondered if someone knows what really happens here.
  • Ovation
    • 2204
    My understanding is that your receiver's power supply will have more "reserves" for any heavy transients if it has fewer channels to drive (there has to be a reason for those massive power supplies on powerful hi-end amps beyond the "weightiness"), particularly as surround transients are less demanding (usually) than those across the front. It's one of the reasons I'm exploring adding a two channel amp in the future (though with my heavy MCH hi-res music listening, I may splurge for a five channel amp instead--depending on finances, of course).
      Receivers are a compromise in most cases. Ok everything is a compromise but receivers do more at a lower price so there are generally more compromises. I have noticed that some hifi rags are now quoting 2 channels and 5 channels driven power ratings when they review multi-channel receivers. If you check these out you will see how power RMS drops as you drive more channels and the amp section has to deal with more load.
      Adding a power amp relieves the strain on the receivers amps but also most power amps will be better quality than the ones in a receiver. Receivers also often compromise on the pre-amp stage so a separate pre-amp for music is another step you can consider.
      Remember to factor in a decent pair of interconnects when you add a power amp. I recently inserted some $(AU)300 dollar flat silver/copper interconnects to replace a basic coper pair at half the price (its tricky avoiding cable brand names). Pretty much everything improved, particularly bass. When adding a power amp try auditioning a few cable options as well, including the HTguide house brand as well of course.
      • spyboy
        • 118
        timetohunt
        If you have not already added a separate power amp, I have some information that might save you a lot of money. It all depends on how you set up your receiver and which speakers you use. We can discuss this on or off line.
        Best Regards
          Adding a power amp to a receiver
          by Andrew Pratt
          As more and more people look to upgrade their sound systems people often ask about adding a more powerful amp to their system. Quite often this obsession we like to call our "hobby" leads us on a quest to sonic nirvana. As a group we are frequently upgrading our speakers or source components...
          23 March 2002, 09:06 Saturday
        • thyname
          Adding an Amp to RA-1570
          by thyname
          Hi everyone!
          I have a RA-1570. Just bought a pair of B&W CM10s this weekend, as I got a good deal used.
          While the RA-1570 is no slouch, and drives the CM10s sufficiently, I am already thinking of upgrading and adding an Amp, such as RB-1582 MKII. A little more juice...
          20 June 2017, 05:29 Tuesday
        • Rolyasm
          Doubling speakers by using amp AND reciever channels
          by Rolyasm
          I know this probably wouldn't sound good, but I was curious about this setup. Say a person was using a Receiver as a preamp and had a 5 channel amp for 5.1. So all 5 speakers are running off the amp. Is there a way to use the amp channels, AND the receiver channels. So lets say you have a typical...
          18 January 2006, 16:51 Wednesday
        • kuon
          Powering three channels
          by kuon
          I'm about to buy the following combo:
          RSP-1570 + RB-1582 + CM9
          for stereo.
          Now, this winter (early next year), I will be able to afford a pair of cm8 and a cm center.
          What I am wondering, is what would be the best combo...
          29 May 2011, 12:45 Sunday
        • Tomek
          Rotel amp choices, etc
          by Tomek
          I'm new to the forum. I have the following setup:
          Rotel RB-1090 amp
          Marantz SR-14EX receiver
          Paradigm Studio 100v2, CCv2, 20v2 speakers
          Marantz DV-12S1 DVD player
          Just recently I purchased the RB-1090 since the Paradigm 100s need power,...
          11 October 2003, 08:19 Saturday
