Amplifier connections
  • Martyn
    • 380
    Anyone have any preferences for RCA v. Balanced v. Speakon connections? Does it matter and, if so, why?
    The reason I'm asking is that I'm building an amplifier and will have to decide which I'm going to use for inputs and outputs. Thanks,
    Martyn
  • whoaru99
    • 639
    Well, purely in terms of connections, I'd think XLR would be better/more secure than RCA jacks. However, going that way would necessitate custom cables or adapters to connect the amp to other gear with RCA only. If you are building the amp, making the cables should not present any issues to you.
    As far as output connectors, I'd probably stick with plain old multi-way binding posts.
    ----JAFFE'S PRECEPT
    • Martyn
      • 380
      I guess I feel the same way, although I've never had an RCA jack fall off. I also feel that the short interconnects from the preamp to the amp probably won't really benefit from shielding, whereas the much longer speaker cables might be more deserving candidates. In the absence of a compelling argument either way, I'll probably end up taking the line of least resistance (RCAs and binding posts).
      • Kal Rubinson
        • 2109
        I agree with your conclusion but speaker connections do not need shielding as the impedances are so low.
        Kal
        Kal Rubinson
        "Music in the Round"
        • Martyn
          • 380
          Thanks, for once I might make life easy for myself.
          Now, should they be brass or copper? Gold, silver, rhodium...? Maybe I'll just run a couple of pig-tails and twist the ends together!
          • warnerwh
            • 261
            RCA's have been working great for alot of years. You may as well make it easy on yourself. XLR connections are nicely secure but really unnecessary for home audio equipment.
            • Martyn
              • 380
              I picked up a couple of Neutrik RCA jacks over the weekend - now I just have to figure out how to cut a 24 mm hole in sheet metal.
                24 mm = 0.944 in
                15/16" = 0.9375 in
                I have found these to be great for drilling sheet metal.
                • Martyn
                  • 380
                  Good idea. I have one somewhere, although maybe not quite big enough. Anyway, it'll do to experiment with. Thanks,
                    These bits can sometimes leave a burr on the exit side of the hole when you drill ‘soft’ (2000 series) aluminum or mild steel. Use light feed pressure to help reduce the likelihood of a massive burr. The good part is, they also make great a chamfer/de-burr tool when you use it from the back side to remove the burr. Also, nothing beats a round rat tail file for finishing to the required size.
                    • nick.h
                      Question: Optical VS RCA/XLR for Audio
                      by nick.h
                      I current use an optical connection from my DVD player to my A/V Reciever. It also supports RCA connections for each channel.
                      Is there any benifit in using RCA over optical?
                      I know if you use seperates from a processor it uses RCA/XLR to the amplifier...
                      26 March 2007, 06:01 Monday
                    • ht_addict
                      RCA connectors picking up interference on my amp
                      by ht_addict
                      Currently I'm in contact with Rotel regarding my 1095 that gives of a hum when connected to my pre/pro. The hum that the amp gives of is only present when my DVD player is connected to pre/pro via coax but not with optical. Its also present when my dvd/pre is connected by optical and I connect my sub...
                      09 April 2004, 20:17 Friday
                      Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
                      by theSven
                      By Jon Hancock
                    • riceaterslc
                      Differences between RCA Video and Audio Cables?
                      by riceaterslc
                      I need to purchase RCA type cables for a SACD player. I was looking for cables for the easiest setup. I can get two 3-wire component video cables or three standard audio cables. what will the sound quality difference be between the two? these are the two sets of cables I am currently looking at....
                      19 March 2007, 23:02 Monday
                    • LenB123
                      RCA Connector Question
                      by LenB123
                      I am setting up an LCD projector and I have to connect a "Y" adapter to the two audio (red/white) and the yellow video connectors from my DVD player. All I can find a Radio Shack are audio "Y" adapters, will those work with the yellow video signal, are RCA audio and video cables...
                      15 June 2006, 21:00 Thursday
