Audio terms????
  • drakeyb
    • 4
    Audio terms????
    Hello all,
    I've been reading this forum for a few weeks now and have found it very informative for the most part. But a few things seemed to have me puzzled. I will just make a short list and I would appreciate some incite....
    audio terms:
    musical?? all audio equipment I thought was 'musical'
    warm...
    forward...
    analytical...
    neutral.....
    there are a few more but these are the main one's. Thanks .....
  • Jesse111
    • 335
    Don't forget the most important one...WAF
    • Jesse111
      • 335
      Originally posted by drakeyb
      Hello all,
      audio terms:
      warm...
      forward...
      analytical...
      neutral.....
      All equipment plays music. But not all are "musical". Musical is a rather broad description of quality sounding gear. A consideraton of the terms underneath musical can help define musical equipment.
      For me, warm means not hot or not bright. It's a more cozy and pleasant sound not harsh. But too much warmth adds a darkness to the sound that hinders the livelyness and accuracy.
      Neutral in my opinion is a mark of a good speaker. No coloration. No dark warmth, no bright harshness. Sounds like what you'd expect at a live performance to a certain degree.
      Many of these terms overlap. Analytical, detail and others are descriptive words that simply offer an opinion of an individual.
      Detail is good, without it, you're not going to hear everything that was recorded. Imaging won't be as clear. Imaging is the sytems capability of producing the illusion of an image of a performer or instrument right before your eyes. A good image is astonishing. We could discuss these ideas for hours. And everyone hears things just a bit differently.
      By the way, WAF is (Wife Acceptance Factor). By far the most important, demanding most illusive and misundertood audiophile term of them all.
      • Victor
        • Apr 2002
        • 338
        Hello all,
        audio terms:
        warm...
        forward...
        analytical...
        neutral.....
        You are not alone. I have no idea what those things mean either. Perhaps they have no meaning at all. On the oter hand, the Terms like THD+N, resolution, frequency responce do have meaning and they also offer clarity of the subject matter.
        • fauzigarib
          • 216
          Hello all,
          audio terms:
          warm...
          forward...
          analytical...
          neutral.....
          Drake,
          This is a very good question. In fact, it's one of those questions that I'm sure a ton of people would want to ask, but would not have the gall to!
          I will attempt to answer your question, but there is no way I will be able to make you understand without an example of a, say forward speaker playing.
          Musical: This is a term used to describe the sound coming out of the speakers which I translate this to mean gentle and smooth. The sound coming out of your speakers sounds like it's playing smooth effortless music, rather than struggling to hit the notes. (Man, this is going to be tough!)
          Warm: I think technically this would mean that the highs of the sound are soft. Take a cymbal crash for example. The timber of that crash can very easily sound painful to the ears when reproduced through the speakers accurately. So a warm sound would be where it would be pleasant to hear.
          Forward: This term means that the sound is in your face. I've never quite understood this term, but I take it to be a bad thing. This usually happens, as I understand it, that the driver timing between the highs and lows are such that the highs get to your ears first. This makes the music sound a little ahead of where you would expect it to be. Of course, I could be completely wrong here.
          Analytical: The opposite of musical. (That wasn't too bad!)
          Neutral: This is probably the most important one in my mind. Each speaker, whatever material it's made of, has its own "sound". The way teh sound waves move inside the cabinet, the way they bounce of that specific cabinet material, the way the drivers sound, how the music is affected by that particular grill cloth, etc. If you listen critically for long enough, you will know that you are hearing cabinet resonances, or that you are hearing a driver that has not fully opened up yet. Each of these factors (and there are many more than the ones that I have mentioned here) add a certain color to the sound. So the idea is to strive for an uncolored - or neutral - sound.
          The fun part here is not to understand these above terms... but to make up your own. It's a lot easier than you think. "Dude, I don't know how to put this, but the sound coming out of you speakers is... ummm.... (finger to clef of chin, contemplating), gooey! Yeah, that's it!"
          Here are a few more that get a feeling across: Adhesive, deplosive, unmodulating, wavering... the list goes on.
          The trick is to put in one good sounding word, paired with a "but" and two critical yet intelligent sounding ones. "Responsive as your system is, it almost feels like the de-tonation and the wave-looping symbiosis curves are slightly off!"
          Read the current issue of Stereophile... it'll get you some good ideas!
          Good luck!
          Fauzi
          • alebonau
            • 992
            this is a good summary/glosary
            Subjective audio is the evaluation of reproduced sound quality by ear. It is based on the novel idea that, since audio equipment is made to be listened to, what it sounds like is more important than how it measures. This was a natural outgrowth of the 1950s high-fidelity "revolution," which spawned the notion that a component, and an audio system as a whole, should reproduce what is fed into it, without adding anything to it or subtracting anything from it.
              Musical Fidelity V-Dac vs RME 9632 Soundcard Comparison
              by audioqueso
              Test Setup:
              Speakers: B&W Nautilus 805
              Integrated Amp: McIntosh MA6800
              Source 1: HTPC w/ RME Hammerfall 9632 Soundcard
              Source 2: HTPC w/ Musical Fidelity V-Dac (via USB)
              Source 3: Marantz DV6001 DVD player w/ MF V-Dac (via digital coax)
              * All sources...
              26 July 2009, 17:49 Sunday
            • theMaximus
              Musical Fidelity X-10V3 Tube Output Buffer
              by theMaximus
              I have always been intrigued about the sound of vacuum tubes but have never been able to afford one. After reading some really good reviews, I just purchased this to try out. Musical Fidelity claims you can put this between your music source (CD player, IPOD, etc...) and your preamp or between your...
              15 August 2005, 09:49 Monday
            • jim1961
              Classe Warmth
              by jim1961
              Perhaps this varies from amp to amp, but Classe amps in general are depicted as being a bit warm in their presentation. For those of you actually owning (or previously owned) these amps (especially any CA-100 owners), what frequency range would you attribute this warmth to?
              13 October 2013, 12:34 Sunday
            • hired goon
              How neutral is the 805?
              by hired goon
              G'day,
              I'm currently doing comparisons of the B&W 805 against an Australian-made bookshelf speaker.
              One thing I noticed was that the Australian-made speaker seemed somewhat harsher in the mid-range. I asked the manufacturer why this may be so, and his response was that...
              10 October 2004, 21:20 Sunday
            • alebonau
              Musical Fidelity M8 500S
              by alebonau
              It would appear, that musical fidelity has listened and for those looking for a stereo amp in the M8 series can now consider the M8 500s. no doubt a stereo power amp in similar ilk to the m6 500i but a stereo power amp for those that thought the m8 700 was a bit too much
              07 February 2014, 04:36 Friday
