I Was Wrong – Some Cables Are Special
    Two weeks ago I was surfing the Internet and ended up on a forum about UFO’s, which I should make clear is a subject about which I am very sceptical. I followed a discussion on whether the US military had conducted analyses of the materials used in the UFO’s that have supposedly crashed on Earth, and if so, where that information could be found. One link lead to another and unexpectedly I gained access to a US Government site that had earlier denied me access. What I discovered at this site was just as interesting as UFO’s.
    I learnt that there is a type of copper that has different properties to normal copper. They referred to the “sub atomic” nature of this copper which made it much better for some electronic applications because it avoided what they called “electron falloff”. The words they used to describe this phenomenon were superior “handshake” and “error correction”, which are terms familiar to me from the computer industry. Basically it means that signals or data are transferred with a much lower error rate.
    This copper is being used by the US military (of course) but what really got my attention was the comment that it is also found in small sections of the hi-fi industry. The reason for this is interesting. Although this copper is closely controlled due to its military use, the owner of the mine in Zambia where it comes from has had connections to the hi-fi industry for over 30 years. This chap, who has a Scandinavian name that I can’t remember, is known in his country as “the father of hi-fi”.
    Other points of interest were:
    • Scientists do not yet understand why this copper behaves the way that it does. Uranium and zinc are found in the same mine, which apparently is most unusual, and this may be the cause.
    • Scientists have not been able to re-create this copper in the lab.
    • This special copper can be added to normal copper at a concentration of less than 1 part per 1000 and it will transfer its properties to the normal copper.
    • The only way that this copper can easily be detected is by its behaviour. The sub-atomic nature of the variation means that there is no easy test.
    Unfortunately I only had access to the site for one or two minutes before I was cut off so the summary was all I had time to read. There was a lot more information in the body of the document. I was a bit freaked out by the warning I received after being detected so I cleaned up my laptop afterwards. Now that no SWAT team has arrived at my house I could kick myself that I didn’t save the document. However I did learn enough in the little time that I was on-line to make the following educated guesses:
    • This copper is probably being used in selected speaker cables and interconnects from a small number of manufacturers, which explains why they sound better. It also explains why they are so expensive.
    • Some of you guys out there must know about this. Materials that are used for commercial manufacturing cannot be kept secret for ever. Who are those cable manufacturers?
    Also, does anyone know who the Scandinavian father of hi-fi is? It was a name with a “q” in it like Norquist.
  • bleeding ears
    • 435
    Hi, interesting topic, you may not get too many replies after telling us how you got the info.
    Apparently some guys on the inside have great Hi Fi systems too, not sure what sort of copper they use in their interconects etc, I suppose they just use what ever metals they find underground whilst tunneling their way out.
    Perhaps you can ask them if you happen to visit soon ? :lol:
    Just kidding, very interesting stuff !
    Perhaps Lex uses this stuff in his cables or can educate us about copper etc ?
    • whoaru99
      • 639
      Interesting.
      Well, my take is that IF there is such a thing, and IF it is so extra-special that the military has dibs on it, I'd be highly speculative about it being used to make audio cables.
      What's the link to the website where you saw this?
      ----JAFFE'S PRECEPT
      • whoaru99
        • 639
        Interesting.
        A cable that could do error correction - now that would be special alright.
        ----JAFFE'S PRECEPT
          Look a little closer at big's post. The cable isn't doing error-correction. The properties of the copper used in the cable facilitate cleaner transmission of data therefor less error-correction is required.
          It's an interesting premise and it'll be interesting to see if bigburner is with us much longer. :B
          • brac
            • Aug 2005
            • 90
            I would think if it was coming ouit out a small part of africa and the military was buying it all up. There would be one rich little section in africa, you know like the Vatican is a rich little section in Italy.......
            Got to get me some of that
            Brac
              Still here David.
              Capt. Reynolds would be proud.
                Hi ya big! Glad you're still around. However, I do understand that you have your own personal satellite in orbit now. Had any sensations of being watched? :
                  DVD players interfer with military
                  by Andrew Pratt
                  DVD owners get visit from feds over static
                  By DAN PALMER, EDMONTON SUN
                  Federal authorities say they suspect some DVD players may be causing havoc for emergency radios on military aircraft.
                  Ron Houston recently got a visit from Mounties and representatives...
                  27 October 2003, 10:26 Monday
                • RebelMan
                  Are Rotel Products HiFi?
                  by RebelMan
                  I have come to believe that there are three major camps that all audio/video reproducing electronics can fit into. These are LoFi, MidFi and HiFi. Although, you usually won't see them broken down this way.
                  From my experience and from the feedback of this forum, I have come to consider...
                  HiFi
                  30.77%
                  28
                  Above MidFi
                  43.96%
                  40
                  MidFi
                  23.08%
                  21
                  Below MidFi
                  0.00%
                  0
                  LoFi
                  2.20%
                  2
                  17 April 2005, 04:49 Sunday
                • RebelMan
                  Are Rotel Products HiFi? (Revisited)
                  by RebelMan
                  About a month ago I posed the poll question "Are Rotel Products HiFi?". This initiated a firestorm of feedback that started to go very well but then quickly began to deteriorate as many were very passionate about their feelings towards Rotel, both positive and negative.
                  People...
                  23 May 2005, 03:11 Monday
                • DS-21
                  Hobby HiFi 2/07 coax review
                  by DS-21
                  Has anyone read this review? Any comments? I'd be interested in reading/seeing more than the summaries listed here on a few of the drivers, specifically the two 10" coaxes by Sica and P. Audio and the HiVi (Expolinear) Trinity 6 spiral planar/ring-radiator/cone triax. But alas I've never seen Hobby...
                  17 February 2007, 04:49 Saturday
                • nick.h
                  803D: Copper or Silver
                  by nick.h
                  I've been checking out the cat cables website.
                  There are a couple of types of interconnects:
                  Kingcats Silver Audio Cables;
                  Silvercats Silver Audio; and
                  Bluetigers Audio Interconnects (Copper).
                  And the Cattails Speaker Cables...
                  21 January 2008, 06:38 Monday
